Threading a bar for 6ba
Former Member | 07/02/2019 16:07:32 |
1329 forum posts | [This posting has been removed] |
Howard Lewis | 07/02/2019 16:15:20 |
6040 forum posts 14 photos | The Model Engineer's Handbook, Third Edition, by "Tubal Cain" gives the top diameter of 6 BA as 0.1102" or 2.80 mm, so you should be OK with 0.110" Howard |
Clive Brown 1 | 07/02/2019 16:39:16 |
807 forum posts 39 photos | Bill, Have you considered buying 6BA threaded rod? Rather less hassle than DIY if you need any significant length. Lots of hits on google/Ebay in several materials. |
Neil Wyatt | 07/02/2019 17:03:32 |
![]() Moderator 18994 forum posts 734 photos 80 articles | That's right althouigh slightly undersize won't do any harm. I doubt you will be able to buy those sizes off the shelf. Neil |
The Novice Engineer | 07/02/2019 17:11:44 |
84 forum posts 72 photos |
Try here for 6BA Studding https://maccmodels.co.uk/ba-fastners-washers/ba-studding/6-ba-steel-studding.html or click on the link below |
not done it yet | 07/02/2019 17:28:15 |
6749 forum posts 20 photos | I expect you can use any size above the minimum, but if long lengths you will need a traveling steady to turn the rod to size. Are you single pointing or running a die down the rod? As above, buying threaded rod may be easier, but obviously several choices. But threaded rod is expensive if you only need the threads on each end. |
JasonB | 07/02/2019 17:38:24 |
![]() Moderator 22605 forum posts 2643 photos 1 articles | EKP sell 7/64" which will take 6BA quite nicely. Alternatively can you substitute 3.0mm rod and thread M3 |
Former Member | 07/02/2019 18:03:56 |
Ian Skeldon 2 | 07/02/2019 19:25:43 |
540 forum posts 54 photos | Firstly my apologies is this post is considered to be hi-jacking the original thread (there's a pun in there somewhere). What is considered to be the best way to create very small diameter threads ( 1mm for instance) both internal and external, can you buy taps and dies in that sort of size? Thanks, Ian |
Benjamin Day | 07/02/2019 19:34:50 |
61 forum posts | Ian, search watchmaker die plate. Several size dies are all on one plate, they usually come with the silly tiny taps too. Hope this helps! |
IanT | 07/02/2019 20:08:56 |
1989 forum posts 212 photos | Hi Ian S2 Surprisingly (at least I was surprised) Machine Mart sell a set of taps and dies that range from 1mm to 2.5mm. I've only used mine on brass (and will not use them on ferrous at all) but they seem OK. Usual cautions - you need to guide the tool - both the taps and dies in these sizes - especially the small ones. I've just checked and they are currently £38.39 a set Probably not top quality at that price but for occasional (and careful) use they were the best option for my needs. Regards, IanT |
Nick Clarke 3 | 07/02/2019 20:22:08 |
![]() 1397 forum posts 61 photos | Posted by Ian Skeldon 2 on 07/02/2019 19:25:43: Firstly my apologies is this post is considered to be hi-jacking the original thread (there's a pun in there somewhere). What is considered to be the best way to create very small diameter threads ( 1mm for instance) both internal and external, can you buy taps and dies in that sort of size? Thanks, Ian I have the set that IanT suggested and second his views. Have a look at Tracy Tools website, or if you are at Doncaster Show pick up one of their catalogues. - usual disclaimer - just a satisfied customer - other suppliers are available etc etc |
Ian Skeldon 2 | 08/02/2019 20:45:23 |
540 forum posts 54 photos | Thank you Benjamin, IanT and Nick, I will check out both of those suggestions. Ian |
Chris Trice | 09/02/2019 11:20:21 |
![]() 1375 forum posts 10 photos | https://www.amazon.co.uk/Small-0-70mm-Plate-Match-Postage/dp/B00BJ2RFYW |
Chris Trice | 09/02/2019 11:22:20 |
![]() 1375 forum posts 10 photos | https://www.amazon.co.uk/Rolson-59154-HSS-Mini-Tap/dp/B0080R1M6G |
