Forum sponsored by Allendale Dec 6th
3D Printing using Flexible Filament
Practical advice and experience of using Flexible filament
The Novice Engineer31/01/2019 23:08:17
49 forum posts
22 photos
I'm looking at making some Lens covers [ for Camera and Telescope Lenses ] has anyone got any advice and experience of using Flexible filament.
Here is an example of the type of cap
Any recommendations on manufacturers of good [ and duff] filaments would also be welcome
My 3D printer is a Leapfrog Creatr.
Thanks
Steve
Andy Carruthers31/01/2019 23:24:19
262 forum posts
23 photos
I am having problems with FFF world FlexiSMART, very soft filament which requires modification to the extruder (on my ToDo list) to reduce the pinch wheel gear diameter to provide better grip
Try TPU and see how you get on
Gary Wooding01/02/2019 08:01:37
595 forum posts
141 photos
I've successfully used NinjaFlex in our Ultimaker.
Neil Wyatt01/02/2019 14:33:47
16740 forum posts
689 photos
76 articles
I've used 'no-name' flexible PLA with success.
Using a Mk. 8 extruder the 'secret' is to fit a filler block with a hole in it to bridge the gap between the pinch roller and the top of the heatbrake tube.
A benefit of such a block is that it allows you to change filaments by pushing the old filament out with the new instead of having to clear the nozzle.
The Novice Engineer05/02/2019 22:41:51
49 forum posts
22 photos
UPDATE
I found the information here from Madhackers very useful
https://www.matterhackers.com/news/how-to-succeed-when-printing-with-flexible-filament
or use this **LINK**
I bought some Priline TPU filament from Amazon and spent a few hours finding the best setting printing a variety of 20mm cubes.
The the standard Leapfrog Creatr feed mechanism seems to be able to feed the flexible filament OK so far.
I created a profile for the Filament that had a higher temp than PLA [240 C] and increased the Extrusion multiplier to 1.15.
The setting for the Print profile was created using a much lower speed setting , Max speed 30mm/sec down to 10 mm/sec.
There is probably scope for tweeking as I print different projects.
Steve
Tee London LMES 6th Dec
