martin perman | 15/12/2018 20:32:32 |
![]() 2046 forum posts 86 photos | Gentlemen, I am machining a brass like material but I'm certain it isnt brass because when I've machined brass in the past it comes off in small needle like swarf where as this comes off in streams of swarf like steel and anything larger than a 0.5mm the lathe groans greatly, Any Ideas please. Martin P |
daveb | 15/12/2018 20:52:04 |
626 forum posts 10 photos | There are different grades of brass, some alloys are hard, some are ductile. It could be bronze. There are different grades of bronze. Sometimes difficult to tell one from the other. Daveb |
colin hawes | 16/12/2018 09:56:47 |
558 forum posts 18 photos | Aluminium bronze, horrible stuff to drill. Colin |
I.M. OUTAHERE | 16/12/2018 10:05:58 |
1468 forum posts 3 photos | I know the brass they make amunition out of is gummy stuff so you may have a grade of brass that is designed for forming . |
JohnF | 16/12/2018 10:19:25 |
![]() 1152 forum posts 190 photos | Plus 1 for Aluminium Bronze machined a lot of this in the past and as Colin also say’s it’s difficult to drill, grabs the drill if you are not careful. One other point don’t use it as a bearing material (bushes) it is totally unsuitable— I know this from experience with a small engine I was repairing many years ago. Edited By JohnF on 16/12/2018 10:22:30 |
martin perman | 16/12/2018 10:31:29 |
![]() 2046 forum posts 86 photos | Thanks gentlemen, I'm making four 75mm dia rollers for a mates butter churn, to support the drum and decorative only. Its a bugger to cut on my band saw also. Martin P |
vintage engineer | 16/12/2018 10:54:10 |
![]() 258 forum posts 1 photos | Ali-bronze! It's s**t! Edited By Neil Wyatt on 16/12/2018 13:05:19 |
not done it yet | 16/12/2018 11:00:11 |
6812 forum posts 20 photos | Look up ‘copper alloys’ on Wiki and take your pick! |
colin brannigan | 16/12/2018 11:00:56 |
108 forum posts 18 photos | Ali bronze is worse than s**t!! Edited By Neil Wyatt on 16/12/2018 13:05:29 |
I.M. OUTAHERE | 16/12/2018 12:30:47 |
1468 forum posts 3 photos | What tool geometry are you using ? |
Nicholas Farr | 16/12/2018 12:52:12 |
![]() 3361 forum posts 1543 photos | Posted by vintage engineer on 16/12/2018 10:54:10:
Ali-bronze! It's s**t! Hi, sorry, but I beg to differ. Regards Nick. Edited By Neil Wyatt on 16/12/2018 13:05:38 |
Neil Wyatt | 16/12/2018 13:06:37 |
![]() Moderator 19040 forum posts 734 photos 80 articles | Mind yer language please folks! The only sticky brown stuff on this forum comes from trees Neil |
martin perman | 16/12/2018 13:47:24 |
![]() 2046 forum posts 86 photos | Posted by colin hawes on 16/12/2018 09:56:47:
Aluminium bronze, horrible stuff to drill. Colin I would beg to differ, I've just given up trying to drill a hole through a slice I cut off, its wearing out brand new drills without hardly making a cut, the drill just polishes the metal. My mate is going to have to find a different lump of brass or go back to plan A and use steel. I've just done a test on a lump of brass I have on my saw, the un machinable lump 95mm dia took three hours to cut a slice, my piece is 65mm and the saw was half way through in no time at all with the same blade. Martin P |
not done it yet | 16/12/2018 14:02:38 |
6812 forum posts 20 photos | Posted by colin hawes on 16/12/2018 09:56:47:
Aluminium bronze, horrible stuff to drill. Colin I hope it is not difficult. I had a casting made by my local foundry some years ago. It turned very nicely and I have about 40 small holes to drill very accurately (to make an exact copy of an original part) and some of them will need tapping and countersinking. |
Alan Johnson 7 | 16/12/2018 16:53:11 |
115 forum posts 16 photos | Have you tested your "brass" with a magnet? Some bonze has an iron content, and therefore magnetic. It may narrow your search. You could do the Archimedes Test...... Place sample in water, measure displacement, and weigh sample. Again it could narrow your search. |
Alan Johnson 7 | 16/12/2018 17:08:02 |
115 forum posts 16 photos | I should have added.. Archimedes Test will yield Kg per cubic metre. Known bronze and brass list this. |
colin brannigan | 16/12/2018 17:09:39 |
108 forum posts 18 photos | Sorry Neil |
not done it yet | 16/12/2018 18:25:12 |
6812 forum posts 20 photos | Posted by Alan Johnson 7 on 16/12/2018 16:53:11:
Have you tested your "brass" with a magnet? Some bonze has an iron content, and therefore magnetic. It may narrow your search. You could do the Archimedes Test...... Place sample in water, measure displacement, and weigh sample. Again it could narrow your search. I would not expect a simple ‘Archimedes test’ would do more than reject the extremes of density, particularly if other elements are present. Might just as well weigh in air and water to calculate, unless of very uniform and measurable dimensions when the volume could be accurately assesed. For decently accurate results, I would be using the turnings/chips and an SG bottle, along with an assay balance... Possibly a phosphor bronze? |
Neil Wyatt | 16/12/2018 20:32:16 |
![]() Moderator 19040 forum posts 734 photos 80 articles | Aluminium and copper make some interesting alloys. Small amount of copper in aluminium is pretty much duralumin. Small amount of aluminium in copper is aluminium bronze, but the more ally added, the harder it gets. By around 50:50 you get a grey alloy that shatters if you hit it with a hammer. Hard to machine aluminium bronzes may have more aluminium than intended. Neil P.S. at our astro club Christmas quiz a question was 'what metals make Bronze'. It was tempting to answer copper and anything other than zinc, except when it's got zinc in it... |
JohnF | 16/12/2018 23:58:13 |
![]() 1152 forum posts 190 photos | Martin, as Neil says aluminium bronze comes in different alloys, it is difficult to machine but certainly not impossible and it is also highly corrosion resistant. The components I was machining many years ago were for submarine seawater services [corrosion resistant ] and were for want of a better description "very large plumbing fittings" pipe diameters of 6 to 12 inches, large flange's on castings to be machined then drilled and tapped or drilled and spot faced. The factory also produced other components from bar stock. Sharp HSS tools are the order of the day and increase the top rake a little, for drilling, thin the point to ease the process and grind VERY slightly offset so it cuts slightly oversize -- do not alter the flute rake as for brass. The best cutting medium is suds, it can generate a lot of heat when cutting. Your tools must be sharp ! I have machined this material successfully on my Myford with correctly ground tools etc. John |
