Forum sponsored by Allendale Nov 29
Mill tooling runouts
gerry madden31/12/2018 13:56:25
44 forum posts
5 photos
They say the devil makes work for idle hands so during a spare afternoon last week (I had intended to tidy the workshop!) I thought I would do some runout checks on my mill tooling. I seem to have acquired a Jacobs, Rohm and ER collet chucks over the years so I thought I'd see how they compared. For each check, I assembled the chuck into the spindle, fitted the bit, measured and repeated this 5 times. The runout was measured radially on a smooth part of the shank of a 6mm bit approx. 5mm down from the jaws.
After averaging al the data this is what I found:
Jacobs 13mm
1)tightening by one hole 26um
2)tightening by 3 holes 25um
Rohm 0~6mm
19um
ER25 standard collet chuck:
1) normal tightening 12um
2) very tight 14um
What I didn't do is measure the runout of the spindle itself. But I did put the DI on the tapered bore of the collet chuck and this gave ne about 10um which suggests that the standard collets are not so bad.
What did concern me though was the flexibility of the structure. Just a light finger pressure on the bit, OR the chuck, OR the head, produced almost the same level of sidewards elastic deflection in the order of 15um. I definitely want to investigate the root of this and see if it can be easily improved.
Does anyone know what would be a typical 'spindle' rigidity value (um/N) in a small hobby mill ? Clearly though my problem is not the spindle. I think I have a problem with the stability of the clamping surfaces in the structural parts. When I know more I'll let you know.
Michael Gilligan31/12/2018 17:20:10
12554 forum posts
545 photos
Posted by gerry madden on 31/12/2018 13:56:25:
Very interesting, Gerry yes ... I look forward to seeing your results.
I recently noticed something similar on a microscope [from a good maker] ... It's fine for visual work, but difficult to use with a camera.
Getting back to little mills, though: My BCA MkIII is probably a good 'benchmark' for how a small capacity mill might be better constructed ... But I'm sure production costs would not suit the modern hobby-market.
For inspiration: http://www.lathes.co.uk/bca/page5.html
Edited By Michael Gilligan on 31/12/2018 17:22:31
Tim Stevens31/12/2018 18:15:32
981 forum posts
All materials bend when subject to a load. All gaps in the structure also allow movement in the same conditions.
If we assume that you were putting no load on the table of the machine when applying your light finger pressure there could be movement in the attachment of the column, the gibs on which the head slides, the attachment of the back half of the head to the front, the bearings locating the spindle assembly, and the quill inside the assembly. Take up all these potential gaps and much of your flex will disappear, but you won't be able to do anything useful with your mill. As Michael Gilligan says, you can have stiff or you can have cheap ...
Wassail, Tim
Vic31/12/2018 18:34:37
1935 forum posts
10 photos
One thing that always surprises me is the number of times I see a cut being increased by extending the quill rather than raising the table. I was taught never to do this. I only move the quill on my machine when drilling.
Andrew Johnston31/12/2018 19:33:38
4380 forum posts
511 photos
Posted by Vic on 31/12/2018 18:34:37:
+1
And on my mill (Bridgeport) moving the knee with a graduated dial is more accurate than moving the quill.
JasonB31/12/2018 19:45:55
14658 forum posts
1455 photos
All goes out the window on most benchtop imported mills, not only do they lack a knee but the fine feed is usually on the quill and a lot even provide a digital readout so the extension of the quill can be set more accurately than with a hard to reach head handwheel.
Emgee31/12/2018 20:38:10
1023 forum posts
191 photos
The first mill I had was a Victoria U1 model I believe, anyhow it had a vertical head but no quill so all cuts had to be put on with the knee traverse, OK when putting on cut depths but not so good if drilling deep holes.
The next machine was a Herbert OV that had a superb quill with full graduations and easy to use locking device, it didn't take much use to take advantage of the new feature, the knee got used for setting up and not much else.
These days I rely on buttons or G code to raise and lower the head.
Emgee
Barrie Lever31/12/2018 21:11:16
107 forum posts
23 photos
Gerry
I would be interested in comparing notes/readings with you on this, could we come up with a basic test procedure so as that we are comparing like with like.
What milling machine do you have?
Barrie
Edited By Barrie Lever 1 on 31/12/2018 21:11:42
Bill Pudney01/01/2019 02:04:04
404 forum posts
16 photos
Over the Christmas break I had to take my mini lathe apart. It seemed like a good opportunity to check and adjust the spindle alignment. I chose to use "Rollies Dads Method", as described by John Moran. This requires using a DTI to measure the out of truth of a suitable test bar.
My initial setup used traditional, fair quality (mixture of MW, Mitutoyo, Starret) DTI holders etc. Well what a performance, I was thoroughly confused with conflicting and non repeatable measurements. I came to the conclusion that the problem was flexibility in the DTI holding system.
So I made a special DTI holder, with reamed holes to take the DTIs, mounted on top of the compound slide using the thread which normally secures the toolpost. Both Indicators could be mounted at the same time. What a difference!
No more conflicting measurements, all (well o.k....most) measurements were repeatable, within a very short time I had the out of truth of the spindle down to acceptable limits, approx 0.04mm over 300mm both vertically and horizontally.
The acid test of course was the cutting test, which showed an error of less than 0.01mm (graduations on my best micrometer) over a 100mm test length. The actual error, given the equipment to measure it, would probably be between 0.004 to 0.006mm. Pretty good I reckon for a 12 year old, much used Chinese pre assembled kit!!
All provided by a rigid system!!
Happy New Year
cheers
Bill
Andrew Johnston01/01/2019 16:23:42
4380 forum posts
511 photos
Posted by JasonB on 31/12/2018 19:45:55:
All goes out the window......................
Closely followed by the mill? smile
gerry madden12/02/2019 09:52:36
44 forum posts
5 photos
Hi All,
I have now made some more detailed investigations into the rigidity of my mill. Measuring deflections at the chuck with loads up to 15Kgf I find the compliance in the right and left direction (X axis) is twice as much as that in the Y axis.
Graph in next post - it doesn't like it inserted here for some reason!
Its surprisingly linear too.
There was also some hysteresis, in other words after applying and releasing the loads the spindle didn't return to exactly the same place. The 'free play' if I can call it that (but its not a noticable rattle) could be minimised by excessive tightening of all the gib screws and headstock clamp bolts but never completely eliminated. So I think some is in the spindle itself. The minimum I could get was about +/- 2um. Without normal gib settings it was about +/-6um.
As mentioned in my previous mail, when I put the DI on the spindle headstock, the deflections were of a very similar order which suggests that the elasticity is in the structure rather than in the spindle itself. The headstock looks quite rigid so I'm wondering if there is some 'rock' / weakness in the joint between the headstock and the vertical column. I'll begin taking it all apart to see if I can find anything that could be easily improved.
gerry madden12/02/2019 09:55:05
44 forum posts
5 photos
….no it wont allow me to paste the graph or even a snip of the graph..
gerry madden12/02/2019 09:56:21
44 forum posts
5 photos
Tim Stevens12/02/2019 10:25:08
981 forum posts
Gerry - you say: I find the compliance in the right and left direction (X axis) is twice as much as that in the Y axis
I am fairly sure that 'compliance' is not the word you need. A compliant device is one which follows its instruction precisely, so you really mean the opposite, I suggest. Would flexibility be a better word? Or deviation, perhaps? Or even floppiness?
PS my Champion 20V is much the same. One day I will try a couple of steel straps from the top of the column to the wall behind it.
Regards, Tim
Michael Gilligan12/02/2019 10:31:12
12554 forum posts
545 photos
Thanks for the update, Gerry
I have quoted from your original post because that is the area which I think needs work.
Obviously the individual structural elements could be stiffened, but you should get 'value' from improving the stability of any semi-permanent joints. [grab the low-hanging fruit, as they say]
When I worked in the vibration test lab. We experimented with using Loctite 638 as a hard gasket material; with excellent results. ... Happy to discuss this further, if you are interested.
Michael Gilligan12/02/2019 10:38:27
12554 forum posts
545 photos
Posted by Tim Stevens on 12/02/2019 10:25:08:
I am fairly sure that 'compliance' is not the word you need. A compliant device is one which follows its instruction precisely ...
Tim,
Other definitions are available, and may be more relevant
In Physics: Compliance is
the property of a material of undergoing elastic deformation or (of a gas) change in volume when subjected to an applied force. It is equal to the reciprocal of stiffness.
TRANSWAVE Converters
