Another gas engine question, sorry!
AJW04/02/2019 22:51:07
278 forum posts
117 photos
My Centaur engine (horizontal) is designed to have a drip lubricator towards the open end of the cylinder.
This is all fine for piston/cylinder lubrication but how is the oil supposed to get to the little end?
Little end of the connecting rod has an oil hole in it so I was thinking of a tube pressed into the piston skirt for directing oil to the area required?
Is this the way it's done, or just give it a squirt before each run?
Alan
Dennis R04/02/2019 23:02:05
46 forum posts
11 photos
Alan
Usually there is a hole in the side of the piston above the little end, so that oil can drip through from the cylinder.
Dennis
JasonB05/02/2019 07:56:25
17098 forum posts
1843 photos
Yes Most of the horizontal open crank engines I have made have a hole in the top edge of the piston above the pin. Still worth putting a drop into the small end hole before you start the engine.
MichaelR05/02/2019 09:42:13
351 forum posts
64 photos
Your idea for lubrication of small end is shown here. For the Centaur.lube.jpg
Edited By MichaelR on 05/02/2019 09:42:53
AJW05/02/2019 13:08:00
278 forum posts
117 photos
Thanks for replies, I thought about the tube idea as without it would any incoming oil not just run round the interior of the piston?
Alan
