geoff adams | 03/02/2019 14:46:25 |
190 forum posts 196 photos | any of you guys help i want convert this cnc lathe to mach3 or something similar i know nothing about electronics the cad cam is driving me mad i can programme quicker by hand could you recommend a firm or someone that can do this for me iam in the Bournemouth area Thanks Geoff |
John Haine | 03/02/2019 14:59:37 |
3529 forum posts 194 photos | These people seem to do CNC conversions, though up in Leicestershire. Why Mach 3? It's old fashioned and no longer supported. I have used it for quite a while on my lathe but will need to change soon. Compatibility with PCs and Windows depends on the goodwill of what is probably a dwindling user base finding fixes. Alternatives are LinuxnCNC, Mach 4, or a number of others have been mentioned here, but it may depend on how much of the current machine you want to keep. |
geoff adams | 03/02/2019 16:29:10 |
190 forum posts 196 photos | thanks for the link looks good will ring them tomorrow only reason for mach3 is my two mills syili x4 and tormach 1100 run on mach3 which i know i also have a sieg lathe with a fanuc based control thanks Geoff |
John Alexander Stewart | 03/02/2019 17:14:58 |
792 forum posts 52 photos | Geoff; 1) There's a fellow who posts here sometimes (can't remember his name at the moment) who had figured out how to drive a parallel-port equipped Emco CNC lathe from LinuxCNC. He and his father got a batch of them. 2) A local club member took his Emco Compact-5 CNC lathe and LinuxCNC'd it, including tool changer. Works very well, when he gets the chance to use it. (young family syndrome) 3) If you have a Tormach 1100, you'll know that the PathPilot upgrade (*) is LinuxCNC with a Tormach UI and conversational programming layer. (I put a star on "upgrade" as I know we all have our own preferences, and some people have difficulty with anything other than Windows on a computer). Tormach dropped Mach in favour of LinuxCNC for a reason. 4) I CNC-converted a Unimat SL lathe, which I gave to a club member, and have recently picked up a Sherline lathe, CNC controller is my old LinuxCNC one from my Unimat-SL. Sherline's CNC controller is LinuxCNC, so that's another company who chose LinuxCNC for their products. I'm a LinuxCNC advocate, as, not only is the price right, it just works 100% of the time for me, on 3 machines. I have converted to the "GMOCAPY" UI, which I like more than the standard UI. Again, there's lots of choice out there; every solution has good points and bad points. |
geoff adams | 03/02/2019 17:16:17 |
190 forum posts 196 photos | John some photos of the machine had it for about ayear never used it the cad cam is a nightmare get fed up and use my other machine the fellow i got form got it as an ex demo dont thick it has ever cut anything want to kep as much of the machine as possible as it all looks as new Geoff |
The Novice Engineer | 03/02/2019 20:56:49 |
79 forum posts 59 photos | Hi, I've converted an Emco Turn 50 to run of Mach3 a while back, ripped out all the Emco controls but kept the original Main Drive motor and stepper motor's. I used a Generic Chinese [E-bay] parallel port interface controller card, Vertex 5 phase stepper drives, and a Omron VFD . It was mostly re-wiring rather than building new electronics. I run off a Windows XP pc the Operating System has been stripped down to the essentials and NEVER connect it to a network or the Internet. [Mach 3 control via the Parallel Port only works under XP or 2000. Windows 7 and above should use a USB interface card] The Main drive is under manual control as is the Tool changer, Mach 3 looks after the X and Z axis. So far this has done every thing I have asked of it, including taper turning, threading .... the awkward stuff ...etc.!!! I use Fusion 360 for the CAD - CAM, and the Mach3 Wizards for simple stuff. Steve |
The Novice Engineer | 28/02/2019 22:13:01 |
79 forum posts 59 photos | Here are some photos of my Emco PC Turn 50 cabinet with the rewired power side , the Rack mounted PC and 5 axis controller, the Drive motor VFD and the Vertex 5 Phase stepper drivers. I had been using this as test bed for trying out ideas before modifying a Emco PC 50 Mill, The lathe retains the original Emco 5 phase stepper drive motors and the 3 phase main drive.
The Power supply at the front is for powering the PC [a Mini ITX dual core running XP off an SSD ..very quick] it also powers the Mach 3 control card, and recently the Tachometer RPM meter The terminal block is a power take off for testing the RPM Tachometer of the Main drive. Steve Edited By The Novice Engineer on 28/02/2019 22:13:56 Edited By The Novice Engineer on 28/02/2019 22:18:50 |
The Novice Engineer | 01/03/2019 20:57:10 |
Update: A bit of a senior moment dyslexia with the spelling of the drives I used! The 5 phase drivers are by VEXTA , to use these the Emco Berger-Lahr stepper motors have to be re-wired internally about a 5 minute job changing links around. The Vexta pentagon drivers have five output terminals; each one connects to two motor cable conductors I've added the information about how I did my modification to this thread as the title may draw folk in who are looking to do a modification. Steve Edited By The Novice Engineer on 01/03/2019 21:00:18 |
terry callaghan | 02/03/2019 15:44:06 |
213 forum posts 8 photos | Mach3 is just running software, what makes or breaks the system is the breakout board. after years of fulling around with cheap rubbish from china and old PC,s running with printer ports I went for the CS=LABS CSMIO motion control unit which uses the lang port. great bit of kit and works right out of the box. I use the units on my large router and a Denford engraving machine I converted. all work with mach3 and windows 10. mach4 is too full of bugs at the moment, so happy with the software I have.michael |
Andreas Chronz | 25/03/2019 09:31:19 |
1 forum posts | Hello! I`am Andy from Germany and a friend of me bought a PC Turn 55 too. But he had also Problems with the original Fanuc Control and want to Keep them out and replace it with another control (i`am looking for Mach3 too). Anybody knows which mainspindle Motor the machine has? (Didnt find a Information sign on it). And how epensive are These vexta Drivers? Kind regards Andy |
John Haine | 25/03/2019 10:16:34 |
3529 forum posts 194 photos | I use Mach 3 on my self-converted Super 7 and Denford Novamill and have been doing so for some years with success. I've got quite a lot invested in it in terms of macros for tool setting and modified screen sets. BUT, if you are looking at converting a machine NOW, why would you want to use a controller like Mach 3 which is no longer supported by its supplier and you are dependent on fixes developed by the use community, for example to cope with problems created by upgrades to Windows? That user community will itself decline as they move to modern supported systems. It must be better to use Mach 4 or a different controller such as LinuxCNC or UCCNC. |
David Colwill | 25/03/2019 10:17:00 |
703 forum posts 38 photos | I run Mach 3 on 2 milling machines and a Denford Easiturn lathe. They all work fine for what I do but I am still thinking of going to the dark side (linux) and have bought a Denford Orac as a test bed machine. If I get on with it I will probably switch over on everything. The main reason is threading. While the easiturn is big enough to manage this on short threads it loses sync over 40mm or so. This is going to be much more of a problem on a smaller lathe like the PC Turn. I have always meant to try linux but have never got round to it so now hopefully I soon will. Regards. David. |
David Colwill | 25/03/2019 10:22:24 |
703 forum posts 38 photos | Posted by John Haine on 25/03/2019 10:16:34:
It must be better to use Mach 4 or a different controller such as LinuxCNC or UCCNC. I wish UCCNC would go more lathe friendly I use a UC300 at the moment on the lathe running mach 3. I have emailed them several times regarding spindle sync (it works on the mill version for tapping) but they always reply that there is no interest in lathes etc. I haven't tried the software though. Regards. David |
John Alexander Stewart | 25/03/2019 10:23:56 |
792 forum posts 52 photos | David beat me to it - threading. LinuxCNC works well, and blows Mach3 out of the water, from what I hear. The reason seems to be that LinuxCNC uses two spindle sensors - one to mark 0.00 degrees, and the other divides the spindle rotation by "lots". Mach3 only has the 0.00 degrees and interpolates the spindle rotation from that. I use "Mesa" boards, which seem to be inexpensive compared to Mach hardware. The whole stuff just works. Note: John Stevenson (miss that guy) and I used to "argue" - he liked Mach3, I like LinuxCNC, so my comments above regarding Mach3 are from discussions with Mr. Stevenson, not my personal experience.
Emgee | 25/03/2019 10:32:02 |
1822 forum posts 239 photos | Posted by David Colwill on 25/03/2019 10:17:00:
I run Mach 3 on 2 milling machines and a Denford Easiturn lathe. They all work fine for what I do but I am still thinking of going to the dark side (linux) and have bought a Denford Orac as a test bed machine. If I get on with it I will probably switch over on everything. The main reason is threading. While the easiturn is big enough to manage this on short threads it loses sync over 40mm or so. This is going to be much more of a problem on a smaller lathe like the PC Turn. I have always meant to try linux but have never got round to it so now hopefully I soon will. Regards. David. Please keep us posted on any upgrade, I am still using an Orac with OEM controls. Emgee |
blowlamp | 25/03/2019 11:16:27 |
![]() 1473 forum posts 97 photos | If you want true spindle-synchronised lathe threading, there are three reasonably priced options that I know of. 1/ LinuxCNC. 2/ Centroid Atom. 3/ PlanetCNC TNG.
Martin. |
Elmouatez Billeh KEBIR | 20/04/2020 16:39:20 |
1 forum posts | Hello. |
The Novice Engineer | 21/04/2020 22:22:04 |
79 forum posts 59 photos | The Tool change motor is 24v DC, The small control board for it will apply 12v to reverse the motor to locate the toolholder in position against a pawl/ratchet, The 12v is maintained continuously to hold the tool in position. The motor housing has a large heat sink it does get warm but not hot. Trust this helps Steve |
Martin Connelly | 22/04/2020 09:24:00 |
![]() 1606 forum posts 176 photos | David, Mach3 threading works fine on the right lathe. What it needs, because of the one pulse per rev synch, is a lathe with plenty of rotating mass and a powerful motor to give unvarying speed as the cutting progresses. Basically it will be more problematic on a dc motored mini lathe than a machine with a big 3 phase motor and a transmission, spindle and chuck that probably weighs as much as a mini lathe. You need the same rpm as the cut is ending as before cutting starts, and this needs to be true every pass. Martin C |
