Sealing water tanks
Stewart Hart23/01/2019 07:45:01
623 forum posts
329 photos
I'm trying to build a water tender tank and I'm having problems getting it water tight by just using soft solder. Is there a sealant I could use to do the job I understand that some people have used petrol tank sealant can any one point me in the direction of a supplier.
Cheers
Stew
JasonB23/01/2019 08:07:00
17315 forum posts
1865 photos
"POR 15" gets mentioned quite a bit on the traction engine forum but not tried it myself, it's meant for fuel tanks. Link
Edited By JasonB on 23/01/2019 08:10:37
Brian Baker 123/01/2019 08:19:43
103 forum posts
20 photos
Greetings,
I have used marine grade epoxy with great success, but the tank needs to be clean, I use a rotary wire brush.
I have used it on 71/4 gauge ride on tenders, with no problems.
Marine epoxy is a bit more runny than araldite, but needs 20 to 25 degrees to set properly.
It can be stiffened with various additives, if you need a paste, and from your local yacht chandlers you should be able to get the "West system", which is the most well known supplier.
It will seal over the solder, and during its working life remains a little flexible.
Simon Collier23/01/2019 08:42:37
320 forum posts
55 photos
I had the same problem and research pointed to fuel tank sealant kit. I bought it but have not yet done the job.
Mark P.23/01/2019 08:50:29
611 forum posts
6 photos
I've had good results with automotive panel sealant, apply with a brush.
Mark P.
Scrumpy23/01/2019 09:03:40
148 forum posts
I have used Por 15 on all my engines as Jason posted it works well it’s been used from 2 in scale to 4 1/2 highly recommend
Paul Lousick23/01/2019 09:15:50
1321 forum posts
526 photos
Bitumen based, paint-on sealant is available from hardware stores. It remains slightly flexible and is a traditional way of sealing water tanks and shower floors. (not for drinking water).
JasonB23/01/2019 09:18:48
17315 forum posts
1865 photos
A lot will depend on what access Stew has to his tender, if just a small hole it will be hard to brush anything on, with the POR and epoxy you just pour some in swill it about and then drain the waste.
Stewart Hart23/01/2019 10:40:37
623 forum posts
329 photos
Posted by JasonB on 23/01/2019 09:18:48:
Thanks for you help full replies chaps, I've left the top of the tank off so that I can get at the inside getting the top sealed is less important than the bottom
Stew
Paul Lousick23/01/2019 11:37:29
1321 forum posts
526 photos
The tanks on most original engines have a removable cover on the side of the tender which allows access for inspection. The cover should be removed to allow the tank to be completely dried when storing the engine to prevent rust.
I am building a tender for my model engine at the moment and have also added a removable cover on the top panel (under the coal bunker) for just this reason, so I can coat the inside with sealant.
Paul.
