Forum sponsored by Allendale Nov 29
Potting Adhesives : for Glass Fiber/Fibre Optic Bundles
Recommendations, please ...
Michael Gilligan13/02/2019 10:29:58
12752 forum posts
552 photos
I have a need to make some custom 'ends' for light guides.
... Schott glass, in fine strands
[currently in 1mm diameter bundles within a sheath]
There are many adhesives offered for this job ...
Most are rather costly, so I cannot really afford to experiment.
Can anyone please recommend a reasonably-priced product ?
MichaelR13/02/2019 11:00:27
310 forum posts
50 photos
MichaelG, I have no knowledge of the subject you are working with but would this item be of use or what you are looking for.Link Mike.
Michael Gilligan13/02/2019 15:21:46
12752 forum posts
552 photos
Posted by MichaelR on 13/02/2019 11:00:27:
Thanks, Mike ... That's certainly cheaper than some I have seen.
Ian P13/02/2019 20:57:44
2037 forum posts
88 photos
I know little about terminating fibre optics so this product from Rapid Electronics might not suit your purpose but I have used it for both encapsulating LEDs and for potting subsea cable splices.
Its water clear, runs like water (almost), and when cured has some flexibility so its not brittle which might make subsequent surface polishing difficult, the 50mL twinpack is what I would call economic. Unfortunately Rapid recently only stock to order so lead time is quite long and MOQ make experimenting expensive.
Alh Systems A6175 NP1480 Water Clear Polyurethane Potting Compound 50ml Syringe
Rapid code 87-7176
Ian P
Michael Gilligan13/02/2019 21:14:13
12752 forum posts
552 photos
Thanks a lot for that, Ian
The product you mention would almost certainly be suitable for a related project that I have in mind [where the existing cable ends will be used] but, as you note, being slightly flexible it would probably prevent satisfactory polishing of cleaved fibres.
Much appreciated
Edit: ... Drat !!
Just noticed the 24 unit 'minimum order quantity'
... now busy looking for an alternative supplier.
Edited By Michael Gilligan on 13/02/2019 21:19:17
Ian P13/02/2019 21:26:29
2037 forum posts
88 photos
Despite having some compliance I dont think it will prevent polishing the fibre strands, my comment originally was referring to polishing the resin surface.
I think the only alternative is ALH themselves but I dont know what their MOQ is.
Ian
Michael Gilligan13/02/2019 21:43:24
12752 forum posts
552 photos
Posted by Ian P on 13/02/2019 21:26:29:
Thanks for clarifying that, Ian
I have no need to polish the resin itself; just the fibres.
charadam14/02/2019 01:00:17
166 forum posts
MG - what on earth are you talking about?
Please educate me (and possibly others)!
Michael Gilligan14/02/2019 08:10:21
12752 forum posts
552 photos
Posted by charadam on 14/02/2019 01:00:17:
This sort of thing: **LINK**
https://www.edmundoptics.com/c/fiber-optic-light-guides/717/
Roderick Jenkins14/02/2019 08:45:33
1681 forum posts
426 photos
Michael,
When I was scouting around looking for a metallurgical potting compound for home use I plumped for this stuff via Amazon **LINK** It sets hard and doesn't interfere with the grinding and polishing of the specimens. Actually it polishes up very nicely itself and seems very similar to the professional (expensive!) products I used to use in a former life.
Hope this helps,
Rod
Michael Gilligan14/02/2019 09:22:22
12752 forum posts
552 photos
Thanks for that, Rod
Good to have the benefit of your experience yes
Although it may not quite be suitable for my immediate needs, it certainly looks ideal for specimen preparation.
... I'm sure to need some soon.
charadam14/02/2019 09:56:04
166 forum posts
Michael, thank you.
Eyewatering prices on that website - I see why you DIY.
Neil Wyatt15/02/2019 10:09:44
15676 forum posts
658 photos
73 articles
What kind of light guide are you making?
Michael Gilligan15/02/2019 10:31:09
12752 forum posts
552 photos
Posted by Neil Wyatt on 15/02/2019 10:09:44:
It's an area of experimentation, Neil ... so probably lots [good, bad and indifferent]
But the immediate interest is edge-lighting of microscope slides
so the 'round in' to 'line-out' variety ... on a rather small scale.
TRANSWAVE Converters
