Sharing information about model turbines
Turbine Guy | 10/05/2022 13:57:14 |
437 forum posts 366 photos | I figured out a method to account for the compression of the nylon housing when tightening the nuts that hold the cover on and was able to get the rotor in the position shown in the drawing of the 03/05/2022 Post. This position gave me the best performance again. I moved the position of the rotor in tiny increments until I reached the minimum pressure of 18 psig required to turn the GWS EP 2508 propeller to a speed of 28,000 rpm. The required pressure changed from 20.5 psig to 18.0 psig in a total movement of 0.012” and from 19.0 psig to 18.0 psig in the final 0.002” move. This is much too sensitive for being due to space required for the gas to go supersonic since it is almost sonic with the 18.0 psig inlet pressure. This small distance from the face of rotor to the face of the cover probably affects the windage loss the most. Most of my sources say to close the gap between the faces of the rotor to the faces of the cover and housing to the minimum possible. The following test sheet is updated to show the latest test results of Axial Turbine 3N R2. Several runs were made with the 18 psig inlet pressure and the maximum speed was always approximately 28,000 rpm. |
Turbine Guy | 21/05/2022 20:10:54 |
437 forum posts 366 photos | I added a sleeve in Housing 3 so that I could use the dental ball bearings in Drag Turbine 6B R1 as shown in the following drawing. After adding the sleeve, I added one dental ball bearings to Drag Rotor 6 without any shims to see if it could slide all the way down the shaft until it contacted the rotor. The dental ball bearing had a slight resistance the last bit of travel like expected, but when I tried to pull it back off the shaft, I could not grip the ball bearing tight enough to move it. Without any shims, the face of the ball bearing was tight against the face of the rotor boss so not even a sharp blade could get in between to pry them apart. I finally had to press the rotor off the shaft and then press the ball bearing off the shaft. After adding Loctite and pressing the rotor back on the shaft, and shimming the rotor to the correct position, I tried my first test. The maximum speed was way below what I obtained with the original all metal ball bearings so I must have damaged the dental ball bearing when I tried pulling it off. I ordered some new dental ball bearings and will start testing the Drag Turbines when I receive them. Edited By Turbine Guy on 21/05/2022 20:12:51 |
Turbine Guy | 22/05/2022 18:46:02 |
437 forum posts 366 photos | To solve the problem of gripping the dental ball bearing mentioned in the last post, I turned down the diameter of the boss on Drag Rotor 2 to 0.180”. This is the approximate OD of the shims and is below the ID of the outer race of the dental ball bearings. The assembly drawing for Drag Turbine 4 R1 shown below shows this change and the added sleeve and dental ball bearings. |
Jon Lawes | 23/05/2022 06:47:49 |
![]() 926 forum posts | Interesting. I wonder at what speed those dental drill ball bearings give up! |
John P | 23/05/2022 09:22:29 |
406 forum posts 257 photos | This may be of some interest for making a high speed machine spindle. https://link.springer.com/article/10.1007/s40684-019-00105-5#Fig7 John |
Michael Gilligan | 23/05/2022 09:31:19 |
![]() 20182 forum posts 1053 photos | Many thanks for that link, John P I have downloaded the paper to read whilst I am waiting for my appointment with the dentist this morning. MichaelG. |
John P | 23/05/2022 09:48:34 |
406 forum posts 257 photos | Michael This looks about the same size as the one in the springer link .
Michael Gilligan | 23/05/2022 10:52:09 |
![]() 20182 forum posts 1053 photos | That’s probably what it will feel like, John 50 min appointment, preparing for a Crown MichaelG. |
Jon Lawes | 23/05/2022 12:23:14 |
![]() 926 forum posts | Posted by Michael Gilligan on 23/05/2022 10:52:09:
We have gone decimal now and the prices have gone up a fair bit. |
Turbine Guy | 23/05/2022 13:20:16 |
437 forum posts 366 photos | Thanks for the feedback. I damaged the dental ball bearing by trying to pull it off the rotor shaft by gripping it around its OD. I was in a hurry to try another test and when I couldn’t remove the bearing gripping it with my hands, I tried gripping it with pliers. This was what damaged the dental ball bearing. The dental ball bearing shown below has worked extremely well for my tiny turbines running on air. Jon Lawes John P |
Turbine Guy | 23/05/2022 13:20:22 |
Michael Gilligan | 23/05/2022 13:50:54 |
![]() 20182 forum posts 1053 photos | Posted by Jon Lawes on 23/05/2022 12:23:14: . We have gone decimal now and the prices have gone up a fair bit. . Yes, this one will be £235 … just creeping above the old ‘tooth hurty’ joke MichaelG. Edited By Michael Gilligan on 23/05/2022 13:52:58 |
Turbine Guy | 26/05/2022 15:24:30 |
437 forum posts 366 photos | I received the new dental ball bearings and tried them in each of my turbines that could use this size. All of the impulse turbines repeated the performance last shown in the 10/05/2022 post within 0.5 psi. My drag turbines performed worse than expected. This was the first time I tried the dental ball bearings in the drag turbines, and I found that the sleeve I added had an ID larger than the sleeves in the impulse turbines. I did all the sleeves the same way, so something must have slipped when I did the sleeve for the drag turbine housing. The oversize ID lets the ball bearings tilt enough to open the gap between the rotor face and the cover and allow too much leakage. I will make a new sleeve for the drag turbine housing and then try testing again. |
Turbine Guy | 30/05/2022 13:37:58 |
437 forum posts 366 photos | I made a new sleeve for the drag turbine housing and started testing of Drag Turbine 4. I checked the bore of the new sleeve with a dowel pin that has a tolerance of +0.0000”/-0.0002”. The dowel pin required a light force to move into the sleeve without any apparent play. This is probably as close a tolerance as I can get on the sleeve bore and unfortunately the rotor still could tilt slightly in the bearings. I don’t know what the tolerances are on the dental ball bearings, but they appear to have a larger tolerance than the ball bearings I was using for the previous tests of the drag turbines. When I was adding and removing shims to find the optimum shim thickness, something occurred that I can’t understand. Because the maximum rotor speed was very low for each of the rotor positions I tried, I blocked the flow out of the exhaust port while the turbine was running to check for leakage. I expected the turbine to start slowing down and the pressure to go up if there was no leakage. Instead, the turbine speed went up. The maximum speed with the exhaust port open was 16,000 rpm and with the exhaust port blocked the maximum speed was 20,000 rpm. I haven’t been able to find a logical reason for the speed going up when the exhaust port is blocked and would appreciate any ideas of how this can happen. The following drawing shows the construction of Drag Turbine 4 and the only way for the air to escape with the exhaust port blocked is through a 0.032” diameter vent hole not shown in the drawing or through the ball bearings. The vent hole is in front of the ball bearing closest to the rotor and is intended to vent any gas that gets behind the rotor to keep it from entering the ball bearings. |
Turbine Guy | 03/06/2022 15:56:13 |
437 forum posts 366 photos | My theory for why Drag Turbine 4 ran faster with the exhaust blocked than with the exhaust open is as follows. The gap between rotor faces and the housing or cover is very small (less than 0.002&rdquo I pressed the sleeve out of the drag turbine housing and tried the larger all metal ball bearings I had been using. With the rotors in the same position used in the last tests with these ball bearings, the results for Drag Turbine 4 and Drag Turbine 6B were almost identical to those shown in the table of the 10/05/2022 post. |
Turbine Guy | 13/06/2022 12:48:58 |
437 forum posts 366 photos | I might try getting some of the lubricant that is used in the dental handpieces for the bearings that are relubricated daily and see how that works for the metal ball bearings I am currently using in the drag turbines. Since these lubricants are designed for the very high speed dental turbines, they may not have the high viscosity at the low temperature caused by the expansion of air in the nozzles. Also, since they are designed to last for an entire day of running the dental drills, the lubricants may adhere to the metal longer. I’ll check the availability and cost of these lubricants and order some if the cost is reasonable. This is all I plan to do with the drag turbines for now. I plan to add a side plate on Axial Turbine 3A next to the inner face of Rotor 5 as shown in the following drawing. The dimensions for the clearances between the rotor and the cover, the rotor and the side plate, and the distance (x) are what I plan to try. These may change after I find the optimum position of the rotor with the side plate added. The intent of adding the side plate is to reduce the rotational (windage) loss by having a close fit on both sides of the rotor based on what I found for the test described in the 10/05/2022 Post. |
Turbine Guy | 22/06/2022 15:06:06 |
437 forum posts 366 photos | I made the side plate and positioned it as shown in the following photo and drawing. I got the best performance with a gap of 0.006” between the set screw collar and the outer ball bearing. The GWS EP 2508 propeller used in the tests pushes the rotor toward the cover plate until this gap is closed. That results in a clearance between the cover and the rotor of 0.005” and between the rotor and the side plate of 0.009”. In all my testing with the dental ball bearings, they have worked best with around 0.004” to 0.006” of clearance between the set screw collar and the outer ball bearing. With these gaps the minimum pressure required to turn the propeller at 28,000 rpm was 19.5 psig, the same as without the side plate. I tried changing the clearance on both sides, opening or closing the clearance in small increments from 0.002” to 0.012”. but no combination performed better. The side plate removed the open space the air leaving the rotor had available to flow into and forced the air into a much smaller channel. This may have offset any gain in performance the tight clearances on each side of the rotor might have given. Axial Turbine 3A is the version without a shroud or tight clearance on the rotor OD, so the flow escaping the blade ends might have increased with the smaller exhaust space.
noel shelley | 22/06/2022 19:41:43 |
1344 forum posts 21 photos | It goes faster when the exhaust iblocked could be that the bearings have become Air Bearings ? Noel |
