Help with Cowells 90 Lathe wiring diagram
Chris Noton06/01/2019 14:24:25
6 forum posts
Could any of you experts out there help me please?
I have a Cowells 90 Lathe. It is on a blue cast base with the single forward and reverse switch. It has a GEC electric motor.
The problem is the motor is getting extremely hot in a short period of time although it does go in forward and reverse. The motor was examined by a specialist and they found that the starter windings were burnt out and they re-wound it for me. I have just re-fitted the motor but it is doing the same thing again and getting very hot in a short period of time.
Has anyone got any ideas what the problem could be? And also, has anyone got a wiring diagram or perhaps a replacement electric motor?
I'd be very grateful for your assistance. Chris.
Phil Whitley06/01/2019 14:42:40
1316 forum posts
147 photos
sounds like the centrifugal switch is not opening (if it has one), if it gets too hot to bear your hand on, stop using itbecause there IS a problem
Former Member06/01/2019 16:56:48
1329 forum posts
Chris Noton06/01/2019 17:44:02
6 forum posts
Dear Phil. Thanks very much for your information. Yes I did it off straight away - as they say there's no smoke without fire. I will check and see if the motor has a centrifugal switch. Best wishes, Chris.
Dear Bill. I did speak to Cowells but they said they haven't got the wiring diagram for the older models. They did tell me that the GEC motor does get hot but not so quickly as mine does. Hopefully someone out there has got the wiring diagram or if they have got a similar Cowells me as mine they would be kind enough to send me a picture of the wiring under the plate. The trouble is that on the older lathes you don't know in the past if someone has reconnected the wires incorrectly. Thanks again, Chris.
Former Member06/01/2019 18:57:00
1329 forum posts
Chris Noton13/01/2019 16:11:54
6 forum posts
Hi, I just wanted to thank all the replies I had regarding the overheating of the motor on my Cowells 90 lathe. I tracked it down with a problem with the relay, now its running fine. Also I would like to personally thank Malcolm at Penny Farthinng Tools.. Although I never purchased the lathe from them he was of great assistance and couldn't of been any more helpful. Also thanks to brothers EMR Swindon who sorted the motor for me.There are some great companies out there. Thanks again to you all you were a great help, Chris.
Martin Shaw 113/01/2019 16:56:06
118 forum posts
37 photos
Chris
I have a Cowells of, by the sound of it, similar age, certainly the GEC motor. My problem is that whilst it will start and run, the motor sounds very lumpy until the start relay lethargically operates, after which it is fine. I spoke to Cowells who identified the relay as the problem but they didn't have any replacements. Am I correct in thinking that you have sourced a replacement relay? I did look at putting a new motor in but other things got in the way. I have got the Cowells book which has a wiring diagram, I'll post it in my album.
Martin
Edited By Martin Shaw 1 on 13/01/2019 16:57:12
Chris Noton13/01/2019 18:17:30
6 forum posts
Dear Martin, I was lucky I have a secondhand relay, why my motor was overheating is because the relay contact was dancing up and down rather than making a clean contact. Personally I don't think you'll have any luck sorting a relay or a moor. You can get a replacement motor from Cowells but you will have to do a lot of modifications as the motor is bigger you would would have to raise the base and change pulleys and it would probably outweigh the value of the lather. I am not an electrician I am a motor mechanic but what you could try (totally at your own risk) with the lathe completely disconnected from the mains, if your lathe has the large cream belt cover loosen the two screws at the back of the lathe and carefully remove the cover turn the lathe upside down, there is a plate with four screws, remove the screws, you will see the black relay with three wires connected to it, near the single red wire from the motor there is a small screw and a plate, remove the screw you will be able then to lift the relay off it will leave the T section in the base, lift the relay and carefully lift the black box you will the contacts near the coil, as long as the coil is alright its a possibility the points can be dirty, if you get some very fine 800 wet and dry paper fold it in half so both sides are abbrassive slide it between the points carefully push the top point down gently so it has slight pressure on the paper and gently move it forward and back, but don't damage the metal section. After you have done this get some clean paper with the same method rub it between the points to remove any residue, similar to what you would do on an old cars distributor.then FULLY assemble and then try it again. If this doesn't work it would pay to un-solder the motor and get a competent electric motor repairer to test it. Hope this helps, best wishes, Chris.
alan-lloyd13/01/2019 19:19:44
173 forum posts
I always found cowells to be a bit evasive about giving out info, I asked what colour blue were the base castings painted on the present lathes? they are not hammerite by the way. sorry don't know, could you send me a sample pot, no sorry, thanks for your help.
Chris Noton13/01/2019 19:51:49
6 forum posts
Hi Allen, YES, I can see with your picture you're a biker as well so you already probably know this, most car spray paint suppler can usually match and mix the paint. I did want some once for an Emco and they did a perfect match for me. Best Wishes, Chris.
Chris Noton13/01/2019 20:16:40
6 forum posts
Hello again Allen I am sure some time ago I did get some paint mixed for a cowells you first have to spray a clear texture finish then the blue finish as it is not a smooth finish Chris
Martin Shaw 114/01/2019 09:55:02
118 forum posts
37 photos
Chris
Many thanks for your notes, I'll have another look at it and see where it might go.
Martin
Mark Cubranic04/02/2021 06:35:04
1 forum posts
Hello all, I am an electrician based in Melbourne, Australia. I had my neighbour come to me with a Cowells 90 ME lathe, saying that it was getting exceptionally hot. The problem is with the little black box that I have seen referred to as “a relay”. In a way, it is, but it is actually a temperature or thermally operates switch. The motor starts and generates heat in the windings as it speeds up. The switch in question then is supposed to change over to switch from the start winding to the run winding. If this thermal switch does not change over, the motor will run hot and potentially burn out. I hope that this helps.
Regards Mark.🇦🇺
JD Metals
