Forum sponsored by Allendale July 23rd
Testing Models
Testing of model steam engines and turbines.
Turbine Guy23/01/2019 15:14:20
107 forum posts
49 photos
I estimated the following mechanical losses due to friction using a friction coefficient of 0.30. The crosshead power loss is estimated to be 0.51 watts. The crankshaft bearings power loss is estimated to be 1.31 watts. The propeller had a thrust force of 0.39 lbs at a speed of 700 rpm resulting in a estimated 0.23 watts of power loss. To estimate the piston rings power loss, I assumed the mean effective pressure pushed the rings out against the cylinder and used a coefficient of friction of 0.13. Since the Chiltern engine has two piston rings, I assumed half the pressure drop occurred across each piston ring. With these assumptions, I estimated the piston rings power loss to be 0.54 watts. The total of all the estimated mechanical losses is 2.59 watts. The indicated power with a clearance area of 0.028 in^3, a cutoff of 94%, an inlet pressure drop of 0.60 psi, a exhaust pressure drop of 0.68 psi, and a compression ratio of 1.36 is approximately 7.9 watts at 700 rpm. With an estimated indicated power of 7.9 watts and an estimated total mechanical loss of 2.59 watts, the estimated power is 5.31 watts. The actual power was 4.71 watts. This leaves 0.6 watts unaccounted for. Hopefully, this analysis gives an indication of the approximate magnitude of the losses and where they occur for the Chiltern engine tested. As previously stated, some of the losses are due to tradeoffs in performance versus ease of operation and setup, not poor design.
Tim Taylor 228/01/2019 17:01:32
66 forum posts
8 photos
TG,
Don't know if you've seen these, but links to a couple references I thought you might find of interest...
https://www.forgottenbooks.com/en/download/The_Steam_Turbine_1000777956.pdf
https://www.osti.gov/servlets/purl/1376860
Tim
Turbine Guy28/01/2019 22:03:30
107 forum posts
49 photos
Tim,
There is a lot of information in your first link, essentially a complete book on turbine design. It will take me a while to go through the PDF file and see what it adds to the several books on turbines I have. Quick scanning through the PDF showed it gets pretty deep in the technical aspects. Thanks for the link.
The second link was information on two phase nozzle design. I currently have no interest in that. When I made turbines with large enthalpy changes that got into the supersonic velocities, I was careful to use highly super heated steam to avoid moisture at the end of the expansion. It would be an interesting subject if change of phase could not be avoided. Thanks for showing the link.
Turbine Guy30/01/2019 21:00:33
107 forum posts
49 photos
After estimating the magnitude of the losses and what caused them for the Chiltern engine, I looked at ways to recover the losses. I started by seeing if the cutoff could be changed and what would be required to make the changes. I started with the best case. I estimated the indicated power without any pressure drop through the ports, no clearance volume, full expansion, and no compression of the air on the exhaust cycle. This is a perfect condition where the power produced equals the energy available. I used a 14mm bore, 18mm stroke, air with an inlet pressure of 24 psig, an exhaust pressure of 0.0 psig, and a mass flow of 1.74 lbm/hr. The cutoff for the ideal case is 48%. With these conditions, the power is approximately 17.5 watts at a speed of 1,620 rpm. I assumed a slightly higher inlet pressure than I was able to attain in the previous testing since I can get a propeller that keeps the maximum speed low enough that my airbrush compressor can maintain the higher pressure. I found by changing the piston valve and changing the ports from holes to slots I could get a cutoff of approximately 50% and still keep the pressure drop through the ports very low. I calculated the indicated power and mechanical (friction) losses by the methods I previously described plus added the 0.6 watts loss I was unable to account for. I estimated I could get a maximum power of 5.9 watts at a speed of 1,040 rpm. The test of the unmodified Chiltern engine resulted in a maximum power of 4.71 watts at 700 rpm. I’ll explain why this major change only has a potential gain of approximately 1.2 watts in my next post.
Turbine Guy01/02/2019 18:29:57
107 forum posts
49 photos
The following drawing shows the valve I designed to try to get approximately 50% cutoff with the existing eccentric and valve linkage. The existing valve has a 0.4mm inlet lap and a 0.6mm exhaust lap. My revised valve has an inlet lap of 2.75mm and no exhaust lap. It wasn’t until I made a series of drawings to check the valve operation that I learned the importance of exhaust lap. Valve Mid Travel Position
Turbine Guy01/02/2019 18:33:29
107 forum posts
49 photos
The following drawing shows the distance from the cylinder cover to the piston when the inlet valve closed. The distance traveled minus the clearance distance divided by the stroke is the cutoff. The actual clearance is 2.25mm, so the cutoff is approximately 58%. Because of the time it takes to close the valve, the effective cutoff is probably close to the 50% I was trying to get.
Valve Cutoff Position
Turbine Guy01/02/2019 18:36:32
107 forum posts
49 photos
The following drawing shows the distances from the end plates when the exhaust closes on each side of the piston. The distance below the piston is used to calculate the volume of trapped steam or air that is compressed. I estimated the amount of power to compress the trapped air to be approximately 0.67 watts. The distance above the piston is used to see the point in the stroke the exhaust is released. The distance moved by the piston 18.08mm minus the clearance distance of 2.25mm and is approximately 15.83 mm. Since the stroke is 18mm, the air is released 2.17mm before the piston has moved the full stroke. I estimated the power lost due to the early release to be approximately.0.85 watts. In my original estimate of the power with the revised valve, I missed the early release. With this loss, the gain in power would be very little. The cure to this problem would be to add exhaust lap. The exhaust lap would almost eliminate the early release but increase the compression. If I could add the required exhaust lap, I would probably get the performance I first estimated. There isn’t enough room to add the required exhaust lap so I will have to look for a better way to improve the performance.
Exhaust closed and release points
Edited By Turbine Guy on 01/02/2019 18:37:39
Turbine Guy12/02/2019 19:52:00
107 forum posts
49 photos
I decided I would have to make separate exhaust and inlet valves to substantially increase the efficiency. The link **LINK** confirmed the increase in efficiency with separate valves. This article also gave me enough information that I could check my formulas and methods of estimating performance with some actual test data. I used the 1.27 in. bore, 2.00 in. stroke, 15% clearance volume, 38% cutoff, early release distance of 0.30 in., exhaust closed distance of 0.44 in., inlet pressure of 38 psig, superheat of 81.2 C, and 502 rpm engine speed shown in fig. 6 for the conventional valve. With these inputs and using my equations I calculated an indicated power of 116 watts. The test result was 119 watts so my equations and methods appear to be valid. The following drawing shows a concept to add a second valve to my existing engine. Separate Valves TDCAdding the separate valves requires 1 each of the following new parts, a valve chest, inlet valve, exhaust valve, eccentric, and a valve connecting rod. To get maximum efficiency I would also add new top and bottom cylinder covers to the preceding new parts. These covers would extend further into the cylinder to reduce the piston clearance from 2.25mm to 1mm at each end of travel.
Turbine Guy13/02/2019 19:50:55
107 forum posts
49 photos
With the preceding new parts, 14mm bore, 18mm stroke, air with an inlet pressure of 24 psig, a exhaust pressure of 0.0 psig, and a mass flow of 1.74 lbm/hr. the input power is approximately 17.5 watts. The average cutoff for each side of the piston is approximately 52%. The estimated output power is 7.52 watts. The estimated hydraulic efficiency is 66.9% and the estimated overall efficiency is 41.9%. Adding separate valves and reducing the clearance volume increases the power by approximately 2.8 watts, a 60% improvement, but requires 7 new parts.
Turbine Guy13/02/2019 21:17:40
107 forum posts
49 photos
I tried various combinations of inlet and exhaust lap for a single valve and found that an inlet lap of 2mm and no exhaust lap that gave an average cutoff of approximately 75% was the best combination for air with an available energy 17.5 watts. The air has an inlet pressure of 24 psig, a exhaust pressure of 0.0 psig, and a mass flow of 1.74 lbm/hr. The estimated output power is 5.6 watts. The estimated hydraulic efficiency is 51.8% and the estimated overall efficiency is 32.3%. Making a new valve without any other changes could increase the power by approximately 0.9 watts, a 19% improvement, and only require 1 new part.
Valve 2 Mid Travel
Turbine Guy10/04/2019 22:09:06
107 forum posts
49 photos
In the post of 31/12/2018 I stated: ‘The velocity coefficient for the existing rotor geometry, nozzle position and throat diameter, a power of 1.92 watts, an air flow of 1.74 lbm/hr, a inlet pressure of 24 psig, a inlet temperature of 70 F, and a speed of 17,012 rpm is 0.34. The velocity coefficient for the optimum Terry turbine rotor for these same conditions is 0.53.’ I built a rotor with twice the number of pockets of my first turbine rotor. The pockets of the new rotor overlap eliminating most of the edge blockage of the first design. I thought this design could possibly approach the performance of the optimum Terry turbine mentioned above. The following photo shows the new rotor (aluminum) next to the original rotor (brass). I tested this rotor with the same air pressure and flow used in the test of my original rotor that had a maximum speed of 17,000 rpm. The maximum speed with the new rotor was 18,250 rpm. The required power of the EP2508 propeller used in these tests is approximately 1.9 watts at 17,000 rpm and 2.4 watts at 18,250 rpm. The average rotor velocity coefficients for these output powers are 0.34 for 1.9 watts and 0.53 for 2.4 watts. I got the maximum I thought was possible, so this is a very significant increase. The original rotor has 24 pockets and the new rotor has 48 pockets. In Dr. Balje's study of high energy level, low output turbines the highest average rotor velocity coefficient for a Terry turbine with a single nozzle, 45 blades, and an admission length to rotor pitch length ratio of 1.72 was 0.53. The open pockets appear to be as efficient as the Terry turbine blades for this very small pocket size.
Turbine Rotors
Turbine Guy10/04/2019 22:21:08
107 forum posts
49 photos
The following drawing shows the details of the Tangential turbine of the previous post with the brass rotor.Tangential Turbine BB
Turbine Guy10/04/2019 22:23:34
107 forum posts
49 photos
The following drawing shows the details of the latest Tangential turbine with the aluminum rotor.
Tangential Turbine 2
Turbine Guy11/07/2019 22:10:10
107 forum posts
49 photos
I decided to make a velocity staged tangential turbine and the next few posts update the testing I have done.. The following drawing shows my initial design. Since I didn't get the first nozzle hole in the correct position I had to add another nozzle hole in the vertical position, but the concept is the same. . I designed this turbine to be able to run with the first row of blades only by leaving the reversing chamber off. The air or steam can exit the first row of blades out the opening required for the reversing chamber. I want to do this so that I can see the performance of the rotor with the larger diameter and greater number of pockets. The testing I have done on the last turbine indicates the open pocket design has about the same performance of a Terry turbine with the same rotor diameter, number of blades, nozzle admission length, and available energy. My first rotor with 24 pockets appeared to match the performance given by Dr. Balje’s diagram for Terry turbines with around 25 blades. My second rotor with 48 blades also matched the performance for Terry turbines with approximately 45 blades. The new turbine rotor has 60 pockets and the pocket angle has been reduced from 30 deg. to 25 deg so that the flow is closer to being perpendicular to the direction of rotation. Since the number of blades or pockets has a very large effect on the efficiency, I expect my new turbine running with just one row of blades and a larger diameter to further improve the performance even with the rotational losses of two rows of blades.. Tangential Turbine 3 VS 2A
Turbine Guy11/07/2019 23:10:58
107 forum posts
49 photos
I ran my new turbine without the reversing chamber with my airbrush compressor and it obtained a speed of 21,500 rpm turning the EP2508 propeller. My estimation of the power required by this propeller to turn at that speed is 3.8 watts. The power available to the turbine from my airbrush compressor is approximately 18 watts so the efficiency is approximately 21.9%. This is an increase in power of about 1.5 watt over what was obtained by my last turbine for the same amount of energy. The increase in power is primarily due to the increase in rotor diameter, increase in number of pockets, and reduction of the pocket inlet angle. The increase in the rotor diameter was from 0.892 in. to 1.226 in. This increases the rotor tip speed and torque. The increase in rotor tip speed raises the power but also increases the rotational (windage) loss. The rotational loss is still low enough at 21,500 rpm that even with the extra set of pockets it did not appear to be excessive. The increase in number of pockets was from 48 to 60. With single nozzles, the number of pockets under the nozzle discharge opening becomes very important since energy is lost in filling the empty pockets. The pocket inlet angle decreased from 30 degrees to 25 degrees. The smaller the angle, the less energy is lost from the flow not being perpendicular to the direction of travel. The power achieved was greater than expected so my estimations of power from the propeller might not be conservative. However, the increase in performance with each of the changes using the same propeller and airbrush compressor verifies that Dr. Balje’s guidelines are useful in the design of model turbines.
The following photo shows my test setup.
Tangential Turbine 3 VS Test
Turbine Guy11/07/2019 23:22:51
107 forum posts
49 photos
I also ran my new turbine on saturated steam at a gage pressure of 50psi (3.4 bar) and an estimated water rate of 0.55 oz./min. The maximum speed it turned the EP2508 propeller was 28,000 rpm. The estimated power required for the EP2508 propeller at this speed is approximately 8.6 watts. The steam was supplied by a Stuart Turner model 504 boiler and the assumed temperature was for saturated steam at the inlet pressure. I assumed the modest superheat of this boiler was lost to the cold turbine housing with air from the propeller blowing over it. The following photo shows the test setup.Tangential Turbine 3 VS Test 2
Turbine Guy12/07/2019 00:20:49
107 forum posts
49 photos
I made the following chart to summarize the testing of my turbines and a chart at the bottom to check the validity of my equation for estimating the power required by the EP2508 propeller. I had only one speed of the EP2508 propeller that I could verify the required power. I wanted to see if my use of increasing the propeller power by the cube of the turbine speed was valid for the range of speeds of my tests. Since APC has performance charts for all its propellers, I checked the performance of their propeller closest in size to my EP2508 propeller at the speeds nearest to the speeds obtained in testing. As shown in the chart, increasing the power by the cube of the speed for the range from 14,000 to 28,000 rpm was accurate to within 1%. Since the first test was with Rulon bushings and run with a smaller boiler, I did not include its performance in this chart. This way all the tests on air or steam will be with the same airbrush compressor or boiler and all the turbines have the same ball bearings. I also added a comparison of the efficiency of my model turbines with the efficiencies of high duty axial turbines shown on the U/Co diagram that will be added in the next post. I added this to show under similar conditions, even the optimum axial turbines do only approximately 20% better than my optimized open pocket tangential turbine.My Turbines 3
Turbine Guy12/07/2019 00:32:14
107 forum posts
49 photos
The following chart shows the efficiency of high duty turbines as a function of the velocity ratio of the rotor tip speed U to the ideal spouting velocity Co. This chart assumes turbine stages with enough nozzles, tight clearances, and power to make the filling losses and rotational losses negligible.Turbine Efficiencies
not done it yet12/07/2019 06:43:06
3165 forum posts
11 photos
Interesting. ‘Estimates’ to three significant figures. How do you manage to measure the power to even a precision of one in five hundred, let alone an accurate figure, to three sig figs? Just wondering - from a mathematical view-point.
Turbine Guy12/07/2019 19:35:58
107 forum posts
49 photos
Posted by not done it yet on 12/07/2019 06:43:06:
Very good point. I explained how I assumed a power of 1.2 watts for the EP2508 propeller turning at 14,500 rpm at the beginning of this thread. And later explained how the actual accuracy of the 1.2 watts was not as important to me as the change in power with each modification to my turbines. That being said, an accuracy of two significant places should have been used for the values of power. Thanks for pointing this out.
Advertise With Us
Ausee.com.au
Meridienne Sept 2019
TRANSWAVE Converters
