Forum sponsored by Allendale Nov 29
Vertex Rotary Table equal 13 sectors
ray jones 123/12/2018 21:36:18
47 forum posts
25 photos
Hi , I Need to cut a gear with 13 teeth. I have available a Vertex H/V rotary table.
13 teeth work out at every 27.692 degrees. Any advice or suggestions on the
best plate to use please , many thanks ray
Brian Oldford23/12/2018 21:38:08
476 forum posts
4 photos
I'd guess 39 hole plate. Is the RT 40:1 worm?
ray jones 123/12/2018 21:49:22
47 forum posts
25 photos
Hi yes 90 to 1 ratio. IE 1 turn of crank equals 4 degrees. Thank you ray
fishy-steve23/12/2018 22:16:36
107 forum posts
30 photos
For a 90:1 rotary table.
90/13 = 6 12/13 = 6 turns and 36 holes in a 39 hole plate.
Steve.
Howard Lewis23/12/2018 22:47:12
1819 forum posts
Sounds just like the problem that I had. My Vertex HV6 chart said 30 holes; that produced some odd vgears, until I checked and found it should be 36 holes on a 39 hole plate.
Martin Connelly24/12/2018 09:54:40
833 forum posts
93 photos
If you have a 65 tooth gear index using that.
Martin C
Paul Kemp24/12/2018 11:04:33
240 forum posts
9 photos
Posted by Martin Connelly on 24/12/2018 09:54:40:
Martin C
? You have lost me there, please explain how you get 13 from a 65t gear wither as direct division or via a 90:1 reduction.
Paul.
SillyOldDuffer24/12/2018 11:13:23
3997 forum posts
810 photos
Posted by Paul Kemp on 24/12/2018 11:04:33:
Martin C
Paul.
Martin has noticed that 65 / 13 = 5 ie. indexing on every fifth tooth will give 13 steps
Paul Kemp24/12/2018 13:12:19
240 forum posts
9 photos
Posted by SillyOldDuffer on 24/12/2018 11:13:23:
Martin C
Paul.
Doh, lol. Of course, must be too much Christmas spirit!! Don't know how I missed that when I always calculate my own divisions rather than refer to the chart that came with the dividing fixture!
Thanks,
Paul.
TRANSWAVE Converters
