WIRE PLAN
ray jones 1 | 21/11/2018 19:59:09 |
54 forum posts 29 photos | HI I have acquired a new unused milling machine, it is USA origin, the motor is 3 phase 440v / 220v dual voltage, 2 horse power. The motor has 9 wires. ( see plan sketch ) Cables are named U1, U2, U5,, V1, V2 , V5 and W1, W2 , W5. I have a standard 3 phase , 3 cable / live supply I.E. No neutral. I am trying to wire it for standard 440 Volts. not 220 volts any suggestions on which wires should be joined and which should be connected to the live feed inputs please many thanks RAY
Edited By ray jones 1 on 21/11/2018 19:59:59 |
John Rudd | 21/11/2018 22:02:51 |
1452 forum posts 10 photos | For 415, ordinarily, you would common up the 1's (or the 2's ) and feed the phases to the 2's ( or the 1's ) Could be the motor is dual speed too...any label on the motor?
(Didnt know they used 415 ac 3 phase....usually 110 single or 220 multi..) Edited By John Rudd on 21/11/2018 22:05:01 |
Emgee | 21/11/2018 22:25:49 |
2409 forum posts 287 photos | Hi Ray Could be some variation of a Dahlander multi speed circuit needed, only thing that concerns me is the 220 or 400v choice. Can you show a picture of the motor plate ? Emgee |
Les Jones 1 | 21/11/2018 22:35:53 |
2255 forum posts 156 photos | I have found this web page by serching for "American three phase dual voltage motors" Your motor could be this configuration but with a different numbering system for the connections. You should be able to confirm if this is the case by measuring resitsnce values between the terminals. Even if we confirm this to be the case I don't know how to work out the way it should be connected to get the phasing of the three separate coils matched to the three coils allready connected in star configuration. If you post a picture of the label on the motor it may give us a clue to the numbering system used by the manufacturer. Les. |
Robbo | 23/11/2018 14:54:37 |
1504 forum posts 142 photos | All I can offer on this is a pic of the data plate of an American 9-wire 3-phase dual voltage motor that I have. This seems to follow the wiring shown in Les's link. The actual wires are all the same colour and are numbered from 1 thru 9. I have it set up for low voltage Delta via a VFD, so no point in showing the actual wiring. At first I found it confusing that 3 wires (4, 5, 6) are connected together when in Delta when on our 6 wire configuration this would be for Star. The "Y CONN" refers to the connections to the left. Sorry this is all numbers and not number and letter combinations. |
John Rudd | 23/11/2018 16:11:54 |
1452 forum posts 10 photos | looks to me that your 3 phases are connected to terminals ( wires..) 1,2 and 3. then 9-6,8-5 and 7-4 are joined as pairs....Its a single speed motor.....the star point is 4,5 and 5 So each phase has two coils in series for 440v or in parallel for 220....so for you running it from a vfd with a 240 output you must have it wired in lo voltage format?
Else I'm completely wrong! Edited By John Rudd on 23/11/2018 16:15:28 |
Les Jones 1 | 23/11/2018 17:12:30 |
2255 forum posts 156 photos | Hi Robbo & John, Les. |
Robbo | 23/11/2018 23:15:06 |
1504 forum posts 142 photos | Posted by John Rudd on 23/11/2018 16:11:54:
So each phase has two coils in series for 440v or in parallel for 220....so for you running it from a vfd with a 240 output you must have it wired in lo voltage format? That's correct John. Wired as the right hand diagram. Works fine. |
ray jones 1 | 26/11/2018 18:34:43 |
I Have now added photos of the Motor spec plate and wire instructions. It appears the Motor was factory pre Edited By ray jones 1 on 26/11/2018 18:35:19 |
