The Workshop Progress Thread 2019
JasonB01/01/2019 06:57:22
18932 forum posts
2083 photos
Report your modelling and workshop milestones in this thread. Anything else should go into the What did you do thread
2018 posts can be found in this thread
Edited By JasonB on 01/01/2019 07:34:58
Ron Laden01/01/2019 08:35:43
2010 forum posts
401 photos
Jason, your engine is coming along nicely, looking really good. Ball bearings and not plain bearings.? just wondered what your thinking was on that.
Ron
JasonB01/01/2019 10:08:30
18932 forum posts
2083 photos
Ron, the flame lickers don't have a lot of power so the ball races should offer less friction than bronze. have also gone for unshielded for the same reason.
Ron Laden01/01/2019 10:43:29
2010 forum posts
401 photos
Posted by JasonB on 01/01/2019 10:08:30:
I thought it must have something to do with ease of running, is the Forest engine similar re power or does the gas mix give them more.
JasonB01/01/2019 12:27:34
18932 forum posts
2083 photos
The Forest would have more power though the original was only rated at 1/15th horsepower from it's 2.5" bore
Joseph Noci 102/01/2019 06:00:23
755 forum posts
949 photos
In late 2017 I obtained a neat 3 phase 250watt motor with attached Varvel 100:1 gearbox and thought that was ideal for a bench powered hacksaw. It sat under that bench for a year..Mid December last year I challenged myself by starting the project, but on the basis that I do it only with bits from the scrap box/store, etc, ie, no purchase of any bits not within the workshops! ( Except hacksaw blades, of course...)
The base is a piece of 150mm x 75mm x 8mm channel iron, shapered flat and milled for the vice, etc. The saw frame slides are 18mm Hex, steel for the fixed and brass for the reciprocating frame. The slides pivot on large bearings that are also on the main drive shaft out the gearbox. In the top hat is the 500watt VFD, and the on/off/speed control. Speeds are from about 2 strokes/sec to position the frame when checking stroke length (inching..) up to 130 strokes/sec.
Views with all guards in place.
The hydraulics are seen here - The tube (right) from an old mountain bike front shock
This is the cam activated blade lifter during the return stroke - worked OK, but eliminated by appropriate crank moments placement and geometry, with only a damper used. See it working in the video
The drive con-rod, ready to weld up. The crank has three throws giving strokes of 220mm, 160mm and 80mm, allowing optimal use of the full blade for different stock sizes.
The oil distribution grooves in the fixed hex slides - fed from an oil well in the top support - one-shot oiling..
The oil well.
The saw frame and slides.
Blade Tensioner.
The vice/screw - made from an old imperial X leadscrew from and EMCO FB2 mill.
The shaper flattening..
And...
The TIG welding on the Ali covers was so good, I just painted over and did not smooth down! ( patting my back..)nice tig weld.jpg
All my 'CAD' design drawings for the complicated bits...
Hydraulics..
A video link below- does not neatly stand on its own, but shows the workings well enough. The blade reliever during return stroke was a trial only really - the cam has a 2mm offset, which through the lever gave a blade raise of 4mm. This needs to reduce to maybe 1mm, ie, cam lift of 0.5mm or so - But the adjustment of the hydraulic drop rate is just to finicky in this mode, and the damper only mode, coupled with proper crank throw moments works best Also, the blade front is 1.5mm lower than the rear mount, and that with correct damping drop rate works very well.
Took 2 weeks to build, finished on the 1st Jan 2019...And Neil, I was ALSO crimping wires for this on Christmas day!
Joe
martin perman02/01/2019 09:51:52
1877 forum posts
78 photos
Thats some saw.
Martin P
Joseph Noci 102/01/2019 15:19:32
755 forum posts
949 photos
Thanks Martin..
After building the saw I decided I had better do something about all my poor condition drill bits..
I have a neat T&C grinder that does drills very well, but is a huge pain to setup, so tends to not be used for drill sharpening. I always thought a jig such as the one in March 2000 (issue 64) MEW was a good idea, and when I got hold of a square block 5C collet holder I decided this morning to knock up a similar adaptor for my grinder.
This is the universal tool head on my grinder - does all, but requires a lot of set up.
The 5C collet block
With a sharpened drill still inserted
Method of aligning the drill edges
The universal tool head with extraneous removed and a fabricated Collet block table fitted
Collet block with drill in place. The block is heavy and stays in place with the tilt of the table for the relief angles.
25deg secondary relief set
Grinding secondary relief.
5deg primary relief set
View of motion tables from above.
6.4mm drill swarf - not to unbalanced..
3mm drill swarf. ( poor, soft and string Ali..)
Joe
Paul White 302/01/2019 15:37:37
101 forum posts
17 photos
Joe,
Did you really mean 2 and 130 strokes/sec. I know you build fast but HSS blades must be essential!
A very neat product at any speed.
Joseph Noci 102/01/2019 16:00:45
755 forum posts
949 photos
Hello Paul! A good New Year to you Sir!
Yes, become bored over the holidays, so got stuck in..And yes, 2 to 130 strokes/s. When the stroke is set to 80mm for example, I could really do with even around 150 strokes/s or faster..At the 220mm stroke, 100 strokes/s is comfortable. I do use HSS blades, but I also cut blade lengths from bandsaw blade stock and drill the tension pin holes with a carbide drill - those blades work even better, as I can easily do down to 12 teeth/inch which is great for thicker Ali stock.
Anyway, it was a lot of fun in the making.
Nice to hear from you!
Joe
Paul White 302/01/2019 16:11:22
101 forum posts
17 photos
Joe,
I should have guessed, did not consider stroke variation, making an even more impressive build.
Looks like a busy year, 2 days into it and 2 projects finished
.Paul
JasonB02/01/2019 16:21:07
18932 forum posts
2083 photos
Joe, if you are using a 100:1 gearbox then you would need the motor to be running at 780,000 rpm to get 130 strokes per second are you sure it is not strokes per minute, even then its 13000rpmcrook Or have you used the gearbox to increase things rather than reduce?
Joseph Noci 102/01/2019 17:08:56
755 forum posts
949 photos
As usual, Jason is Wide Awake! I have too many bits on the go here...The 100:1 is for the gearbox on a motor I am using for another cheese curd stirrer for my good wife - and that one is giving me a headache, and so was on the brain, so to say!
Sorry, to set things straight - The saw's motor is 1345RPM @ 50Hz ( according to its descriptor plate). The gearbox is a Varvel 15:1 box, and the speed should have been in STROKES/min !! Seems I got most of everything wrong..
I think I'll just back off and try again next year....
Should really edit that post 'cause that is plain crappy posting..
Joe
daveb02/01/2019 18:57:18
623 forum posts
10 photos
I wouldn't mind getting it all wrong if my jobs turned out like that.
I like the drill jig, just what I need for my Clarkson.
Very nice work Joe!
Daveb
Joseph Noci 102/01/2019 20:31:41
755 forum posts
949 photos
Daveb,
Since the Clarkson has both table traverse and feed, you would not need anything more than what I have implemented - just a firm tray/guide to hold the square collar block and a means of setting azimuth and elevation angles. Since the drill tip included angle can be fixed, that one is easy to do, and then a means of setting 25deg and 5deg ( or whatever takes your fancy) for the primary and secondary facets in the remaining plane is all that is needed.
I was very pleased with the accuracy of the collar block - it is a chinese block and was inexpensive, but is ground parallel to within plus/minus 0.002mm across all flats! Fitting a 10mm 5C collet with a 10mm carbide rod in the collet and placing the block flat on a granite block I find less than 0.006mm variation with a height gauge and dial indicator between granite surface and top of the carbide rod, on all 4 block faces. Part of that variation will also be from the collet, so all together not bad at all.
The 5C collet also offers more contact length across the drill flutes which seems to give better drill location on smaller drills ( sub 3mm) than I was obtaining with ER20 collets.
I appreciate the ease of removing the block from the receptacle and being able to quickly inspect the tip grinding progress, and then replacing the block with no loss of register.
What I need to do is make up some sort of optical/magnifying aid to better align the drill cutting edges parallel with two sides of the block, especially the smaller drill. Maybe a small video camera in line with the drill bit tip, and projected onto a PC screen with a cross-hair overlay. Problem with that is that it starts to become too complicated again to get all the bits out, connected and working, before I can sharpen a drill bit...A monocular magnifying eye piece in line would work fine, but I have few skills in that dept - and no optics or lenses to play with!
Joe
David Standing 102/01/2019 22:22:37
1289 forum posts
48 photos
Joe
I am now at the point where I recognise a photo that is clearly your work before I even see who has posted it! yes
Jeff Dayman02/01/2019 22:36:16
1896 forum posts
45 photos
Joseph - re the covers TIG welding - you keep going like that and there will be grinder disc factories shutting down!
Great work, well done.
Joseph Noci 103/01/2019 06:07:06
755 forum posts
949 photos
Posted by David Standing 1 on 02/01/2019 22:22:37:
Joe
Mmmm, David, methinks I need to change the colour that I paint things..
Joe
Ian McVickers15/01/2019 21:30:39
188 forum posts
89 photos
I'm in the middle of making a version of the upgraded universal head for the Clarkson MK1 Tool Grinder as shown on the bedroom workshop site. Base plate has been milled to size and a recess cut to accept the upper part. A centre line was engraved across the plate as well but it doesn't show up too well on the photo. Upper part turned to size at 95mm diameter and 110mm high then cut in the bandsaw, about 30 minutes worth of cutting. Hopefully at the weekend I will get some time in the shop to finish milling it and possibly get a scale engraved around the bottom edge.
JasonB17/01/2019 19:36:17
18932 forum posts
2083 photos
After letting the paint harden off for far longer than it really needed I thought it was about time to see if I could remember how it all went back together, I think this looks about right and there were no bits left over blush
[img]
It is not quite as lively now it is back together though that may be due to having to fit a new ring as I broke one during assembly though compression seems reasonable. I have not got the governor latching in this video as it does not need it at these speeds. Hopefully with a bit more tinkering it will liven up and the governor can be set to work.
This thread is closed.
EngineDIY
