Forum sponsored by Allendale Nov 29
Anyone recognise this optical magnifier
Norfolk Boy10/02/2019 11:17:44
36 forum posts
14 photos
Hi All,
Having a bit of a clearout (long way to go) found this item in a drawer. I didn't photo the ends but theres a lens each end. I assume it needs an external light source to get the most out of it. I would be interested in it's purpose. It's made in Germany and I think it may be something to do with photography as I acquired it from my father ..I think.
Alan
Michael Gilligan10/02/2019 11:36:39
12775 forum posts
554 photos
Alan
I think it may be for record player stylus inspection
... was he an audio enthusiast ?
Philip Rowe10/02/2019 11:56:02
164 forum posts
14 photos
It's what I would describe as a pocket microscope, in a former life I used to use one for inspecting the polishing on fibre optic cable ends. Mine I think came from RS, but at the time were still known as Radiospares.
Phil
capnahab10/02/2019 12:00:14
178 forum posts
61 photos
It is indeed a pocket microscope, the bevelled end for letting light in is the giveaway.
Norfolk Boy10/02/2019 12:21:37
36 forum posts
14 photos
Ahh,
Interesting, I work in communications and do splice optical fibres, but I have only been doing it for the last 20 years with relatively modern equipment with lcds screens etc, and have never done the polishing, seen someone do it once. Now looking at the link below the extra light source needed makes a bit more sense, without that not sure its much use.
https://www.theloupestore.co.uk/Hand-Lenses/Pocket-Magnifiers/Tech-Line-Zoom-pocket-microscope-314.html
Alan
Michael Gilligan11/02/2019 00:15:25
12775 forum posts
554 photos
Alan
Phil obviously put you on exactly the right track, but; just for the record ... this is the Colton device that I had in mind: **LINK**
https://picclick.co.uk/Colton-Stylus-X-50-Stylus-Inspection-Pocket-Microscope-263582698911.html
Neil Wyatt12/02/2019 09:13:18
15700 forum posts
659 photos
73 articles
It looks like a 'better than aveverage' pocket scope, but the little mirror suggests that it may be optimised for looking at things from the side and reflecting light up on to them.
My ancient cheapy (which works as a passable 'splinter checker' also functions as a very awful telescope. It has a transparent, bevelled end.
Lambton12/02/2019 11:18:33
669 forum posts
Norfolk Boy,
This is an Eschenbach Optik 1171 Microscope that used to be supplied by RS components part number 541-040 now discontinued. I have the 40x only version which is difficult to use unless you have excellent vision.
Eric
Norfolk Boy12/02/2019 17:41:26
36 forum posts
14 photos
Hi Eric,
Thanks for the info. I must admit I have tried a number of ways to look at things with it, and concluded that it is so difficult to use that I will never have a use for it. I have managed up to now with other means of looking closely at things and I have a set of binocular twin optic microscope (don't know what else to call it) that I found at work that I assume were used in very early fibre splicing techniques.
I use them infrequently also to be honest, mostly doubling up with reading glasses gets me by. I am just scratching the surface of decluttering in an attempt to create enough space and ready access to things so I can acheive something without spending all day trying to find things. Wasn't a problem when I was younger I remembered where everything thing was, now I have to see things as I glance around. I do realise this is a drop in the ocean but it turned up in the excercise.
Alan
TRANSWAVE Converters
