Forum sponsored by Allendale July 23rd
z axis arduino
arduino not loading program
peter ravenscroft02/12/2018 13:38:16
85 forum posts
hi has anyone tried to up load the program (sketch ) for the z drive in mew no 275 as i can not get it to load keeps coming up with error all the time
regards
peter
John Rudd02/12/2018 13:50:20
1365 forum posts
58 photos
Peter,
What errors are you getting? Can you post a screen dump of them? I havent got the issue or the code so cant say immediately..
What flavour of board are you using, Uno, Nano, 2560...... Any com port errors?
Edited By John Rudd on 02/12/2018 13:51:30
peter ravenscroft02/12/2018 14:02:17
85 forum posts
hello
the error i get is
exit status 1
error compiling for board arduino/ genino uno
it will load the the script with hello- world so know it is comunicating with the board and loading i think there is an error in the program
regards
pter
SillyOldDuffer02/12/2018 14:25:28
4527 forum posts
971 photos
Hi Peter,
The error messages are probably hidden because the pane at the bottom of the IDE screen is minimised. You can see more by dragging it. Find the upper boundary with your mouse (cursor changes to a down arrow and line) , then click hold on it and drag upwards.
However, easier way to share. There's a button two thirds of the way down on the right marked 'Copy Error Messages'. After clicking on that you can paste (ctrl-v) whatever it catches into a forum reply and we can look at the gory details in full.
Neil Wyatt02/12/2018 14:27:10
16254 forum posts
679 photos
74 articles
The original project that Chris got the code from is here on Martin Raynsford's website:
msraynsford.blogspot.com/2014/03/z-axis-controller-replacement.html
And here's a link from that page to the source code:
drive.google.com/file/d/0ByhmPLslpgYKblJjVDdmNzNOemc/edit
SillyOldDuffer02/12/2018 15:16:06
4527 forum posts
971 photos
Just compiled the original code successfully for a Uno with Arduino 1.8.5. There's a warning about comparing signed and unsigned integers otherwise completely clean. The Warning probably doesn't matter.
I see the sketch uses the TimerOne-R11 library which may not be installed on Peter's machine yet. In the Sketch tab, look for it in the Include Library dropdown list. If it's not there go to the top of the same list and select 'library manager'. This opens a search facility that finds, downloads, and installs libraries for you with a few clicks.
Chuck Pickering02/12/2018 15:29:40
36 forum posts
I agree with Dave. I also just loaded the sketch to an Uno and uploaded with no errors. But, I have the TimerOne-R11 library installed...
peter ravenscroft02/12/2018 16:14:59
85 forum posts
thanks to all who replied
the reason it would not load was the timerone was not installed i have installed it and loaded it ok
thanks again Dave for comming to my rescue
John Rudd02/12/2018 16:54:32
1365 forum posts
58 photos
Yup, the first line of code is a major clue...timerone-r11 library
More often than not if there are non-included libraries used, will give rise to an error....if they are not present in the ide. Ask me how I know..,lol.. surprise
Good to hear you are sorted..
Edited By John Rudd on 02/12/2018 16:54:57
TRANSWAVE Converters
Meridienne Sept 2019
Advertise With Us
