Forum sponsored by Allendale Dec 6th
Machine/hand reamers?
AJW21/11/2018 21:44:23
275 forum posts
117 photos
My first embarrassing question!
I am of the understanding that a hand reamer has a long cutting taper and a machine reamer is shorter in taper.
I have never used a reamer 'by hand's as I feel the finished bore could suffer from radial movement while turning. I have only used any type in the lathe with a centre in the reamer end or if smaller in the chuck, and have never reamed under power.
What type should I be looking to purchase when used as above, or am I thinking too deep?
Alan
Pete Rimmer21/11/2018 22:02:51
472 forum posts
19 photos
The whole reason that a hand reamer has a long taper is to prevent the thing you're worried about, but if you're using the reamer in a machine either powered of hand-turned, buy machine reamers.
AJW21/11/2018 22:36:37
275 forum posts
117 photos
Thanks for that, I seem to have quite a mixture of reamer types but always use the as above.
Might try the hand ones! (by hand)
Alan
Zan21/11/2018 22:42:02
136 forum posts
5 photos
Machine readers can size a blind hole, hand cannot. Hand can be put half way down the taper to provide a force fit. It’s always best to guide a hand reamer using the centre. Hand readers need a smaller reaming allowance to stop them juddering in the hole. I have often used a hand reamer under power, but by pushing the tailstock to give some small measure of float,- not for very small ones though! I’m building a set of both.
Marcus Bowman21/11/2018 23:05:04
162 forum posts
Hemingway do a nice kit for a floating reamer holder. I made one a while ago.
Marcus
ega21/11/2018 23:05:27
1335 forum posts
109 photos
Posted by Pete Rimmer on 21/11/2018 22:02:51:
And, I would suggest, chucking reamers rather than taper shank.
AJW21/11/2018 23:19:06
275 forum posts
117 photos
Thanks guys, it's all gone in the memory bank!
Alan
JasonB22/11/2018 07:04:53
16530 forum posts
1759 photos
I use my hand reamers under power, just run slowly as the longer engagement length of the taper may chatter if you go too fast. I hold with a collet chuck in the tailstock when it really matters buy drill chuck if not so critical.
Tee London LMES 6th Dec
