Forum sponsored by Allendale Dec 6th
Myford Super 7 Serial Number Missing
Bob Johnstone27/10/2018 14:37:01
11 forum posts
34 photos
I've just acquired a Super 7, partially disassembled, and for the life of me I can't find a serial number on it. I've read through other threads on possible locations to no avail. I've even tried scraping paint of here and there, in the hopes that it might be buried under what looks to be a repaint. No joy.
The bed casting has the raised "Made in England" and "M3" (with a "5" just above and to the right) on the back, below the gap and the headstock.
I've looked on both edges of the ways, both front and back, on the tops of the ways, on the right hand end of the casting where the leadscrew hand wheel is, on the back machined surface (where the taper attachment bolts?) and underneath the feet. The only place left to look is under the headstock mating surface. Were serial numbers ever put there?
Any help would be appreciated.
Brian Wood27/10/2018 15:23:56
2008 forum posts
37 photos
Bob,
My lathe is an ML7R with the S7 headstock. The serial number is directly under the flat of the front shear just to the right of the gap, visible looking directly at that detail, and should start SK------------ Get a good light to help you, but the numbers are usually quite well stamped.
They were NOT hidden in obscure places!
ega27/10/2018 17:03:52
1335 forum posts
109 photos
The bed may have been re-ground/milled thereby erasing the serial. I think a pukka re-grinder would have re-stamped the number, however.
Brian Wood27/10/2018 17:12:09
2008 forum posts
37 photos
Ega,
Ah, I hadn't thought of that but like you I think the number should have been restored. Myford used to add a code letter to the beds they reground so that the evidence was preserved, but that was Myford practice and not necessarily copied by others
ega27/10/2018 17:22:36
1335 forum posts
109 photos
Brian Wood:
I didn't know about the code letter. Presumably this was done because Myford had a policy about the number of re-grinds that the bed could accept.
John Baron27/10/2018 18:16:29
92 forum posts
16 photos
Hi Guys,
It could be one of the Taiwanese clone Myfords, or just the bed and rebuilt.
AJW27/10/2018 19:52:49
275 forum posts
117 photos
Taiwanese clones?
Really?
Alan
V8Eng27/10/2018 20:13:17
1324 forum posts
28 photos
Posted by AJW on 27/10/2018 19:52:49:
Taiwanese clones?
Really?
Alan
Yes a quick look at the Lathes site will pick them up.
Link to same. **LINK**
AJW29/10/2018 13:05:57
275 forum posts
117 photos
I had forgotten about those! I think I can remember seeing some at a Model Engineering Exhibition many years ago and thought they seemed very crudely finished.
Alan
Martin Kyte29/10/2018 13:35:48
1511 forum posts
24 photos
Either on the facing for the rack just to the right of the gap or on the rear of the lathe on the vertical shear at the tailstock end.
regards Martin
KWIL29/10/2018 14:33:40
3130 forum posts
57 photos
There is always the possibility that the bed was a Replacement (spare part) and so would not have a machine number allocated!
KWIL29/10/2018 14:37:55
3130 forum posts
57 photos
A further point, measure the widths and thickness of the shears, that will give an indication of regrind.
Tee London LMES 6th Dec
