Forum sponsored by Allendale Nov 29
[Dremel or smaller size] Diamond Saw Blade
Does anyone recognise this blade ? ....
Michael Gilligan20/12/2018 21:12:32
12752 forum posts
552 photos
Here's a screen grab from the latest epidode of "Digging for Britain" ... featuring a [presumably] Diamond saw, on a transparent disc.
Does anyone recognise it, please ?
SillyOldDuffer20/12/2018 21:26:22
3974 forum posts
807 photos
Could it be an optical illusion due to holes in the disk? Something like these dremel diamond cutters on amazon.
Derek Lane 220/12/2018 21:29:17
157 forum posts
25 photos
Could it be one with holes but due to the speed it appears as though it is a clear material. If it was plastic any heat build up may effect the clear plastic and distort the disc.
Edit cross post with SOD above and they are what I was thinking of
Edited By Derek Lane 2 on 20/12/2018 21:30:07
Michael Gilligan20/12/2018 21:36:42
12752 forum posts
552 photos
Thanks, gentlemen ... I did wonder that.
I have already written to Dr Madgwick, and will report back if/when he advises me.
colin wilkinson20/12/2018 22:57:25
44 forum posts
On eBay, from China, but for £3 I will take a chance.
https://www.ebay.co.uk/itm/10x-Mini-Diamond-Cutting-Discs-Wheel-Blades-Set-Drill-Bit-For-Dremel-Rotary-Tool/332731011825?epid=1854079303&hash=item4d785052f1:g:fzkAAOSwYq5bVhpY.
Colin
Bill Pudney21/12/2018 02:13:19
405 forum posts
16 photos
Or try a lapidary shop, they use fine diamond discs to cut stones, rocks etc. They also cut composites which is why I got mine!!
cheers
Bill
JasonB21/12/2018 07:04:30
15005 forum posts
1522 photos
The amount of "solid" around the edge looks a lot thinner than most of the drilled discs that are about would show when spun up but you may want to look at the dental ones such as this which only have a small amount of diamond coating around the edge
Ron Laden21/12/2018 09:06:59
969 forum posts
145 photos
Posted by JasonB on 21/12/2018 07:04:30:
I think Jason is probably right, my brother in law was a dental technician at the local hospital. He once showed me around his workshop and I can remember seeing a small holder with a range of very thin small cutting discs, not the type you would normally see for sale.
Michael Gilligan21/12/2018 09:12:54
12752 forum posts
552 photos
Well folks ... as you may have noticed, he was sectioning a tooth angel
MichaelG..
Ron Laden21/12/2018 09:25:25
969 forum posts
145 photos
Michael, have a google for Kerr diamond cutting discs
Ron
Michael Gilligan21/12/2018 09:59:58
12752 forum posts
552 photos
That looks promising, Ron
https://www.kerrdental.com/kerr-rotary/diamond-discs
Some of their's are slotted, rather than being perforated with  big round holes ... so the optical illusion would probably be more convincing.
Edit: Thanks also to Jason yes
Edited By Michael Gilligan on 21/12/2018 10:09:11
Martin W21/12/2018 10:55:08
782 forum posts
29 photos
I haven't watched the programme yet Michael but are you sure its a tooth and not a bone that he is sectioning? It doesn't look to have the right structure and shape for a tooth.
Martin W
Michael Gilligan21/12/2018 15:06:14
12752 forum posts
552 photos
Posted by Martin W on 21/12/2018 10:55:08:
Martin W
blush Oops !!
... His department also does a lot of work on teeth
Apologies for the sloppy error on my part
Edited By Michael Gilligan on 21/12/2018 15:32:09
Michael Gilligan21/12/2018 15:09:34
12752 forum posts
552 photos
Helpful resonse from Dr Richard Madgwick :
[quote]
It's not actually transparent - it has spokes, but you can't see them. It's a flexible diamond wheel that dentists use. I get them from prestige dental and they're about £12 each I think.
[/quote]
Thanks for the interest, everyone
JasonB21/12/2018 16:03:57
15005 forum posts
1522 photos
So are you taking up DIY dentistry as a hobby for the new year?
Michael Gilligan21/12/2018 16:17:15
12752 forum posts
552 photos
Posted by JasonB on 21/12/2018 16:03:57:
Maybe about 2:30 devil
TRANSWAVE Converters
