loctite fixing
gerry madden14/10/2018 14:52:32
221 forum posts
114 photos
Hi all, I'm just after a bit of guidance on workholding using glues. I wanted to mill some small aluminium parts today and thought I would try the technique of bonding them to a aluminium baseplate which would be more easily fixed to the mill table. The parts are 12mm wide, 10 high and 32 long.The contacting surfaces we very clean before glueing. I used a 'retainer' on the 32x12 face and left it for an hour. I couldn't pull it off with my fingers but as soon as I started to mill it detached. I kept my cut very very light. Now I'm about to try a medium strength Loctite, 243.
Is the face area just too small or am I using the wrong glue ? These simple techniques never go wrong in the 'Clickspring' videos !
Jim Nic14/10/2018 15:06:11
362 forum posts
202 photos
Not sure what you used when you say "retainer". Loctite is best at fixing shafts and bearings into holes and when correctly used for that purpose is difficult to shift.
I often use the adhesive method for workholding and use cyanoacrylate - instant glue. Ensure your surfaces are clean, and oil free, apply the glue sparingly and with pressure. I usually leave the assembly for at least 12 hours before machining.
To disassemble, moderate heat with a paint stripper gun and a light tap usually does the trick.
Jim
Michael Gilligan14/10/2018 15:06:47
19577 forum posts
995 photos
Gerry,
I will start the ball rolling, by saying that the traditional 'anaerobic' retainers [i.e. the type that were the original Loctite range] have very low peel-strength: They are better considered as gap-fillers rather than adhesives.
For this job, you need an adhesive.
Edit: Jim beat me to the start
Edited By Michael Gilligan on 14/10/2018 15:07:55
Neil Wyatt14/10/2018 15:22:36
18893 forum posts
734 photos
80 articles
You want to be using a 'superglue' not a retainer.
Nick Hughes14/10/2018 15:43:35
256 forum posts
143 photos
This vid should point you in the right direction
Edited By Nick Hughes on 14/10/2018 15:44:25
Former Member14/10/2018 16:16:20
1329 forum posts
gerry madden14/10/2018 16:24:20
221 forum posts
114 photos
Well the Loctite 243 was a disaster too. I then dashed out to the shops with 10 minutes to spare and got some superglue as per your recommendations, tried it and guess what... it works a dream. Thanks all for your instant help !
Alan Waddington 214/10/2018 17:00:09
523 forum posts
87 photos
Posted by gerry madden on 14/10/2018 16:24:20:
Screwfix sell an own brand largish bottle of superglue and an aerosol instant activator in a pack, works great for little cost.
https://www.screwfix.com/p/no-nonsense-mitre-adhesive-200ml/41795
Edited By Alan Waddington 2 on 14/10/2018 17:03:10
not done it yet14/10/2018 18:36:20
6509 forum posts
20 photos
Some low profile holders to prevent lateral movement might be a project for you . Harold Hall has designs for these. Depends on how many small parts you are machining.
I would only use glue in a milling situation (with no other support) if there was no other alternative - just in case something gets thrown at me - unless there was a large contact area.
Howard Lewis15/10/2018 15:54:37
5737 forum posts
13 photos
Anaerobics do not like Aluminium alloys too much, because there tends to be oxygen available in the alloy (especially if there is any porosity) and so do not cure.fully.
For that sort of work, I would aim for less than the normal 0.003" clearance, tending towards size and size.
With Ali, warming the outer will not only expand it, but speed curing.
Nick Hulme15/10/2018 21:24:53
750 forum posts
37 photos
Some think "Locktite" is a thing rather than a myriad of products, of course using the wrong product will not work, did you read the application sheet for your product?
oldvelo16/10/2018 21:51:44
280 forum posts
54 photos
Hi
The earlier adverts for super glue showed lifting an elephant with two pieces of metal glued together believe it or not.
As yet I have not lifted an elephant but used it in many fixing jobs.
Eric
not done it yet16/10/2018 22:19:29
6509 forum posts
20 photos
Yes, but.... shear forces are a different story. Magdeburg hemisphers could not be pulled apart by horses, but quite likely slid apart if there were no interlocking rims to prevent it. In school, we used small ones to demonstrate the forces needed. Same with magnets, too - more easily detached if they can be slid off the surface
JD Metals
walker midge
rapid Direct
