Forum sponsored by Allendale May 23
Denham lathe
Michael Instone10/11/2018 19:43:00
1 forum posts
just joined, have bought a Denham lathe, need a manual & possibly the gears. Would any other manufacturers back gears fit. All help appreciated.
Brian Wood11/11/2018 12:23:34
1894 forum posts
37 photos
Michael,
Go to www.lathes.co.uk and look at the splendid archive there. Tony Griffiths, whose site this is, covers a very high proportion of most of the machine tools made and Denham are listed
The change gears are listed in the tooth numbers needed but sadly not the DP number, which I suspect just by looking at the photos is 16 DP. Those you can pick up from sales on ebay or from people selling off parts for other lathes. I believe the Raglan Little John lathes had 16 DP change wheels, but I could be wrong. Drummond is another make using that size, but those may be hard to source.
If you have even one with the lathe you can establish that parameter for yourself. Count the teeth, add 2 to that count and divide the total by the diameter in inches. The numbers are always whole and even which makes deciding what you have exceptionally easy
Welcome to the forum by the way
Brian Wood11/11/2018 14:36:13
1894 forum posts
37 photos
I forgot to add, he also does machine manuals for sale
Keith Long11/11/2018 16:22:44
780 forum posts
10 photos
Michael
Just to save you a bit of frustration, the common change wheels for Drummond lathes are 14 DP NOT 16 DP so you could have problems fitting them to your Denham, depending just how much room there is for gears.
Keith (multiple Drummond lathe owner)
larry phelan 111/11/2018 16:38:56
413 forum posts
11 photos
Brian,
To the rescue,once again ! I dont have a lathe like that,but I found your reply of great interest. Was never quite sure about those DP,s,another piece of useful info to be noted.
Thanks once again.
Like Tesco says "Every little helps "smileysmiley
Brian Wood11/11/2018 18:49:03
1894 forum posts
37 photos
Thank you Keith for the correction.
TRANSWAVE Converters
