Forum sponsored by Allendale Nov 29
WM250VF Loose Saddle
John Slaven15/01/2019 21:46:57
23 forum posts
13 photos
Hi All,
My WM250 seems to have a very loose saddle. I can see no obvious gib adjustments. Is there some other adjustment for the saddle that I have missed? Any help would be much appreciated.
Cheers the noo
John.
mechman4816/01/2019 11:12:09
2299 forum posts
387 photos
I have a 250V-F too... this happened to me, have a look at the back of the saddle, under the shear, you should find a metal 'gib strip' held on by bolts these may well be loose, give them a snug up , it should fix the problem.
George.
Howard Lewis16/01/2019 11:14:49
1819 forum posts
2 photos
If there are no obvious gib strip adjusters along the side, there may be a large screwdriver slotted item on the end, under the handwheel. This will drive a wedge onto the gib to take out slack. They do work loose and increase slack and so need resetting from time to time..
mechman4816/01/2019 11:17:45
2299 forum posts
387 photos
Just had a look at my manual, the item I mentioned is part # 63 on the carriage assembly page.
George.
John Slaven16/01/2019 11:18:49
23 forum posts
13 photos
Hi George and Howard,
Thanks for the reply. I'll have a look this afternoon. The saddle is pretty loose and parting off is near impossible.
Cheers the noo
John.
mechman4816/01/2019 12:48:09
2299 forum posts
387 photos
Just on the off chance check the 4 SHSC that fasten the cross slide to the saddle gear box, they may have also worked loose enough to give it slight lift...?
George.
John Slaven16/01/2019 15:54:08
23 forum posts
13 photos
Hi All,
Thanks for the replies. George, you were right. The 4 allen bolts at the back of the saddle were loose. Gave them a snug up and the saddle feels a lot better. I can now part with confidence!
Cheers the noo
John.
mechman4816/01/2019 23:16:21
2299 forum posts
387 photos
thumbs up
Geo.
Ausee.com.au
TRANSWAVE Converters
