Forum sponsored by Allendale Nov 29
Material hardness in raw state
Brian Abbott18/01/2019 10:03:47
375 forum posts
61 photos
Hi all.
A little off topic but does anyone know a material which in its raw supplied state is around the 52 - 54 Rc mark ?
Thanks in advance.
Michael Gilligan18/01/2019 10:22:46
12766 forum posts
553 photos
According to this page, Brian: **LINK**
https://www.offgridweb.com/preparation/understanding-steel-the-rockwell-hardness-scale/
'420' Steel is in your Goldilocks Zone
Andrew Johnston18/01/2019 13:08:07
4496 forum posts
520 photos
Plenty of carbon, alloy and stainless steels can meet the requirement after hardening and tempering, but I'm not aware of any sold in a prehardened state. Those that are, like EN16T and EN24T aren't hard enough. There may be some ceramics that meet the requirements, but I haven't looked.
JasonB18/01/2019 13:24:29
15019 forum posts
1530 photos
What form do you need the material in? Piano wire is only just below that and easily available in small diameters.
HOWARDT18/01/2019 15:17:30
388 forum posts
14 photos
Any flame hardening steel will achieve this to some depth, or do you require a through hardened steel. In which case look at the tool steels used for mould making. If its commercial Carrs Steel over Birmingham way are very good at giving you a good selection so long as you can furnish them with correct answers to the questions.
Brian Abbott18/01/2019 20:06:29
375 forum posts
61 photos
Thanks guys for taking the time to repy.
It was something for work, i needed some 25mm thick plate, customer calls for it to be hardened to 52-54, just had something in the back of my mind that there was something available, otherwise i need to heat treat which risks bending the plates.
Not to worry, thanks anyway..
Michael Gilligan18/01/2019 20:15:42
12766 forum posts
553 photos
Posted by Brian Abbott on 18/01/2019 20:06:29:
dont know ... Just curious, Brian ... Was my reference to 420 irrelevant to your requirement ?
A little more detail here:
https://springsteelstock.co.uk/stainless-spring-steel/420-stainless-steel/
Edited By Michael Gilligan on 18/01/2019 20:22:05
David George 118/01/2019 20:20:12
716 forum posts
257 photos
Hi Brian what is it for and what sizes do you need. I have a few different steels
CMS 420 x 35mm dia. P20 x25mm dia. And D2 x 20mm dia.
If any are suitable let me know.
David
Andrew Johnston18/01/2019 20:33:31
4496 forum posts
520 photos
It was something for work, i needed some 25mm thick plate..........
Seems pretty clear to me?
colin brannigan18/01/2019 21:21:20
47 forum posts
I have used TOOLOX 33 and 44, if I remember rightly that came in at around 420, was used for swaging dies in presses.
Colin
John Reese18/01/2019 23:56:03
701 forum posts
In the US we have AR500. It is an abrasion resisting plate with a Brinell hardness around 500. Nasty stuff to machine.
TRANSWAVE Converters
