Forum sponsored by Allendale Nov 29
Modern efficiency !!!!!!!!!
Mick Charity19/12/2018 10:10:32
322 forum posts
4 photos
Incidentally, motor vehicles have always had excellent GREEN credentials, you'd need to look very hard to find one in a landfill. Most of a motor vehicle can be recycled, apart from the traditional parts scavenging which is increasingly being legislated out of business, there are recycling yards that smash the vehicles into tiny pieces & sort the result with only the plastics & seat foam going to landfill.
I don't know the figures, but this cycle of recycling may actually be better for the environment than keeping whole vehicles on the road for longer & longer.
Best of all it seems to operate very successfully without any gov't subsidies or legislative interfering !
martin perman19/12/2018 10:55:57
1515 forum posts
63 photos
Posted by Neil Wyatt on 18/12/2018 22:40:26:
Posted by martin perman on 18/12/2018 20:40:32:
Posted by Neil Wyatt on 18/12/2018 20:26:29:
Posted by martin perman on 18/12/2018 20:14:52:
After a long run, like Scotland and back, where I get about 67mpg, I put redex in the next tank and accelerate using lower gears than normal. Also, when there's no one behind me I drop the clutch and let rev limiter kick in - three or four of those blow all the crud out of the system and don't really waste a lot of fuel.
So to overcome one issue you are keeping addative, timing belts and clutch manufacturers in business in the long term. An endless circle.
Em... dropping the clutch top briefly rev the engine doesn't wear it out, and the engine has a timing chain.
I did say long term, does it have one of those sprung flywheels where the springs break and chains do stretch wink
Edited By martin perman on 19/12/2018 10:56:52
Edited By martin perman on 19/12/2018 10:57:32
martin perman19/12/2018 11:10:17
1515 forum posts
63 photos
Regardless of the cost and the week without it, nearest dealership is 30 miles away, I collected the car from the garage this morning and as soon as I turned the key I found that I had a different engine so the issue had been brewing over time.
Martin P
larry phelan 119/12/2018 11:41:15
393 forum posts
11 photos
There was a time when cars were simple ! Is there anyone out there old enough to remember when that was ?cheeky
Brian Wood19/12/2018 11:50:21
1848 forum posts
36 photos
Oh yes, and the starting handle you had to pull them over with to fire up the engine, remembering to keep your thumb away in case of kick back
Along with dim lights, awful screen wipers, no heating, narrow cross ply tyres, poor brakes, scoop opening doors semaphore direction indicators if you were lucky etc ----who could forget!!!!
Brian
Peter G. Shaw19/12/2018 12:01:05
943 forum posts
39 photos
20 years ago I bought my first diesel - Peugeot 405 turbo. 2 years old with 37K on the clock. At some high mileage, the clutch was changed, then at 137K the cylinder head failed - apparently they were known for that. But after that we ran to 165K at which point it was 12 years old. We part exchanged it for a 2 year old Focus 1,8 turbo diesel with 27K on it because we were told that the Peugeot towbar was no longer strong enough to tow our caravan.
That Focus. The worst car I have ever had. Poor tyre life, and not on cheap tyres either, clutch failure at 56K. Engine failure at 59K, various other engine management parts falure. We were glad to get rid at 85K/6 years old.
The replacement is a Toyota Avensis 1.8 petrol. Bought new, 5 & 3/4 years ago. 78k now on the clock. It does everything we want. Other than normal wear and tear, nothing has failed.
Both the Peugeot & the Toyota on Michelin tyres exhibit the same wear characteristicks - about twice the Focus! Which tells me it's not the drivers. In terms of economy, the Peugeot did 42.5mpg, the Focus 45.5 mpg and the Toyota does 38.5mpg. All averages of course which includes local running about and caravan towing.
Both diesels had turbochargers. The Focus also had a DMF. The Toyota does not have a turbo, and as far as I know does not have a DMF, although I understand some petrol cars do indeed have both. The Toyota is also far quieter than the diesels and theoretically more powerful and faster than the diesels.
When we bought th Toyota, we ummed and ahhed over Petrol v .Diesel. Diesel for its slogging power, but the unreliability of DMF's, and the known problems with regeneration in that we are not in a position to regularly do 20 minutes at 60mph in a lower gear meant that we had to go back to petrol. We do about 13-14k per annum which isn't enough for diesels.
I only wish we'd bought the Toyota earlier!
Cheers,
Peter G. Shaw
Neil Wyatt19/12/2018 12:47:35
15681 forum posts
659 photos
73 articles
Posted by Mick Charity on 19/12/2018 08:32:22:
There is a disease spreading all across the world & unless we find the cure then pretty soon the whole of mankind as we know it will be destroyed.
This disease is called GREEN.
There will soon come a day when it will be difficult to purchase petrol or diesel in the quantities needed to fuel a motor vehicle in daily use. The pumps will disappear as rapidly as those EV charging points are appearing.
With the introduction of self driving vehicles, it may actually become impossible to justify self ownership of any form of personal transport, these things will NEVER be able to interact with human drivers on the roads, so it's possible that human drivers may be banned from the highways.
Be afraid, the Brave New World is happening.
Well, I agree with the last sentence of your post...
Roll on affordable EVs I say...
Neil Wyatt19/12/2018 12:52:05
15681 forum posts
659 photos
73 articles
Posted by larry phelan 1 on 19/12/2018 11:41:15:
Yes, but they also seemed to break down a lot more often...
V8Eng19/12/2018 12:56:01
1230 forum posts
25 photos
Unfortunately I am having started driving in the 60s😢
I also remember shortish mileages between services and some awkward to get at items needing greasing at 3k intervals. Things like contact breaker points failing, spark plugs furring up, carburettor jets blocking.
Serious rusting on relatively young cars, brakes that took a long time to stop you at speed, etc.
Electrics that couldn’t keep up with demand.
I could go on and on but will resist the temptation.
Modern cars are (comparatively) quite brilliant, I look at all the big covers under the bonnet and think yes Better check the oil because I can see everything else through the containers.
Edited By V8Eng on 19/12/2018 12:59:35
Circlip19/12/2018 13:09:45
915 forum posts
Best car I had, Ford Escort 1.6D (CAV engine) 54mpg when I bought it, 70k on clock, 54mpg 7years later with 150k on clock. Only engine fault in that time, new water pump. Body corrosion was problem. Modern motoring later was new Punto, 10k and 2years, new exhaust, dealer said the exhaust didn't have time to heat up to "Dry out" between runs, (Right angled bend at bottom of pipe where it rotted out didn't help either). 25k., dash light with engine picture on it and misfire informed the garage that ONE of the coil packs(?) had gone down, two on it, each serves two cylinders. Went back to garage a few times when light came on despite both coil packs being replaced. Transpires that when the coil goes down, it bu***rs the ECU! NEW one from Germany, more than £500, latest version fitted to Punto before model change. Replaced it at 35k with a Sandero (Renault really) 4 years old with 12k. When "Tested" this year I'm informed that "We tested the water content in the brake fluid and the fluid needs replacing"
First time in 55 years of motoring that I've been hit with that one. It was the main agents testing it, so it MUST be right.
Regards Ian.
Peter G. Shaw19/12/2018 13:41:34
943 forum posts
39 photos
Yes. And all the short term servicing that went with them. Along with crossply tyres, rear wheel drive, poor heaters, low power headlights etc.
But, at the same time, less red-tape, fewer restrictions, fewer vehicles on the road, no motorways, death trap 3 lane roads. Motoring then was fun. Mind you we were much younger then as well.
Yes, although home servicing was simple and easy (perhaps as well considering the reliabiity issues), today's cars are much better in all sorts of ways, so being unable to DIY, is a small price to pay.
Peter G. Shaw
Swarf Maker19/12/2018 13:46:27
62 forum posts
4 photos
Yes, they probably are. Brake fluid is hygroscopic and the water content that it attracts leads to internal corrosion of the hydraulic parts. It's a good and useful test to carry out and should be done fairly regularly. Surprised that you have not come across it before!
not done it yet19/12/2018 13:57:52
2708 forum posts
11 photos
Is that an MoT failure? Is it a main dealer? You only need to search on U-toob to find that a lot of places don't actually do what they charge for. The last time my local repairer bled my brakes, I supplied the brake fluid.
I might just be inclined to nearly empty the fluid reservoir and top up with fresh fluid. If the dealership/repairer actually change it, I would be checking that each bleed screw had been at least bled a bit.
Yes. I would chase most of the fluid back from the calipers, to maximise the fluid changed. This could be done several times a year at far less cost than the dealership 'changing' the fluid just the once! Just mind the paintwork if it has the old type of fluid (almost certainly has, as the silicone based fluids are not hygroscopic). Robbing (pub) landlords, some of them.
Michael Gilligan19/12/2018 14:54:44
12752 forum posts
552 photos
Posted by Circlip on 19/12/2018 13:09:45:
It may, or may not, be relevant to your vehicle but the problem is a genuine one.
Water lowers the boiling point of the fluid:
https://www.alsglobal.com/services-and-products/oil-fuel-and-coolant-analysis/brake-fluid-testing
Colin Heseltine19/12/2018 19:34:47
254 forum posts
54 photos
The comments about driving hard to clear blocked filters reminds me of an occurrence a fair few years ago. Mt In-laws had a 2 litre diesel Granada which was blowing lots of black smoke out. They want to know what the issue is. I persuaded them to let me take it for a drive. I bought it back 20 mins or so later having thrashed the b....x of it in second and third gear along the main road near me. No longer any black smoke and its performance (such as it was) was restored. The injectors were blown nice and clean.
I must admit I regularly give my 2 litre Mondeo similar treatment and have done so with the previous few diesels. It regularly gives me 44 to gallon and on longish trip like this morning (130 miles each way) returned 53mpg.
I sometimes long for the old days sorting out carburettors and ignition systems, doing engine rebuilds. I have just put a programmable ECU on my Caterham7 and although I have not done the programming on it ( a much more skilled and knowledgeable person did this bit), it is amazing to plug the laptop in and watch what actually happens ignition and fuelling wise as the engine revs up and slows down again. I was quite entertaining trying to wok out why when I lifted off the throttle the engine would keep a nice steady 2300rpm up. This was a little unnerving on the M6 in heavy evening traffic. I had to do a lot of tests capturing engine data from the ECU to send to the manufacturer or him to suss out the issue.
The brake fluid requiring changing is something that has been around since I started working on cars back in early 1970's. Lots of high speed braking and the fluid can boil. As soon as it boils NO BRAKES.
Colin
Alan Waddington 219/12/2018 21:56:12
410 forum posts
86 photos
Haha, all this moaning about new technology, and extolling the virtues of simpler times....yes old stuff is cool, but new stuff is infinitely better.
For example 20 years ago i could service my van on the drive, but it wouldn’t pull the skin off a rice pudding, was rattly, uncomfortable, had candles for headlights, did 20 to the gallon on a good day and was generally crap.
In comparison the current van has things under the bonnet which i dont even recognise, but has 204bhp, stops on a sixpence, is quiet and comfortable, with headlights that light the future, does 35 to the gallon and is generally fabulous.
Would i swap for the old one.........err let me think about that for a nanosecond thinking
Trevor Crossman 119/12/2018 23:23:54
125 forum posts
15 photos
Modern cars,vans and motorbikes are indeed many ways a fantastic improvement over the leaky,rattly rubbish that I had in my youth, but I'm not sure about the ''greenness'' of modern motors due to parts being shipped to and fro across the globe before final assembly. By co-incidence a Guardian article today shows how a (BMW) Mini crankshaft starts as a casting in France, arrives and is worked on at a plant in England, sent to Germany for fitting into the engine, which is returned to another plant in England to be fitted to the car. The same sort of process must be going on for many other components and for other manufacturers, so how can 'global' manufacturing be better for the environment than 'local', though of course it may well be deemed to be 'more efficient' by the bean counters that control most things these days.
Trevor
clogs20/12/2018 07:03:27
442 forum posts
12 photos
just to add,
practically all modern vehicles never have major mechanical problems.......it's the cxap electronics that let the side down.......that's because somehow the know nothing accountants have got control....I'm guessing that most of the electronics is made in a shed somewhere in China....BUT IT'S CHEAP......!!!!!!
long gone of the days when cars were tested for 1/2 million miles before they got into productin......now, some hairy moron just outta uni setting up a computor program tell's us it'll work OK......there should be mandatory warranty on all automotive electronic's for 100,000 miles .....no more problems....eh........
mentioning no names, I did prototype work on a high power wind turbines, told management there was a design problem.....was told the computor says it'll be OK....and what the xxxx did I know about anything......3 months down the line a major disaster and a refit to each turbine cost £600,000 each......Managemnet and Accountants....bahhhhhhh....
on Trevor's point, there's a certain ladies knicker manuf that sends the cut material to Turkey for the sowing to be done .........by truck.......!!!!!!!!!..very green and OTT.......
on my old vehicles,
as the Citroen is show and go so it has an alternator.....actually off a Kubota tractor re-machined and fitted inside the old 3 wire dynamo..... so the "anarack's" wont notice......
the distributor was totaly rebuilt but with a 2 wire electronic ign system.....Brakes have modern linnings so they work a little better....just.......hahaha......
as for the greasing I quite enjoy it but I have a commercial grease gun on a hose with a large bucket of grease with the whole thing on casters plus a 2 poster car lift....
nobody mentioned CD players but all mine get a decent radio with some sort of modern connector so I can plug in my I-POD......but thats now old tech........hahaha......
job for next year, client wants a modern 16valve (black) Ford Focus petrol engine in a MKII Escort.......absolutly no ECU....carbs off a Kawasaki, distributor from a MkIII Escort.....there u go.........
All the best of the new and the old....
wishing you all the best for the festivities and a special thanks to the moderatorator's for giving their time......
HAVE A GOOD ONE.........Clogs
Ady120/12/2018 07:59:20
3462 forum posts
513 photos
I know thrashing the backside off an older diesel worked in years gone by but I'd be a bit uneasy about doing it on a modern unit full of bells and whistles
Life was easier when it was only the fuel, the compression and a drainpipe at the back
FMES20/12/2018 09:36:25
548 forum posts
1 photos
Reading the thread about combi boilers makes me think that saving the planet is becoming a bit silly, I dont disagree with the basic premise but its costing us individuals lots of money.
I'm collecting my car from the dealer garage tomorrow where its been for the last week because the Catalytic Converter light came on followed by the management light, the traction control and cruise control also failed all because of the DPF failing and it failed because I who prides himself in acheiving the best MPG, doesnt break speed limits, doesnt thrash his car enough to burn the filter clean, so trying to save fuel and drive carefully is about to cost me £507, basically I give up and whats the point of trying.
Rant over.
Martin P
FWIW, cleaning a DPF both active or passive does not require the breaking of speed limits, more the use of higher revs over a period of time.
Most DPFs dont start to clean until the gas flow through them is high enough, on Peugeot / Citroen for instance its at 2400 Rev/min, which as most would accept would be well in excess of the national limit in top gear.
So don't use top gear - you can bring the revs up in a lower gear ins cruise, it won't harm the engine but even so it can take upwards of 20 minutes at those revs to produce a full clean.
Normally when a DPF blocks you will get plenty of warning before the CAT fails and there are now a number of businesses that will remove the DPF, and pressure clean it to good effect for about £60 (BMW X5) .
Ausee.com.au
TRANSWAVE Converters
