3 Jaw self centering ER chuck
An unusual tool
Joseph Noci 120/02/2019 09:54:34
671 forum posts
890 photos
Would there not be a chance of swarf, minute or otherwise, penetrating the collet/jaw contact area when the jaws are released to remove the work piece? After all, the swarf flies everywhere inside the cabinet and in the video, the tiny brass shavings might enter the chuck area. Unlike a normal collet holder that is essentially sealed except for the slots at the workface.
I still like the idea though. I also especially like the cnc machine..
Joe
JasonB20/02/2019 10:01:20
18132 forum posts
1996 photos
1 articles
He says he uses through coolant collets so slots are sealed
jimmy b20/02/2019 10:45:30
638 forum posts
38 photos
I just used to hold an ER collet chuck in some soft jaws.
I really can't see an advantage to how this is shown.
JIm
Chris Trice20/02/2019 10:45:51
1362 forum posts
9 photos
Given the high degree of accuracy with which the chuck jaws are obviously machined, I can imagine that the part of the jaws that fits in the collet groove also contact the bottom of the collet groove and participate in the closing action as well as preventing the collet being squeezed out the chuck..
Chris Trice20/02/2019 10:51:21
1362 forum posts
9 photos
Posted by jimmy b on 20/02/2019 10:45:30:
JIm
I don't think it's an attempt to improve accuracy but more about being able to change sizes quickly and positional consistency. However, I suspect it's probably very accurate also since the soft jaws by their nature hold very accurate tolerance when holding at the position they were machined at.
JasonB20/02/2019 11:19:28
18132 forum posts
1996 photos
1 articles
Once again if you read the link you will see in this instance he has 250 of those brass tubes to machine and the setup allows the material autofeed to be used rather than having to stand by the machine to undo and tighten an ER Collet 250 times
Edited By JasonB on 20/02/2019 11:20:11
Neil Lickfold21/02/2019 06:02:20
614 forum posts
102 photos
It is a easy way to have an auto collet closer using the 3 jaw chuck.
Joseph Noci 121/02/2019 06:26:27
671 forum posts
890 photos
Posted by JasonB on 20/02/2019 10:01:20:
I am not sure I understand what you mean by 'sealed'
Your photo below shows normal slit collets - where is the sealed slots? My query was re swarf entering the three jaw to collet contact area,ie the collet taper surface. The 3 jaws have space between them where swarf could enter and when the 3jaw retracts to decompress the collet, swarf can enter the gap, enter the collet slit, or the collet to soft-jaw contact area, upsetting TIR surely..?
Joe
