Steam pipework SWG
SomersetSimplex15/01/2019 09:23:40
8 forum posts
I’m tidying up the pipework on a Simplex, most of which is 3/16”. What SWG should I use / is there a minimum recommended? The supplier I’m intending using lists 16, 20 & 22 SWG.
GAVIN
JasonB15/01/2019 09:28:05
17813 forum posts
1948 photos
May want to take a look at this recent thread on the subject
Former Member15/01/2019 10:15:07
SomersetSimplex15/01/2019 13:43:33
8 forum posts
Thanks Jason. I tried searching SWG and a couple of other terms, but obvoiusly not the correct ones.
SomersetSimplex04/06/2019 22:49:33
8 forum posts
Just following up on this, is there any reason not to use annealed copper pipe- it is cheaper than the straight lengths and comes in a coil so longer single lengths?
Ian S C05/06/2019 12:50:12
7468 forum posts
230 photos
It's easier to use straight lengths, and bend them, rather than trying to get the coiled tube straight, curves where it should be straight look awful, you would find out about pipe work if you modeled an NZR locomotive, all the pipe work exposed all over the boiler.
Ian S C
Edited By Ian S C on 05/06/2019 13:27:53
duncan webster05/06/2019 19:00:07
2531 forum posts
49 photos
Gavin
I've got a load of brand new copper pipe I'm trying to sell on behalf of a model engineer who has had to give up due to ill health. It will be a lot cheaper than retail. If you're interested, send me your email address by pm and I will send you a list
