Christopher Buxton | 03/02/2019 18:24:00 |
5 forum posts 3 photos | Hi there, so I'm a newbie to the engineering world and probably trying to jump in at the deep end. I want to reproduce some watch bezel inserts from aluminium.If they were flat then probably not too difficult to make on the lathe but unfortunately they are conical.I can get some stock aluminium tube that's less than a mm too big O.d and I.d so very little machining there. If I get the correct pitch from the leading face using the lathe then I can cut off. That just leaves the back to do. Would I need a milling machine to do this or could I cut off at an angle? Dimensions are 37.7mm o.d 0.4mm depth 31.7mm I.d 0.7 mm depth. Think the pitch is 27 degree putting the dimensions into a trapezoid calculator. I've put photos into an album but not sure how to add them to this post. Thanks for advice |
Howard Lewis | 03/02/2019 18:57:41 |
1697 forum posts 2 photos | Could you turn the chamfer on the outer end, (offset Top Slide) and then carefully part off? Or maybe I've misunderstood the shape. Howard |
Emgee | 03/02/2019 18:59:27 |
1022 forum posts 191 photos | Hi Christopher Welcome to the Forum, you could turn the internal angle (bevel) on a lathe by setting the top slide over to the required angle. You may be able to turn a flat ring and make a simple press tool and former to achieve the bevel shape. Emgee |
Christopher Buxton | 03/02/2019 19:09:04 |
5 forum posts 3 photos | Hi Howard, Thanks for your reply. Are you able to view photos in my album? |
JasonB | 03/02/2019 19:25:07 |
![]() Moderator 14657 forum posts 1455 photos |
From the top 1. face the end of your tube 2. Reduce OD and bore ID to finish size 3 Set over topslide to cut tapered underside 4 Parting cut most of the way through to height 5 With topslide still set at same angle machine the top slope 6 Complete parting cut to separate part Edited By JasonB on 03/02/2019 19:32:48 |
Michael Gilligan | 03/02/2019 19:25:57 |
![]() 12554 forum posts 545 photos | The design and manufacture of suitable chucks for this sort of work is featured in the current issue 277 of MEW. https://www.model-engineer.co.uk/editorial/page.asp?p=250 Well worth a look. MichaelG. . Edit: ... am I right in thinking that there are 'beaded edges' visible on the underside ? https://www.model-engineer.co.uk/sites/7/images/member_albums/179580/823476.jpg Edited By Michael Gilligan on 03/02/2019 19:44:02 |
SillyOldDuffer | 03/02/2019 20:15:26 |
3762 forum posts 747 photos | Similar to Jason: Step 1, face off and bore tube to the diameter of the bevel's inner ring at the narrow end. Step 2, offset the tool-post and chamfer the inside. Step 3, cut the outer chamfer Then part off. If necessary for a better finish I'd superglue the clean end of the bevel to a rod held in the chuck and skim the parted-off side with a sharp tool. From the comfort of my armchair, not difficult to do by angling the tool-post. Apart from the extreme delicacy needed while cutting that is! As Emgee mentions, manufactured bevels could well be made by stamping rather than turning. Please report back, it's a challenge! Dave Edited By SillyOldDuffer on 03/02/2019 20:17:40 |
Emgee | 03/02/2019 21:35:36 |
1022 forum posts 191 photos | After further consideration I believe myself, Jason and Dave are expecting a lot of a newcomer without a lot of experience using a lathe to be able to do such delicate work, especially if he uses the tube mentioned in the post, I now feel stamping seems to be his best bet. Emgee. Edited By Emgee on 03/02/2019 21:43:28 |
Christopher Buxton | 04/02/2019 11:31:59 |
5 forum posts 3 photos | Thanks for the awesome illustrations.I now know how to tackle it. I only have a boley watchmakers lathe with compound cross-slide but hopefully as it's a soft metal it might do the job. I don't want to make any big purchases on a larger lathe or milling machine right now until I know whether I can complete the next steps successfully. I.e black anodizing then printing the silver markers and numbers, either by pad printing, laser etching or chemical etching. So just a few blanks hand turned should be sufficient. Then I might look at making or buying a press as Emgee suggested to get a small production line going. Anything on a larger scale I think a laser cutting service would be needed. As soon as I get the materials I need I will document and post the results. |
SillyOldDuffer | 04/02/2019 17:12:48 |
3762 forum posts 747 photos | Emgee's concern this might be too delicate got me out of my armchair following my own advice. First I bored an 18mm cavity into a bit of scrap Aluminium 22mm diameter rod. (Although scrap the alloy is known to machine well.) Then I angled the tool-post: and widened the hole by cutting a 20 degree bevel into it. The tool was traversed by the topslide and was happy taking 0.8mm cuts. Main problem was chatter on the shallow finishing cuts, but note I used an ordinary coated blunt insert rather than a sharp one intended for non-ferrous metals. Without altering the angle of the toolpost I switched to a left-hand insert, which happened to be correct for Aluminium and cut the outer chamfer. I narrowed the wall down to 0.6mm (messed up - it's actually 0.52mm) Then reset the toolpost to 0 degrees and parted off: As it didn't part-off cleanly: I superglued the ring backwards on to the rod Then switched to a sharp right-hand tool and tidied up: In the past I've easily broken Poundshop superglue joints by leaving them in boiling water for a few minutes. Not so this time with proper Locktite - it has better heat resistance and I had to blowlamp it for a few seconds. Wasn't difficult to do and I could have got a much better finish with a little more work. Despite my legendary clumsiness and use of carbide rather than sharp HSS the bevel wasn't stressed during cutting. I'd bet money on Christopher succeeding - if I can do it anyone can. Only issue was making sure tools cutting at an angle didn't foul the work. Also, switching to a right-hand knife rather than using a boring bar to make the inner chamfer would probably have eliminated the chatter. Dave |
Michael Gilligan | 04/02/2019 17:51:20 |
![]() 12554 forum posts 545 photos | Nice demonstration, Dave ... 'though the angle looks somewhat different to the example in Christopher's album. I suspect that his version may prove trickier. MichaelG. . [heckling from the safe haven of my armchair]
JasonB | 04/02/2019 18:26:14 |
![]() Moderator 14657 forum posts 1455 photos | In true Blue Peter Style here is one I prepared earlier (about 10 years ago) 1.125" OD, 30deg slope which is not far off the OP's 27deg, 0.025" thickness, Steel. Finish looks bad at this magnification! Just done on the end of a bit of bar in the 3 jaw, more or less the same as I suggested above. Edited By JasonB on 04/02/2019 18:28:01 |
Martin W | 04/02/2019 18:46:54 |
774 forum posts 29 photos | Hi Just printed out one of the photos showing the bezel ring edge on and measured the angle of the bezel to the base and this gives an included angle of 22.5 deg. Before anyone jumps up and down I know that this is not the way determine the 'true' angle on the bezel. I think that SOD by offsetting the top slide by 20 deg actually cut an included angle of 70 deg rather than 27 deg and this would account for SOD's bezel looking very different from the pictures. That said Dave clearly illustrates one method of producing the particular part on a lathe which is what Christopher wanted which was the point. Cheers Martin W |
Michael Gilligan | 04/02/2019 18:50:28 |
![]() 12554 forum posts 545 photos | Posted by Martin W on 04/02/2019 18:46:54:
I think that SOD by offsetting the top slide by 20 deg actually cut an included angle of 70 deg rather than 27 deg and this would account for SOD's bezel looking very different from the pictures. . Yes, that was my point, Martin ... Jason's is much flatter. MichaelG. Edited By Michael Gilligan on 04/02/2019 18:52:02 |
duncan webster | 04/02/2019 21:26:04 |
![]() 1860 forum posts 36 photos | +1 for SOD method, but I'd have machined a groove with a parting tool so that the outer chamfer ran into fresh air rather than becoming a wider and wider cut. |
Tim Stevens | 05/02/2019 11:05:57 |
![]() 981 forum posts | Jason - if your three pictures above were done with the same settings, they are a very good example of the colour bias created by cameras which try to achieve an overall 'standard' colour balance. The same effect causes tools which are just less than new to look really rusty, unless there is plenty of red in the background. Perhaps this effect has caused others problems, so I hope this helps someone. cheers, Tim |
Hopper | 05/02/2019 11:40:50 |
![]() 3161 forum posts 53 photos | Yes, "automatic" camera settings can be a bit like "universal" motorcycle parts: they almost fit everything but don't quite fit anything. |
Michael Gilligan | 05/02/2019 13:35:14 |
![]() 12554 forum posts 545 photos | Posted by Tim Stevens on 05/02/2019 11:05:57:
Jason - if your three pictures above were done with the same settings ... . As we know : Everything lump of metal that Jason machines 'turns to gold' MichaelG. |
SillyOldDuffer | 05/02/2019 14:07:20 |
3762 forum posts 747 photos | Forgive me if this is getting boring but I think there's a little more beginner interest to be squeezed from the question. In my defence I deliberately cut a 70° bevel rather than the shallow 27° mentioned by Chris because I thought it would be easier to photograph. I ignored Chris's other dimensions as well - they didn't match the scrap in my junk box! But people noticing the angle was 'wrong' allows me to comment on angling the tool-post as a problem. Not all lathes have an angle scale fitted. These have to be set either by gauge or by calculation, which might be necessary for accuracy anyway. On lathes fitted with with an angle scale the maker has a choice between showing either the post's angle to the saddle, or its complement ( 'opposite' ) which is the angle the tool cuts relative to the spindle axis. Getting it wrong makes a difference!
Quite a lot of beginners, including me, get caught when first attempting a screw-thread using the recommended set-over top-slide method as per the excellent Mr Sparey. A small problem is that Sparey writing in 1948 recommends 27½° which is correct for 55° Whitworth but not ideal for a 60° metric thread where the offset should be 30° (ie half the thread angle). However a much bigger problem is that - for Whitworth - the angle scale on my lathe should be set to 90°-27½° = 62½°, not to 27½° as specified by Sparey. Your scale may not align with Mr Sparey's instructions! Lesson learned: always check the angle at which the tool moves rather than assuming your lathe's angle scale has removed the need to engage brain! Michael pointed out that my demonstration is flawed by me cutting a deep bevel rather than what was in Chris' spec. Quite right, it is harder to to cut a shallow bevel because the tool gets in the way. In this photo the top-slide is at maximum travel! I was able to get close enough by increasing the tool overhang. Normally I like the cutting point to be as close to the tool-post as possible. It reduces the risk of chatter. However, chatter wasn't a problem in this case even with a long overhang. Another consequence of lack of space due to the angle was that Duncan's point about cutting a groove came into play! In order to make space for the insert holder, I had to rough-out a groove in the rod before making the real cut. It's helpful when grooving like this that carbide inserts can cut along the full length of their exposed edges, not just at the point. Finish cuts in the second stage. There was no need to part-off with another tool - I just cut into the bore. By the magic of Gimp, two photographs of the finished item merged for top and bottom views: Other comments: Cutting the inner bevel was easy enough but I did need to use a boring bar to get clearance. With a silver aluminium insert there was no repeat of the chatter I got with an ordinary gold insert. At no time did I see signs of distress as the bevel got thinner. A disadvantage is the potential loss of accuracy due to having to position the tool with the Carriage Wheel. This has much coarser travel than the fine verniers on the top and cross-slides. Despite that I got to 0.63mm on a target of 0.6mm. It does make getting an accurate result slightly awkward though. Thanks to Chris for providing a 'not too much work' diversion from domestic duties. I should be recycling junk and washing floors... Dave
Edited By SillyOldDuffer on 05/02/2019 14:16:50 |
Emgee | 05/02/2019 14:19:38 |
1022 forum posts 191 photos | That's much better Dave looks about the same as the picture, well done. Emgee |
