Flott TB13 STW Electrics
Power supply replacement for DC motor
Pete.19/02/2019 14:28:16
217 forum posts
36 photos
I've got a Flott TB13 STW Drill press from the 80's, the motor works fine but the electrical components are well aged, temperamental and imo beyond help, as an electrical incompetent I was wondering if anyone could tell me if this would be a suitable replacement to power the motor, it has a 700w DC motor https://www.ebay.co.uk/itm/AC-220V-Input-DC-0-220V-Output-Speed-Controller-Motor-1200W-10-65-HHD6-G/183574495849?epid=2181750644&hash=item2abde48269:g:RakAAOSwXi9cGbTX:rk:2f:0
Thanks.
John Haine19/02/2019 16:07:21
3012 forum posts
160 photos
It would help if you could be a bit more specific as to what the problems are and why you think it is beyond help. It could for example simply be that it needs a new speed control potentiometer if it is "temperamental" - that implies that sometimes it works and sometimes it doesn't. Yes that controller might do the job, looks the right sort of rating. Note that it has provision to drive a field winding which you might or might not need on the machine motor.
Symptoms plus a couple of photos of the inside would help, it looks like a nice machine and well worth preserving.
Pete.19/02/2019 17:00:51
217 forum posts
36 photos
Posted by John Haine on 19/02/2019 16:07:21:
Ok, the motor would sometimes start, sometimes not, then the what seemed like the on off switch popped and tripped the fuse box, apart the that all the connections on the circuit board are kinda loose and brittle, and just looks like things are going to start falling apart soon, which is why for the sake of £20 I'd replace it if possible.
John Haine19/02/2019 17:50:54
3012 forum posts
160 photos
OK, sounds sensible then. Probably the existing controller is a thyristor or triac type, similar to the eBay one. The eBay controller is probably floating so you need to take care when installing it, and check that the original design does not assume the controller is grounded. On that controller, you'll see that one end of the potentiometer is labelled GND but I suspect that this should NOT be connected to mains ground, it just means the common end of the pot. As I said, some photos of the current device showing the wiring, terminal blocks etc would be useful. Given your professed competence in electrical matters, it would be well to get someone who knows more about electrics to have a look!
Pete.19/02/2019 20:24:57
217 forum posts
36 photos
img_20190219_201352.jpgimg_20190219_201257.jpgOK, here's a few photosimg_20190219_201130.jpg
John Haine20/02/2019 09:24:06
3012 forum posts
160 photos
Thanks. The German words "metallteile der electronik führen spannung" mean "metal parts of the electronik carry voltage" - as I suspected the controller floats at mains voltage. It also looks like there are a few ICs on it so quite complex, it probably has a speed regulation function as well as control, to keep the speed constant under load. I'm not sure if the eBay controller will have this - on my little CNC mill I use a KB Electronics controller which does.
John Rudd20/02/2019 11:35:15
1368 forum posts
66 photos
The KB Electronics speed controller has a few features, current overload protection, Acc/Decel ramp adjustment, as well as motor current feedback.
Well worth the money if you buy one and far superior to the Ebay offerings
Pete.20/02/2019 23:56:24
217 forum posts
36 photos
Could you give a link to a suitable KB Electronics speed controller? I'd be willing to spend a bit more if it means it's done right.
Pete.21/02/2019 00:05:46
217 forum posts
36 photos
Although I do have a few new treadmill motors which would swap with the original very easily, I could put a reverse mode on that so it could be used for tapping as well, and keep the motor as a spare, as I actually picked up 2 of these Flott TB13 stw's, the other looks in much better condition inside, this one has various wires soldered into place, looks like someone was quite rough with it while repairing something in past,
Thank you for your input it is appreciated.
John Haine21/02/2019 07:28:45
3012 forum posts
160 photos
**LINK**.
That's the U.K. Stockist and the version that on a quick look seems best for your motor. I've sent you a PM.
Alexandr Bondar19/07/2019 12:43:51
1 forum posts
DST gprive. I am from Ukraine, so I don’t know English. Could you get a photo of the internal parts of the machine? Just such a machine restore. Very necessary. Thank.
