Forum sponsored by Allendale Nov 29
What material is it
Hopper17/12/2018 03:03:17
3074 forum posts
50 photos
Posted by martin perman on 16/12/2018 13:47:24:
... I've just given up trying to drill a hole through a slice I cut off, its wearing out brand new drills without hardly making a cut, the drill just polishes the metal.
Did you try slowing the spindle speed way down? And drilling a small pilot hole first?
If so, you may need to anneal the bronze before trying to cut or machine it.
Edited By Hopper on 17/12/2018 03:03:50
martin perman17/12/2018 08:21:52
1404 forum posts
60 photos
Gentlemen,
I'm doing this as a favour for a friend and its costing me money, three worn out and broken bandsaw blades, and time trying to machine, for me, the impossible. I dont have or use HSS tooling.
I've now asked my friend to source some different material.
Martin P
Brian H17/12/2018 08:33:11
961 forum posts
74 photos
Another way to identify it is to try and silver solder it. If it's ali-bronze, it won't.
Don't ask me how I know!
Brian
Nicholas Farr17/12/2018 09:23:27
1711 forum posts
868 photos
Posted by Brian H on 17/12/2018 08:33:11:
Brian
Hi Brian, I don't quite agree with you, below is a photo of a Ali-Bronze block Silver soldered to a Brass plate, that I did about 30 years ago. I don't know the grade of the Ali-Bronze, but I do know it is Ali-Bronze, it was hacksawed, filed and drilled from a worn out Ali-Bronze nut.
Regards Nick.
Edited By Nicholas Farr on 17/12/2018 09:26:53
John Reese18/12/2018 02:52:02
614 forum posts
JohnF,
Thanks for suggesting an off center point on the drill. It solves the problem of the hole tending to close around the bit.
mark costello 118/12/2018 20:54:05
470 forum posts
10 photos
Could be Beryllium Copper.
méridienne Nov 18
Ausee.com.au
TRANSWAVE Converters
