Sealer for bare steel.
Sealer for bare steel - matt finish
Former Member07/12/2018 20:02:34
1329 forum posts
JasonB07/12/2018 20:05:57
18915 forum posts
2082 photos
Metal Guard, it is a much thinner coat than lacquer so you can't tell it's there
Former Member07/12/2018 20:18:04
1329 forum posts
mike T07/12/2018 20:28:27
173 forum posts
Lanolin is a very good long term preservative for bright steel and other metals.
And you don't have to go to Arc to get it.
Neil Wyatt07/12/2018 22:35:28
18246 forum posts
714 photos
77 articles
Posted by mike T on 07/12/2018 20:28:27:
Indeed, just rub your Mamod on a passing sheep...
mike T07/12/2018 22:50:49
173 forum posts
Posted by Neil Wyatt on 07/12/2018 22:35:28:
Quite so, proves the point. Have you ever seen a rusty sheep
Phil P07/12/2018 22:55:50
658 forum posts
166 photos
I just had to google it ..............
http://kilchoan.blogspot.com/2015/07/rusty-sheep.html
Phil
JasonB08/12/2018 07:07:14
18915 forum posts
2082 photos
Posted by mike T on 07/12/2018 22:50:49:
No, but have you seen all the fluff that gets stuck to them!
Does the lanolin stay oily/waxy? as that may not be ideal inside where the item may collect dust, the metal guard dries so you don't get that issue.
Andy_C08/12/2018 07:38:08
30 forum posts
8 photos
Renaissance Wax was recommended in ME some time ago for conserving clocks once polished. Worked for me - no links just satisfied customer. Also apparently used in antique metal conservancy by stately homes.
John Paton 108/12/2018 15:27:20
283 forum posts
17 photos
Might be worth trying Owatrol or Ambersil. Ambersil is a great rust preventer but leaves a rather dull and slightly tacky finish. Owatrol leaves a very thin film but dries to a reasonably hard finish and can be overpainted.
AJW08/12/2018 16:19:59
306 forum posts
121 photos
Dinitrol used to produce a wipe on type of lacquer.
Alan
Edited By AJW on 08/12/2018 16:20:20
Phil P08/12/2018 16:37:01
658 forum posts
166 photos
I am planning on using this product on the vulnerable areas of my Morris Traveller.
https://www.bilthamber.com/corrosion-protection-and-rust-treatments/dynax-s50
Phil
Andrew Evans08/12/2018 21:09:16
329 forum posts
8 photos
Dynax S50 is good stuff but it leaves a visible waxy coating.
Mark Rand08/12/2018 22:28:32
924 forum posts
6 photos
I would vastly prefer to see them in their original colours. If bare metal is preferred and the surface finish has been cleaned up to the point that it's acceptable, then get the parts nickel plated (not chrome). That will look good and will last longer than a varnish.
pgk pgk08/12/2018 22:52:32
1914 forum posts
288 photos
My pet sheep enjoy being rubbed.. so available for hire.. just watch out for the burs and brambles they like to collect....
pgk
Phil P08/12/2018 23:01:42
658 forum posts
166 photos
I was wondering about the merits of nickel plating the bright metal work on my model corliss engine, has anyone tried the DIY kits that are available with any success, and consistency of results ?
Phil
Chris Trice09/12/2018 02:12:52
1362 forum posts
9 photos
Not tried any home kits but have used this company a lot. They can plate 3D prints in copper (which strengthens them considerably) and then nickel giving a perfect chrome appearance as well as the more usual metal items.
http://morganicmetalsolutions.com
Ian S C09/12/2018 10:36:59
7468 forum posts
230 photos
If the model is going to be display only, hair spray works ok, bit smelly.
Ian S C
EngineDIY
