Forum sponsored by Allendale Until July 27th
3 cyl Pip engine
David Kenyon 217/12/2018 19:06:52
190 forum posts
144 photos
Hi , I recently built a 3 cylinder 'PIP' engine from plans purchased at LittleLocos.com. I wrote a build thread on another forum I use so I thought I may transfer it across to here. Bear with me as this forum works a little differently to the one I am used to.
First job is to make a 2mt taper with a 1/2 inch round boss on the end.
This will fit into my rotary table and my lathe nose and will enable me to
swap work pieces quickly while keeping them centred.
 Then machine a 1/2'' hole into my Cylinder blanks to fit the taper and also a 1/4'' grove
to use for holding clamps. I am making four cylinders so I have a spare in case something
goes wrong. The Cylinders are the most complex part apparently.
You can see the taper fitted into the last blank.
The first blank is mounted to the lathe using the taper and face plate.
First job is to open out a bore to .75'' , the combustion chamber is formed by a standard
118 degree 11/16 drill bit then the bore is opened out to .75 ready to fit a steel sleeve
later in the build.
The outside shape of the Cyl is then formed by turning a 30 degree taper leaving
a mounting boss on the end.
Edited By David Kenyon 2 on 17/12/2018 19:09:57
Edited By David Kenyon 2 on 17/12/2018 19:37:44
JasonB17/12/2018 19:12:39
15536 forum posts
1594 photos
1 articles
David once you paste the text from the other forum you will need to go through it and remove the IMG codes and cut and paste the URL between them into the Image icon at the top of the editing screen.
I'll do what you have already posted as you may not be able to get back to edit it.
EDIT, looks like you got there first
Edited By JasonB on 17/12/2018 19:16:41
David Kenyon 217/12/2018 19:20:50
190 forum posts
144 photos
Hi , yes realised this forum works differently so I am just working things out so I can post the pictures.
David Kenyon 217/12/2018 20:11:28
190 forum posts
144 photos
I ground a slight taper onto a 3/32 parting blade and rounded the end. This was used
to cut the fins and also reduce the thickness of the boss .
The DRO I fitted recently was a godsend for this job.
First one done , just another three to do
The 2mt was removed from the lathe and fitted to my rotary table then centred on my mill.
First cylinder fitted and the eight [2mm ] mounting holes drilled in the boss
Emgee17/12/2018 20:55:44
1113 forum posts
201 photos
Interesting topic, keep posting please.
Emgee
David Kenyon 218/12/2018 19:02:40
190 forum posts
144 photos
The rotary table is set up horizontal on the mill table and a milling cutter is used to
mill through the first two fins opposite each of the eight mounting holes.
This provides clearance for the mounting screws to be fitted later.
David Kenyon 218/12/2018 19:29:30
190 forum posts
144 photos
That's all the work from the bottom of each cylinder so I now part off each one from its mounting.
One mounting is then drilled and tapped m2 to match the cylinder boss and this will be used
for mounting the cylinders for future work on the top end.p1030342 (medium).jpg
David Kenyon 218/12/2018 19:36:17
190 forum posts
144 photos
Had to make a jig to hold the Cyl for the top fins to be cut.
This consists on a large chunk of alloy rod with an expanding mandrel
David Kenyon 218/12/2018 19:37:21
190 forum posts
144 photos
here you can see the set up with a cylinder bolted and the mandrel tightenedp1030344 (medium).jpg
David Kenyon 218/12/2018 19:38:09
190 forum posts
144 photos
David Kenyon 218/12/2018 19:42:09
190 forum posts
144 photos
The same form tool is then used to cut the fins. The lathe is set to 70 rpm using the back gear and
the tool is fed in slowly whilst lubricating with oil. Took ages but quite satisfying listening to the tool
Ady118/12/2018 23:20:43
3463 forum posts
513 photos
You may find a lack of replies disconcerting at first, it's so we don't clutter a good build thread like this one
JasonB19/12/2018 07:52:55
15536 forum posts
1594 photos
1 articles
You are making good progress, I had to double check the drawings as I thought the fins were running the wrong way but the curved top runs front to back as the cylinder gets turned through 90 deg after machining the fins.
David Kenyon 219/12/2018 15:12:13
190 forum posts
144 photos
Posted by Ady1 on 18/12/2018 23:20:43:
That's ok, I am copying and pasting from another forum so it easy enough now I have sussed the pictures.
The other forum was not an engineering forum so you may find some of the explanations a bit brief / simplistic.
David Kenyon 219/12/2018 15:22:27
190 forum posts
144 photos
With the lathe work complete the next step is to machine the holes for the
valve guides and hot plug using the mill.
The holes will need drilling radially at a 30 degree angle and enter the tight combustion
chamber accurately.
To help me set up the drill I had to make another jig seen below with a cylinderp1030353 (medium).jpg
David Kenyon 219/12/2018 15:33:20
190 forum posts
144 photos
The jig is a copy of the internal bore and combustion chamber shape and is set up on the mill
at a 30 degree angle so the top is level . A taper is drilled dead centre of the flat using a centre drill
and this is then used to centre the jig on my mill as blow.
David Kenyon 219/12/2018 15:37:15
190 forum posts
144 photos
So with the first cylinder fitted in place of the jig I set the table to zero degrees
and line the top fins so the drill enters dead centre.
First hole is for the glow plug, a mill is used to turn down the fins until a flat is
formed on the cylinder head, then centre drill , drill and finally tap 1/4 - 32 thread.
David Kenyon 219/12/2018 15:38:26
190 forum posts
144 photos
The table is turned 120 degrees ready for drilling the valve guide seat. This is a bit more involved.
First mill a flat, then drill 7.6mm, ream 8mm, then drill down 9mm but stop about 1/16'' from the bottom.
Then tap M10 fine, again just short of the bottom. A 45 degree taper will be cut on the shoulder at the bottom
were the m8 is left.
The table is turned another 120 degrees and the second valve guide seat is cut.p1030466 (medium).jpg
David Kenyon 219/12/2018 15:39:40
190 forum posts
144 photos
I then had to turn some threaded posts for the rocker arm pivots. They are just Silver steel with an M3 thread. p1030497 (medium).jpg
David Kenyon 219/12/2018 15:43:39
190 forum posts
144 photos
Remember the set up on the mill was turned 49 degrees , that is because the rocker posts are
fitted at a 49 degree angle from the valves.
So while centred over the valve guide I offset the table 0.344'' and drill / tap a m3 thread, a post is
screwed in with permanent Loctite and then a slot is milled to accept a rocker. p1030478 (medium).jpg
Ausee.com.au
Meridienne Sept 2019
TRANSWAVE Converters
