Forum sponsored by Allendale Nov 29
Milling a T slot ??
Garry Coles16/01/2019 08:32:17
28 forum posts
Hi, I am currently building the D & NY 2" scale Traction Engine.
I am working on the rear axle brackets and need to mill the area where the axle block moves up and down. This is like a T slot. The area to be machined is 1 1/4" wide x 1" high and 2" long. The lip each side that makes it a T slot over hangs by 1/8" each side. (Hope this makes sense) My question is can I use a T slot cutter to machine this. Or is there another way.
Thanks
Garry
JohnF16/01/2019 09:28:39
758 forum posts
85 photos
Good morning Garry, I am not familiar with traction engines but from your description of the component a T slot cutter is the way to go. Just make sure the cutter , shank relationship is enough to to cut the depth you need, most will be for sure.
Garry Coles16/01/2019 09:38:00
28 forum posts
Hi John,Thanks for the reply. I think I be using a T slot, I just wanted to know if this was the right way to go, or if there was another way of doing this.
Garry
David Standing 116/01/2019 09:40:32
1191 forum posts
45 photos
Also make sure you use a T slot cutter, not a Woodruff cutter.
JasonB16/01/2019 09:47:33
15019 forum posts
1530 photos
Short of using a slotting head or built up construction the tee slot cutter would be the way to go, mill out all you can with a standard cutter and just use the tee slot one for the inder cut.
Also make sure that the diameter of the head is at least 1/4" larger than the shank, some small tee slot cutters just have a neck for shallow clearance then a large shank.
Garry Coles16/01/2019 10:04:58
28 forum posts
Thanks Jason, am now looking on the web for a cutter.
TRANSWAVE Converters
