Forum sponsored by Allendale May 23
What Did You Do Today 2019
mechman4803/01/2019 20:29:11
2365 forum posts
373 photos
Posted by Michael Gilligan on 03/01/2019 19:12:02:
Posted by mechman48 on 03/01/2019 18:57:31:
The digi gauge showing discrepancy of 1 minute...
Can't complain at the 1st attempt though. Comments / tips welcomed...
George.
Looks good, George ... but I wonder
Have you tried 'rotating' the gauge and reading from t'other side ?
... The readings should, of course, add up to exactly 90°, and a discrepancy would demonstrate a limitation in the resolution/accuracy/repeatability of the digital gauge.
Thanks for the tip... just been out & tried it t'other way...180*
Bang on 45*… + 45*.1" = 90*.1' … 1" total discrepancy...
So … "a discrepancy would demonstrate a limitation in the resolution/accuracy/repeatability of the digital gauge"... so for a hobbyist work shop ...yes
No doubt purists will comment.
George.
mechman4804/01/2019 22:32:20
2365 forum posts
373 photos
Made a couple more angle plates today, a 30*- 60* & a 70* - 20*…
George.
Michael Gilligan04/01/2019 23:42:20
13059 forum posts
570 photos
Great stuff, George
Paul Lousick05/01/2019 00:38:12
1072 forum posts
478 photos
The GemRed web site for digital angle gauges specifies a resolution of 0.1° and a repeatability of ±0.1°. You would need a sine gauge for anything more accurate.
Edited By Paul Lousick on 05/01/2019 00:40:31
Michael Gilligan05/01/2019 00:45:54
13059 forum posts
570 photos
Posted by Paul Lousick on 05/01/2019 00:38:12:
So presumably George is actually displaying 45.1 degrees, and 45.0 degrees
Edited By Michael Gilligan on 05/01/2019 00:49:01
Brian H05/01/2019 08:09:51
1096 forum posts
85 photos
Broke a 10BA tap today, that the third tap I,ve broken in 60 years! The last one was also 10BA and the first one was 1/4" Whit on the end of a 4ft long tap wrench in the crown of a 12" piston.
Brian
roy entwistle05/01/2019 08:55:08
968 forum posts
Brian H
Clumsy cheeky
mechman4805/01/2019 16:44:08
2365 forum posts
373 photos
Digi readings as displayed for the later two angle plates …
60* side...
30* side …
so; 59.9* + 30.1* = 90 *
20* side...
70* side …
so 70* + 20.1 = 90.1* I'm contributing the 0.1' discrepancy in all down to the digi gauge +/- 0.1* as mentioned by
Paul Lousic's post …
''The GemRed web site for digital angle gauges specifies a resolution of 0.1° and a repeatability of ±0.1°. You would need a sine gauge for anything more accurate''.
Just in case the question is asked I zero the digi gauge before readings on ea. side...
So now that I've refreshed my old grey matter with trigonometry workings I'm a happy bunny... now on to a couple more - 5*-10*-15*- 25* using the same methodology... face 20 … don't think I need to post on the rest.
George.
DrDave06/01/2019 17:21:48
157 forum posts
30 photos
Reading Mr Cutwel’s latest caralogue that arrived recently, I noticed that one of their indexable face mills is advertised as having “hugh feed rates”. This means a feed of 1.0 to 1.5 mm per tooth in carbon & alloy steels. I suspect that my little Sieg mill might not be up to that!
Barnaby Wilde06/01/2019 17:42:08
326 forum posts
1 photos
Posted by DrDave on 06/01/2019 17:21:48:
I suspect that you're right.
There are many factors involved in metal removal rates, yet real world physics plays the biggest, but perhaps the most ignored part !
mechman4806/01/2019 18:51:40
2365 forum posts
373 photos
Finished off the set of angle plates; all within 0.1* according to my digi gauge...just need a bit more polish up...
George.
Joseph Noci 108/01/2019 17:15:04
476 forum posts
817 photos
Completed my Drill Alignment microscope jig to align drills in my 4 facet grinding jig ( previously posted on).
The optical head is a Bausch and Lomb Zoom microscope, and I fitted a horizontal reticule in the right eyepiece after some advise and guidance from Robert Atkinson - Thanks Robert!
The 5C collet in a square block holder sits on a focusing stage as seen.
The focusing stage - drill end view
Focusing stage - side view
Th reticule is a plastic ring sized to fit inside a threaded reticule holder that screws into the underside of the eye piece. A single fibre of fibreglass was teased from some weave, and superglued to the 180deg apart slots made in the sides of the plastic ring. The ring then inserted in the holder and screwed into the eye piece until focused.
View ( focus was difficult..) of the fibre reticule in place, from the bottom of the eye piece.
View through the microscope, focused on a 3mm drill, showing the reticule.
The camera was difficult to focus, being handheld, so the drill image is not that clear - it is VERY sharp when eye viewed.
The difficult part in the construction was getting the microscope sight-line horizontal and in line with the drill point at all focus ranges and zoom settings.
This at lowest zoom setting - at full zoom the 3mm drill fills just over half the image
Then I added a micrometer to the drill grinding stage on the grinder to be able to minutely advance the drill to grind the primary facet - I was using the X slide to do that, but with small drills ( sub 2mm) the movement is difficult to keep fine. The micrometer makes it a doddle!
Makes sharpening drills a pleasure!
Joe
Neil Wyatt08/01/2019 18:50:54
15951 forum posts
674 photos
73 articles
Just to be pedantic 0.1 degree on a wixey type gauge is six minutes.
A 0.1 degree error is only 1.7 thou per inch, or about 3 thou over the width of the gauge.
mechman4808/01/2019 21:08:16
2365 forum posts
373 photos
Thanks Neil; I'll not worry over 1.7 thou' per inch in what I do
Geo.
ChrisH11/01/2019 10:28:24
816 forum posts
12 photos
Yesterday morning early my daughter was driving to work along the dual carriageway from Guildford to Alton and spotted a car head first into the ditch, obviously been there a little while as the windows were all frosted over.
She phoned 101 and they said yes, they'd had numerous calls re the incident already. So daughter asked if anybody was going to check if anyone was inside. Their reply stunned her. Yes, they said, they would do if they had anyone available, or if they had anyone driving by they would ask them to check it out. Absolutely disgraceful.
So what happens if there is anyone inside unable to summon help themselves? Tough luck it seems, hope they don't die before anyone can be bothered to check.
Moral of the story is, don't get into any difficulty and go off the road, at night and in freezing conditions especially, but if you do, don't expect help to arrive anytime soon.
Welcome to todays not-so-great anymore Britain.
Edited By ChrisH on 11/01/2019 10:30:11
duncan webster11/01/2019 10:53:55
2069 forum posts
30 photos
Joseph, I've puzzled about this for a long time. As soon as you grind even the smallest amount off the end of the drill, it's cutting edge is no longer horizontal. Shouldn't you set it so that after a known cut the edge will be horizontal? Of course that implies knowing the helix angle and they are not all the same. I asked DG Brown the same question once and he replied you should set it as I suggest and that you soon learned by experience how much to set it off horizontal.
Joseph Noci 111/01/2019 11:29:41
476 forum posts
817 photos
Duncan, you are quite correct. I try now to do as you say - If the grind is just a 'touch up', I align and grind the secondary facet, and then re- align to do the primary, especially on the drills smaller than 3mm or so. If the drill end is bad, I hack it off-hand to be rid of the chipped parts, etc, then align and grind a secondary, and then re-align and redo the secondary, and re-align and do the primary. It sounds tedious but at least with this microscope jig its quick to align.
I suspect I ( you and I?) are/am being over-fussy, since the many 4-facet jigs built by many folk seem to work ok? gadgetBuilder et-al seem to have working devices and they do not bother with the error. I suspect though they are all just 'sharpening', not regrinding!
I guess it all depends on how much you are taking off of the tip.
Joe
Neil Wyatt11/01/2019 12:37:10
15951 forum posts
674 photos
73 articles
Posted by ChrisH on 11/01/2019 10:28:24:
A Scottish couple died after being left unfound in a car which had gone through a hedge a year or two ago.
I saw a car embedded in a fence near where I live in icy weather about a year ago. I stopped and there appeared to be someone hunched over the wheel. I opened the door to find it was an airbag, just as the driver got out the back seat and made me jump out of my skin!
Colin Heseltine11/01/2019 21:26:08
299 forum posts
63 photos
Spent the day trying to use Turbocad Pro 2018. Took me all day before I could get a pipe flange to look vaguely like the video tutorial said it should. BIgger screen, newer eyes and not being Red/Green colour blind might help.
Colin
ChrisH11/01/2019 21:56:17
816 forum posts
12 photos
Neil - my point entirely re the Scottish couple, tragic we can as a country afford all sorts of vanity projects but not have the funds to properly fund our emergency dervices. Probably two unnecessary deaths there.
Can appreciate your panic when you came across your incident, would scare the life out of most folk, and you being such a sober stoic sort of bloke too!
Chris
TRANSWAVE Converters
Ausee.com.au
