Forum sponsored by Allendale Nov 29
A Video for Ron
JasonB05/01/2019 16:42:50
14872 forum posts
1492 photos
I posted a photo of progress on this engine the other day and Ron asked why I had used ball bearings rather than bronze, I think this video should answer that.
ARC's 686 bearings straight off the shelf, not cleaned, no additional lubrication, I paid full price and I don't get any commission but they seem to run quite well.
mechman4805/01/2019 16:54:29
2256 forum posts
381 photos
Wow! 4 min. 22 sec. to come to a complete stop... nigh on perpetual motion... devil … can't complain about those bearings.
George.
Ron Laden05/01/2019 17:21:18
938 forum posts
137 photos
Wow Jason, I know that good ball bearings are free running but I would never have guessed for that long, certainly proves your point. The last 30 seconds when there is less momentum show just how free it runs, you certainly havnt got any friction to worry about there.
The flywheel, very nice, have you machined that from solid..?
Ron
Ketan Swali05/01/2019 17:50:32
1072 forum posts
87 photos
Jason,
That is indeed a long running time.
The late Roy Darlington well known for Stirling engines used to tell me that in certain cases to reduce further friction, it was a good idea to wash out the open bearings in paraffin before use, but in your case it seems unnecessary.
Ketan at ARC.
JasonB05/01/2019 18:26:55
14872 forum posts
1492 photos
I may well give them a flush out before final assembly, at least that way if the engine does not work by give it a good spin and keeping the video short I can claim it's a runnersecret
Ron, its a casting off e-bay. I have bought a few from the same guy and they are good quality, he used to cast fr the old owners of College Engineering. Since the video I have had a good chew at the hub as it was too big for the 6mm PGMS shaft that I used.
Martin King 205/01/2019 18:33:18
555 forum posts
182 photos
Hi Jason,
Any chance of a link for the flywheel castings please?
Cheers, Martin
JasonB05/01/2019 18:34:56
14872 forum posts
1492 photos
f:0">Flywheel
he has others too
Edited By JasonB on 05/01/2019 18:35:22
not done it yet05/01/2019 19:47:43
2648 forum posts
11 photos
Needs balancing!smiley
Ron Laden06/01/2019 10:16:52
938 forum posts
137 photos
Thanks for the flywheel link Jason, I see he does a 6 inch version which is just about right for my scale on the engine.
Ron
Ian S C06/01/2019 10:35:36
7225 forum posts
227 photos
I have not actually done the strip and degrease of the bearings I use, and most are shielded bearings. I think the general idea is to remove the shields, and the grease, but then use a very light oil in the smallest amount. On little bearings(3 mm/4 mm bore) a drop on the end of a pin.
Ian S C
TRANSWAVE Converters
