Vickers Bl 8 icnch Howitzer
mal webber | 06/12/2018 22:15:43 |
![]() 141 forum posts 294 photos |
here are a couple of pictures of were i'am at, going to build chassis first and work it out from there . |
ronan walsh | 06/12/2018 22:18:06 |
544 forum posts 32 photos | Very good, i will watch with interest. |
Thor | 07/12/2018 05:23:41 |
1324 forum posts 40 photos | Hi Mal, You have made a good start so far, looking forward to see the rest of your build. Thor |
David George 1 | 07/12/2018 07:37:44 |
![]() 1429 forum posts 456 photos | Thanks Mal for posting different model's but how do you go about creating such items like the trail hitch is it a casting or is it made by fabrication for instance. Great work, keep the pictures coming. David |
Brian H | 07/12/2018 08:22:14 |
![]() 1964 forum posts 108 photos | Thanks for posting something out of the ordinary Mal, it's looking good. Brian |
mal webber | 07/12/2018 18:41:39 |
![]() 141 forum posts 294 photos | Hello all Thanks for the interest in the build, this is a first for me to build a model with no plans so lots of mistakes will be made no doubt ,David no castings will be made for this build has i have not got the expertise in any sort of casting or pattern making, the trail hitch in the picture is made from 4mm flat plate with some fabrication to make it look a bit like a cast peace which is on the full size Howitzer. Thanks Mal. |
Ron Laden | 07/12/2018 18:50:19 |
![]() 2073 forum posts 411 photos | Glad you have started a build thread on this Mal, I will follow with interest as its nice to see something different. Ron |
Paul Kemp | 07/12/2018 20:35:16 |
589 forum posts 18 photos | Mal, That drawbar looks excellent, is it a fabrication? Paul. |
Neil Wyatt | 07/12/2018 20:36:21 |
![]() Moderator 18409 forum posts 718 photos 78 articles | Looks good, the sort of model I want to tackle some day! Neil |
mal webber | 07/12/2018 20:50:52 |
![]() 141 forum posts 294 photos | Posted by Paul Kemp on 07/12/2018 20:35:16:
Mal, That drawbar looks excellent, is it a fabrication? Paul. HI Paul thanks for the interest it is fabrication out of 4 mill plate and i tried to make it look like a casting. Mal. |
Vic | 07/12/2018 22:15:29 |
2685 forum posts 1 photos | Good start Mal. Looking forward to seeing the work on the barrel. |
Paul Kemp | 07/12/2018 23:57:49 |
589 forum posts 18 photos | Posted by mal webber on 07/12/2018 20:50:52:
Well you have nailed that! Very nice work, looks every bit like it is cast. Well done. Paul. |
ronan walsh | 08/12/2018 15:55:40 |
544 forum posts 32 photos | Have you looked for original drawings ? Maybe the Imperial war museum or the Tank museum in Bovingdon could help ? |
mal webber | 08/12/2018 22:46:01 |
![]() 141 forum posts 294 photos | Thanks Ronan did not cross my mind to look for plans from a museum, think i have enough info of the internet to go on at the moment but will bear that in mind if I get stuck on something.
Thanks Mal. |
mal webber | 09/12/2018 22:52:19 |
![]() 141 forum posts 294 photos | Hello all , little bit more done on the trail for the howitzer cannon ,no machining work for a while but plenty of fabrication work to be done, so made some brackets that rivet on the side of the trail that the spade or thrust plate bolt on to, didn't show how these were done as its just a bending of some steel with holes drilled in to them .
mal webber | 12/12/2018 22:41:37 |
![]() 141 forum posts 294 photos | Hello all. thought I would keep the pictures coming no matter how small the progress is , so bit more done on the howitzer chassis, limber rubbing plates done and riveted on and cross beam [ the limber is the cart that was towed in between the howitzer and the vehicle that would be towing the cannon and these plates are for wheel rubbing on sharp turning , there is a rear cart as well for the firing platform , any way holes drilled on top plate ready for rivets and the wood blanks for under foot grip.
Edited By mal webber on 12/12/2018 23:02:06 Edited By mal webber on 12/12/2018 23:02:44 |
Buffer | 13/12/2018 08:20:29 |
211 forum posts 84 photos | Mal Great work, how are you going to make the breech interrupted screws? Rich
Mick B1 | 13/12/2018 09:22:40 |
1801 forum posts 91 photos | Posted by Richard brown 1 on 13/12/2018 08:20:29:
More difficult in the breech ring than the plug, I'd think... > |
mal webber | 13/12/2018 10:09:40 |
![]() 141 forum posts 294 photos | Posted by Richard brown 1 on 13/12/2018 08:20:29:
Hi Rich , thanks for the interest will cross that bridge when I get to it, plenty of time to think about it .
Thanks Mal.
mal webber | 14/12/2018 23:56:14 |
![]() 141 forum posts 294 photos | Hello all ,small move forward on the trail chassis for the Howitzer, hope those who are interested don't mind small update progress ,but like I said I'll keep the pictures coming ,well some rivets done [some false some threaded rivets due to angle and not possible to do so in places,plus not necessary ] any way photo 1 added spade holder, photo 2 is the next part to be fabricated marked out in the circle, next couple of photos is how I wen't about it.
Thanks Mal. |
