Forum sponsored by Allendale July 23rd
Cutting a large round hole
petro1head21/11/2018 18:29:53
600 forum posts
110 photos
I need to cut a hole in some 2mm alloy sheets. Its for a computer as I want to add an extra 120mm fan.
I was just going to but a hole saw from screwfix **LINK**
Any advice ie should I sandwich between 2 pieces of wood
JasonB21/11/2018 18:37:28
15750 forum posts
1647 photos
Have you got a boring head, could do it with that.
Neil Wyatt21/11/2018 18:41:34
16257 forum posts
679 photos
74 articles
Posted by petro1head on 21/11/2018 18:29:53:
I would, then it should be easy.
Make sure it is well clamped, if it can move, it will.
petro1head21/11/2018 18:49:42
600 forum posts
110 photos
I have Jason but it not big enough
Cheers Neil
Andrew Johnston21/11/2018 19:08:04
4710 forum posts
532 photos
Mark the centre, scribe the circle with dividers, drill, saw, chisel the centre away, file to the scribed line. Shouldn't take more than 10 minutes or so in aluminium.
Edited By Andrew Johnston on 21/11/2018 19:08:23
petro1head21/11/2018 19:19:03
600 forum posts
110 photos
Jason, I think the hole saw option will be quicker and neater
Carl Wilson 421/11/2018 19:41:33
668 forum posts
53 photos
The hole saw option will be a complete dogs breakfast. Hole saws tend not to be especially round and you will end up with an oversize/oval hole.
The way to do this is to use an abrafile in a fret or coping saw. Mark it out with dividers then drill a small hole to get the abrafile in. Then saw out your hole.
Minimum amount of filing then required to achieve the final dimension.
Abrafiles are now sold labeled up as 'rod saw blades' I believe.
Michael Gilligan21/11/2018 19:48:21
13557 forum posts
586 photos
Posted by Carl Wilson 4 on 21/11/2018 19:41:33:
Do you have a link to a reputable supplier, please, Carl ?
I have yet to find a decent modern equivalent to the original Abrafile.
Ian Hewson21/11/2018 20:02:23
259 forum posts
24 photos
The hole saw will cut a decent hole if used in a drill press and the plate clamped to a wood backing piece, I have done thousands over the years, usually freehand in a pistol drill.
The saw you link to will need an arbore to mount it though, a cost effective method would be the drill and file method.
Not a long job in aluminium.
alan ord 221/11/2018 20:09:19
66 forum posts
When I was making the splashers for my Pansy loco I made steel mig welded "cans / tubes" from 1.6mm thick steel sheet. The diameter from memory was around 5". I used a cheap treppaning tool in the drill press, clamped onto a sacrificial piece of wood on the table. Cutting half way through and turnoing over to complete the cut. Filed away the burs before going on to weld it to the rolled centre piece worked out well.
Should be a dodle with aluminium.
Alan.
martin perman21/11/2018 20:10:09
1614 forum posts
67 photos
I smear tap/die lubrication which helps the hole saw work.
Martin P
Carl Wilson 421/11/2018 20:14:35
668 forum posts
53 photos
I've also yet to find an equal to the original abrafile. I have a small stock of originals that I use carefully.
I think the nearest equivalent now is a tungsten carbide tile cutting saw blade. Not as good as an original abrafile but should do a good job on the above.
A 120 mm hole saw is going to make a right mess.
JasonB21/11/2018 20:28:29
15750 forum posts
1647 photos
You don't need a big head, just a tool out the side, this quick video was done for Ron in his boring head thread but I just used scraps of 2.5mm ali as an example.
Not a bad finish
Edited By JasonB on 21/11/2018 20:31:52
Edited By JasonB on 21/11/2018 20:46:06
John Rudd21/11/2018 20:29:20
1365 forum posts
58 photos
How about a tank cutter, treppaning tool?
JasonB21/11/2018 20:35:50
15750 forum posts
1647 photos
If you don't know what a treppaning tool looks like it's the one bottom left. That would do the job too.
Emgee21/11/2018 21:06:14
1146 forum posts
206 photos
The tool Jason refers to as a trepanning tool is probably what John and I call a tank cutter, originally used in an old fashioned brace, or very low speed power drill.
Emgee
vintage engineer21/11/2018 21:17:02
142 forum posts
You need a longer tool.
Posted by petro1head on 21/11/2018 18:49:42:
Cheers Neil
petro1head21/11/2018 22:44:57
600 forum posts
110 photos
Just had a look at the photos in the boring thread and now see what you mean. Will check my boring tool to see it the bit will fit the way. At the mo the tool bit points down
Edit:  yes it has  the tool it is triangular like this https://www.chronos.ltd.uk/acatalog/info%5fXP162%2ehtml
Edited By petro1head on 21/11/2018 23:07:30
Marcus Bowman21/11/2018 23:02:22
161 forum posts
Bosch make hole saws with fine pitch teeth, specially for cutting holes in thin sheet metal. Not cheap, though.
Marcus
Mike Poole21/11/2018 23:50:29
2015 forum posts
46 photos
The tank cutter type tool works well until you break through, i find attacking from both sides is helpful but you will probably still need to tidy up with a file. Hole saws seem to make a hole but holding to a size is not their strong point. If you don’t mind a bit of filing then jig saw most of the waste and file to size.
TRANSWAVE Converters
Meridienne Sept 2019
Advertise With Us
