RevStew | 24/11/2018 11:37:03 |
87 forum posts | Hi all. I'm considering a used Flexispeed Meteor 2. Apart from the usual, is there anything I need to know? More importantly, if wear exists, can it be rebuilt and how? It's purpose is to build a 2 1/2 or 3 1/2 gauge loco at the very most, amongst other smaller projects. Can new chucks be fitted to this machine? Your advice very much appreciated. Edited By RevStew on 24/11/2018 11:50:42 |
Neil Wyatt | 24/11/2018 14:16:49 |
![]() Moderator 18992 forum posts 734 photos 80 articles | It's a sort of Super Adept on steroids Worst case you can make a new headstock from cast iron or rebore for an oversize spindle. Very basic calibrated dials might mitigate against easily working to a high level of accuracy, especially if it is worn. Very dated now, but people did great things with them in their day. |
Michael Gilligan | 24/11/2018 15:10:02 |
![]() 20090 forum posts 1042 photos | If you are short of space ... This is well worth a look: **LINK** https://sites.google.com/site/flexispeedlatheinabox/ MichaelG. . See also: https://www.model-engineer.co.uk/forums/postings.asp?th=130342 The Cowells is of course a very well-respected 'Silk Purse' Edited By Michael Gilligan on 24/11/2018 15:17:10 |
Bazyle | 24/11/2018 18:51:13 |
![]() 6297 forum posts 222 photos | Although a nice little lathe and it would be possible to build a loco like the TIch on it I suggest it is really sized for clockmaking and model railways including garden railways. I Think if you are looking to build a bigger loco you should look for something like an old Drummond that is jus that bit bigger and more robust. |
Nick Clarke 3 | 24/11/2018 21:49:24 |
![]() 1394 forum posts 61 photos | If you are looking for lathe chucks you can buy backplates and machine them to accept commonly available chucks - but if you are looking for tailstock drill chucks looking at lathes.co.uk they appear to be 0MT which are harder to locate. As a simply built lathe it is possibly easier to renovate than some designs, but are these skills available to you? because paying someone else to do so could be expensive. A fully equipped Flexispeed Meteor 2 sold on eBay earlier this year for £835. This for a machine at least 40 years old is probably about the same as it would cost to buy and equip a modern mini lathe - except you will have to search for and perhaps modify or make parts and accessories instead of walking in off the street and buying them. As to whether it is suitable for the task you have suggested - probably, depending on the prototype you choose. Just checked the drawings for the 7 1/4" Tich and you could fit the wheels and cylinders on either lathe! The mini lathe may have a larger capacity, but if the flexispeed is backgear equipped it may be more suitable for turning wheel castings if they fit on the machine. Go figure! Edited By Nick Clarke 3 on 24/11/2018 22:01:03 Edited By Nick Clarke 3 on 24/11/2018 22:09:40 |
Nick Clarke 3 | 24/11/2018 22:28:03 |
![]() 1394 forum posts 61 photos | Although they would fit I am not of course suggesting it would be the most suitable design to make on lathes of this size!!!! |
john carruthers | 25/11/2018 08:38:47 |
![]() 614 forum posts 180 photos | Beware of a Meteor II that has been over revved, the plain bearings don't like it. |
James Alford | 25/11/2018 09:21:30 |
463 forum posts 79 photos | RevStew: I was given on of these for Christmas three or four years ago: it came from E-bay, but it would have been a lot less than £835 (probably about £180) although it did not have the screw-cutting gears with it, just the standard leadscrew. I have not made anything large with it yet, just small tools, an adjustable height tool post and an attachment for an an oil line for a car. I am pleased with it: it was not worn and everything works well. The biggest frustration is the difficulty in finding fitments for the headstock with the correct thread. Someone kindly sleeved and re-threaded a metric chuck for me and I have made my own collet holder which seems to be accurate. I also fitted a DTI on an arm to allow accurate turning, mainly because I struggled to read the calibrations on handwheels. Overall, a nice lathe which is easy to use and I am very much a beginner. James.
Edited By James Alford on 25/11/2018 09:22:18 Edited By James Alford on 25/11/2018 09:22:39 |
here again | 26/11/2018 13:24:03 |
66 forum posts | If you have trouble with 0mt arbors I found my new ones were a little slack .I ground the end off and just managed to tap it about 5mm and use a bit of studding as a drawbar.It just pulled it up unlike Lathe Bits on youtube who unfortunately had much more rattle on his. Also found the threaded arbor and a nice little bar operatex chuck with same thread from RDG/CHRONOS .As Lathe Bits I also bought 0mt reamers but they fit the tailstock as it is.Seems to be quite a varation in 0mt standards! |
Brian Oldford | 26/11/2018 14:13:16 |
![]() 686 forum posts 18 photos | The Flexispeed Meteor 2 is a complete heap of junk. Send it to me for safe disposal.
James Alford | 26/11/2018 22:02:46 |
463 forum posts 79 photos | Posted by here again on 26/11/2018 13:24:03:
If you have trouble with 0mt arbors I found my new ones were a little slack .I ground the end off and just managed to tap it about 5mm and use a bit of studding as a drawbar.It just pulled it up unlike Lathe Bits on youtube who unfortunately had much more rattle on his. Also found the threaded arbor and a nice little bar operatex chuck with same thread from RDG/CHRONOS .As Lathe Bits I also bought 0mt reamers but they fit the tailstock as it is.Seems to be quite a varation in 0mt standards! Do the 0 MT arbors which you have found fit fully or do they protrude a long way? The only items that I have found so far are too long to fit properly. James. |
here again | 26/11/2018 23:54:51 |
66 forum posts | Yes! You want narrow end only Available from Cowells I believe.Sherline? I have one but cant remember.I did phone to check which was right one -about ?20 you only want the right one.Or make your own! |
James Alford | 28/11/2018 07:05:49 |
463 forum posts 79 photos | Posted by here again on 26/11/2018 23:54:51:
Yes! You want narrow end only Available from Cowells I believe.Sherline? I have one but cant remember.I did phone to check which was right one -about ?20 you only want the right one.Or make your own! Thank you. James. |
