Parallel Machine Files
Supplier in UK ?
Smike25/11/2018 23:32:39
4 forum posts
Trying to locate a supplier in UK for files for my bench filing machine. Any ideas anyone ?
thanks for your help
Brian Wood26/11/2018 08:50:39
2186 forum posts
37 photos
For round files, use chainsaw files. As for others, you will have to research those yourself
Neil Wyatt26/11/2018 10:08:56
17891 forum posts
706 photos
77 articles
They are very hard to source in the UK, most people resort to importing from the US. It might be possible to buy direct from a Swiss manufacturer.
daveb26/11/2018 19:02:46
622 forum posts
10 photos
You need to search for PARALLEL MACHINE FILES. Good luck with that!
I had the same problem about 12 years ago, easier to get bull feathers! I eventually bought some from Federal file co in the USA for my bench machine (files, not feathers), they are a similar size to Swiss files. (I have an unused set of these PM if interested). I could not find any new or used files for my large filer so I bought a set of Swedish files (no particular reason for buying Swedish except the shop had a set in stock that looked as if it would do) 12", round, flat, square, tri, half round, etc. I cut off the non parallel parts and ground the ends to fit my machine, 60 degree point at bottom, 1" square tang at top to fit chuck, cuts on down stroke. Medium or coarse files are better, you will die of old age if you use fine files on these machines. If you haven't used a filing machine before, hold downs are essential if you value your fingertips.
Harold Hall designed a small filing machine some years ago, he made some suggestions on modifying standard files, should be some info on his website. Daveb
Colin G28/11/2018 09:13:11
24 forum posts
‘Smike’ I sent you a message 2 days ago, still unread.
Please log in on this site and go to your inbox. Colin
OuBallie29/11/2018 11:20:34
1149 forum posts
661 photos
Smike
Harold Hall has details of converting normal files to work on filing machines.
Geoff - Slowly recovering from my '111' ordeal early this year, and resulting 6 visits to hospital.
Edited By OuBallie on 29/11/2018 11:21:54
Edited By OuBallie on 29/11/2018 11:22:35
