Allendale Group - Black Friday Sale
Machine-DRO23/11/2018 10:55:00
18 forum posts
25 photos
Morning all,
Black Friday Sale at the Allendale Group across all our stores, 15% off everything )
**LINK** Machine-DRO
**LINK** Machine-Tapping
**LINK** Ultrasonic Cleaners
**LINK** Flight cases
**LINK** Soldering tools
**LINK** Data loggers for RC models
**LINK** Arts and Crafts supplies
**LINK** Longbow Power tools
**LINK** Lyons Instruments
Please enter BLACK18 at checkout, offer ends midnight 25th November
Edited By Machine-DRO on 23/11/2018 10:56:49
Cornish Jack23/11/2018 14:27:49
988 forum posts
137 photos
DRO possibilities for a 'Sanity Clause' pressie to self ... but, which type??? Optical or Magnetic? Fitment would be to a D-W mill. Limited research suggests Magnetic - can anyone with experience or expertise advise, please?
rgds
Bill
Brian H23/11/2018 14:58:17
1389 forum posts
100 photos
Hello Bill, I bought one of Machine-DRO universal kits to fit my Graham Alpine DM-25 mill/drill on 2 Axis and it's brilliant. You get lots of brackets to enable fitment and the instructions are in English.
Cornish Jack23/11/2018 15:49:36
988 forum posts
137 photos
Thank you for the quick reply, Brian.
Which type of encoder, please - Magnetic or Optical ? Any reasons for choice?
rgds
Bill
duncan webster23/11/2018 16:11:40
2331 forum posts
34 photos
I fitted MDRO optical to my machines and they have been brilliant. They didn't sell the magnetic ones at the time. If I did it again I'd look at magnetic as they are smaller and would fit in better I think, in fact when I get round to doing the Z axis I'll look at using the existing X on the Z and a new one on the X
John Paton 123/11/2018 17:21:56
207 forum posts
6 photos
Hi Bill
I actually ordered an Easson 3 axis kit from Allendale this morning after a week's intensive research and price comparison. You might find my notes below of some use.
In fact I shall be sharing the Console between my Boxford and my Centec mill and am splitting the magnetic readers which come with the kit between the two machines. I have bought an additional short magnetic reader and an optical one for the mill which means I will get two axes on the lathe and 3 on the mill.
The logic in my final decision being:
1. I had promised myself DRO on the Boxford when i bought it (mainly to enable metric and imperial machining - and a kind 'token' from my dearest last Birthday for this).
2. Most people say Milling machine is more significantly improved by addition of DRO than a lathe is, even if just two axes so it was difficult to decide which to do first.
By sharing the console (just three connectors to unplug and plug in the other leads - the Easson Console is switchable between late and mill modes) it only mean the cost of a couple more readers. The Easson also has a nice LCD graphics display making it quite intuitive to use (Allendale kindly sent me a download manual to let me explore this). As far as I can see the only downside of the Easson is its plastic case (not aluminium as some others are) and separate power supply unit (some others take mains supply direct to the console)
3. Allendale DRO kit prices really help reduce the cost of Magnetic readers. On the kit I bought the two longer readers are good for the x axis on both lathe and mill, leaving the shorter (cheaper) readers to be bought as extras.
4. 15% discount is really worthwhile on a purchase of this size and Allendale seem very competitive. I didn't want to buy from overseas due to cost of returning items under warranty. The discount saving goes a long way towards the cost of the two extra readers
5. Magnetic readers are more compact and can be cut to length helping me to make a neat and 'workmanlike' installation. Optical readers seem fine where they are out of the way and can be installed with the head underneath the bar. I was not keen on using optical for the z axis of the mill, being fearful of muck getting past the seals where the head passes through (I have linishers right next to the mill so often have fine wood dust floating about that area).
6. Initially I was tempted to have their 'mini' magnetic head as a removable item to share between the Boxford topslide, tailstock and the Centec Quill. I then realised that to do this I would soon want the 'summing interface' for use on the quill and the topslide.
This would add together readings from the other reader working on the respective axes. I wasn't sure I needed these features sufficiently to add nearly £300 to the bill and in any case this would not be accurate when the topslide is set at any significant angle or when the vertical head on the mill is set at an angle (effectively a fourth Axis in that case).
Instead of this I am 'reworking' a cheapo Digital vernier to make a simple DRO for the lathe topslide - if this is successful I will post details as I have a cunning plan for the Boxford which at present looks most promising.
I might then use a similar arrangement for the Centec vertical head. I bought a QuillStar reader some time ago but never fitted it as its arrangement does not suit the Centec - It was actually designed to go on a Bridgeport. I had been hanging onto this with the idea of using the slide and reader head but have been reluctant to do so this to an expensive item. It is probably better that I move it on to someone with a Bridgeport.
Samsaranda23/11/2018 17:39:45
824 forum posts
5 photos
I fitted MDRO optical scales to my Champion V20 mill, only needed X and Y axes because mill was equipped with magnetic scale on Z. They have been brilliant, wouldn’t be without them. I would like to fit same to my lathe but having just bought another shotgun I would have great difficulty getting the expenditure sanctioned by head of finance at the moment, still it’s on the list.
Dave W
Cornish Jack23/11/2018 17:58:12
988 forum posts
137 photos
Duncan, John and Dave, many thanks.
Your replies have sorted out the Yes/No decision - the Mag/Optical decision has firmed up to Mag, unless someone with real world experience advises strongly against. Now I've got to behave myself for a month!!
rgds
Bill
Martin Whittle23/11/2018 18:16:38
84 forum posts
9 photos
After a discussion with an MDRO representative at the Midlands show last month, I ordered and have recently fitted the Champion V20 mill kit to my Warco WM16. It all went very straightforwardly without significant problems, and I am very pleased with it indeed.
So I am now eagerly awaiting delivery of an MDRO 'Chester lathe kit' for my WM250!
Martin
Brian H23/11/2018 18:17:26
1389 forum posts
100 photos
Posted by Cornish Jack on 23/11/2018 15:49:36:
rgds
Bill
Hello Bill, I went for the magnetic ones because they can easily be cut to size, 'though in the end I didn't have to cut them.
mechman4823/11/2018 18:29:49
2549 forum posts
385 photos
'So I am now eagerly awaiting delivery of an MDRO 'Chester lathe kit' for my WM250!
Looking forward to your set up on the WM250, I have this lathe model myself & have had this idea on the back burner for some time.
George.
Martin Whittle23/11/2018 18:49:10
84 forum posts
9 photos
Posted by mechman48 on 23/11/2018 18:29:49:
George.
Hi George
I shall report back when I fit the kit
Martin
Machine-DRO26/11/2018 15:34:29
18 forum posts
25 photos
Hi all,
Thank you for your feedback, always great to hear from our customers own experiences
We have extended the sale for cyber monday, this offer will end on Thursday 29th November
If you have any questions please feel free to contact our product technical specialists on 01992 450780
Allendale Team
