Forum sponsored by Allendale May 23
Wooden display base
3404620/11/2018 16:58:24
374 forum posts
Can anybody recommend a supplier of bespoke wooden bases to mount an engine on please?
Just want a plain oak base, about 9 by 4.5 by 1/2 inch thick no fancy shape sides.
Fed up with looking on ebay and etsy.
Thanks
Bill
Rod Ashton20/11/2018 17:49:47
280 forum posts
12 photos
Buy an old laboratory balance!!
Bazyle20/11/2018 18:01:09
4489 forum posts
184 photos
Google your town for woodwork / turning /carving club /society. Likely that someone will be happy to make one for you and possibly in exchange for a metal bit for one of his projects.
Graham Wintersgill20/11/2018 18:16:23
2 forum posts
Bill
Unless you are set on Oak I can supply a piece of American White Ash or strips of Western Red Cedar left over from my kayak and canoe build.
Graham
Bazyle20/11/2018 18:19:03
4489 forum posts
184 photos
Just had another thought. Try looking for a local sign maker as house signs and nameplates are about that size. If in Devon try Notice-it in Topsham. Only thing is the lead up to Christmas is busy for them as a people think of easy presents.
3404620/11/2018 18:23:13
374 forum posts
Thanks replies gents.
Graham - PM sent
Bill
Ian Parkin20/11/2018 18:45:08
606 forum posts
166 photos
If you just want a piece of English or European oak the size that you quoted let me have your address and i’ll Drop a piece in the post for you
i can do it rough cut ,planed, or planed sanded and finished
bricky20/11/2018 19:02:32
368 forum posts
47 photos
Try a kitchen fitter who often rip outdated oak units and the doors are ideal pieces of timber.
Frank
fizzy20/11/2018 19:36:47
1564 forum posts
104 photos
theres a chap on ebay sells them cheap - type in plinth - I use them to display my boilers and they are well made solid wood
Stuart Bridger20/11/2018 20:14:56
274 forum posts
15 photos
Cheap chopping board from a supermarket, cut to size and finish
Barnaby Wilde20/11/2018 20:17:05
324 forum posts
I've used chopping boards from the local supermarket in the past.
Tesco's granite ones make excellant flat surface tables too.
Derek Lane 220/11/2018 23:36:02
179 forum posts
47 photos
If you get stuck give me a shout as I have some Oak/ Roughly where about are you
3404621/11/2018 08:24:22
374 forum posts
Thanks for the offer Derek
I said oak as I needed a light colour but any light / yellow colour would do as engine is black.
I have no woodworking skills or equipment so was looking to buy a finished base.
Would have happily paid up to £20 for a bespoke one..
Bill
Edited By Bill Chugg on 21/11/2018 08:24:56
Martin Kyte21/11/2018 08:54:39
1404 forum posts
9 photos
Oak is quite acidic to the extent of tending to rust steel screws used as fixings so be aware if you do use that. If the engine base is directly in contact then a good sealing of shellac and wax or varnish should protect your engine.
regards Martin
Bandersnatch22/11/2018 01:30:06
1154 forum posts
40 photos
In Canada/US you can get finished bases from a decent handicraft store such as ' Michaels. Surely there are similar such stores in the UK which might supply one?
Derek Lane 222/11/2018 09:46:35
179 forum posts
47 photos
Posted by Bill Chugg on 21/11/2018 08:24:22:
Bill
Bill I will have a look to see what other wood I have. I definitely have Oak if you want that just for postage. I can cut to size and finish.
But as stated above Oak can play effect metal if both are left bare due to the Tannin in it. I turned some wet Oak once and had to clean the lathe straight afterwards and even then the metal started turning black.
Samsaranda22/11/2018 10:26:57
651 forum posts
4 photos
Check Ebay there are numerous sizes of finished plinths suitable for mounting models.
Dave W
3404622/11/2018 10:52:12
374 forum posts
Thanks reply all
I need a specific size 235 by 135 by 10mm
As soon as you ask the ebay sellers for a non standard size the price doubles - quoted £30 by one chap.
Local woodwork / window / furniture makers quote the same figure - but be about six weeks.
It is at times like this you wish you were in Canada or America.
Thin wall brass tube 1 inch diameter - I have to buy it from America,
Thanks to a kind member I am now sorted
Bill
Weary22/11/2018 11:08:00
275 forum posts
Bill,
Brass tube, 1" diameter x swg 22 (0.028", 0.75mm) is listed by M-Machine metals. He also stocks 20, 18,16, & 10 swg.
Phil
3404622/11/2018 11:16:09
374 forum posts
Posted by Weary on 22/11/2018 11:08:00:
Bill,
Phil
Phil, thanks for that.
Just checked it out and saved it. That will be a great help
Thanks
Bill
TRANSWAVE Converters
