Forum sponsored by Allendale Nov 29
Making small Wheels
Making small Wheels
Adrian Harrison07/01/2019 04:01:01
38 forum posts
11 photos
I have a small RC Model that I would like to make some aluminum wheels for..
the original plastic wheels have a 2mm hole in the middle that has a flat spot so its a D shape for mounting and taking the drive..
what would be the best way to make this D shaped hole?
Paul Lousick07/01/2019 05:17:04
1004 forum posts
468 photos
A photo would be helpful, otherwise you will get lots of replies that would not be suitable for your application.
not done it yet07/01/2019 05:44:07
2708 forum posts
11 photos
Most small metal pulleys (probably mostly larger than this) simply use a grub screw through the wheel flange to bear on the flat. Think here meccano to about 75mm diameter low power motor pulleys. Wheels are about the same sort of thing as pulleys?
Nicholas Farr07/01/2019 05:49:59
1766 forum posts
879 photos
Hi Adrian, a couple of ways shown in this tread, **LINK** but it will be a bit fiddley at 2mm.
Regards Nick.
Adrian Harrison07/01/2019 05:56:14
38 forum posts
11 photos
Adrian Harrison07/01/2019 05:58:08
38 forum posts
11 photos
Posted by Nicholas Farr on 07/01/2019 05:49:59:
Regards Nick.
Thanks Nick I will look at the link now
JasonB07/01/2019 07:02:12
15010 forum posts
1528 photos
Make a small broach and drive that through an undersize hole
Nicholas Farr07/01/2019 07:25:06
1766 forum posts
879 photos
Hi Jason, I like that idea. thumbs up
Regards Nick.
Edited By Nicholas Farr on 07/01/2019 07:25:50
Mick B107/01/2019 09:18:24
956 forum posts
56 photos
Posted by JasonB on 07/01/2019 07:02:12:
When I've thunk that thought in the past, I've doubted that it would work because of the asymmetric side-forces on the broach messing up the concentricity.
From the pics of your swarf, it looks as if it works pretty well. Thanks, I'll file that for future ref! smiley
JasonB07/01/2019 09:27:42
15010 forum posts
1528 photos
Mick, it did wander off slightly so best to do the broaching first and mount on an arbor to complete.
Having said that it was only a quickly knocked up broach to see if it would work and I just squeezed it in with the bench vice, a better made one and some care ensuring it is true when pressed would give better results. It came out so well I did not bother with a better version just use the test piece.
David Jupp07/01/2019 09:53:25
649 forum posts
16 photos
If mounted on a steel axle, an aluminium wheel will be prone to fretting if there is even the slightest relative movement possible. I think I'd be tempted to also use a drop of Loctite (or similar) to prevent that.
Adrian Harrison08/01/2019 02:14:16
38 forum posts
11 photos
Posted by David Jupp on 07/01/2019 09:53:25:
I seam what you mean and yes that would be a good idea
Adrian Harrison08/01/2019 02:16:58
38 forum posts
11 photos
I can see that working seeing as i would be driving the broach into aluminum.. thank you for sharing the idea
Jeff Dayman08/01/2019 04:06:40
1438 forum posts
37 photos
Another possible way to do a driving flat in pic below.
EDM is another option if you know someone with a machine, or if you know a mouldmaker.
Adrian Harrison08/01/2019 05:51:57
38 forum posts
11 photos
Posted by Jeff Dayman on 08/01/2019 04:06:40:
That is also a good idea.. I think i could use a washer behind the wheel to keep the insert from falling out
JasonB08/01/2019 07:02:42
15010 forum posts
1528 photos
Jeff where do you get those 0.15mm diameter screws from as the axle on the "toy" car is only 2.0mm diasmile p
Even if you could do it that way it would spoil the Bling effect of the alloy wheels.
JasonB08/01/2019 08:03:48
15010 forum posts
1528 photos
Another option may be to just put a 2mm hole right through then cross drill 1.6mm to meet the 2mm hole. Part tap that M2 and then make a small steel screw with 1.6mm plain end and M2 thread with a screwdriver slot in the end.
Slip the wheel onto the stub axle, start the screw then put a small amount of Loctite onto the thread before screwing in until it just nips the flat of the axle. once the Loctite has dried you can slide the wheel on and off as needed with a fitted tyre, pin will stop it rotating.
Adrian Harrison09/01/2019 06:14:18
38 forum posts
11 photos
That's also a good idea and probably the easiest to accomplish I should think
Neil Wyatt10/01/2019 18:47:44
15681 forum posts
659 photos
73 articles
Another way might be to drill an offset hole for a small peg using an end mill, if made a close push fit should be enough to prevent rotation.
TRANSWAVE Converters
