Small slitting saws
ronan walsh09/10/2018 21:56:58
539 forum posts
32 photos
I am looking for a small slitting saw, 1 1/4" x .082", anyone know where i might buy one ? I have looked on ebay etc, but this size is smaller than any i can find.
not done it yet09/10/2018 22:23:14
4155 forum posts
15 photos
Is the 1 1/4” dimension diameter or arbor size?  2mm is close.
Edited By not done it yet on 09/10/2018 22:24:23
Emgee09/10/2018 22:26:15
1400 forum posts
212 photos
Try searching for Dremel 32mm saw blades, many available but perhaps not the exact thickness you want,
you may be able to double up 1mm thick blades for close to your desired width.
Emgee
ronan walsh09/10/2018 22:38:43
539 forum posts
32 photos
Yes 1 1/4" is the diameter of the blade itself, not the arbour hole. I will look at the dremel blades.
Mike Poole09/10/2018 22:39:12
2434 forum posts
53 photos
Chronos have 20mm 25mm and 40mm, if the thickness is critical perhaps a thicker one could be ground down.
SteveI09/10/2018 23:32:57
246 forum posts
17 photos
Ronan,
CR Tools in Sheffield have several options very close to what you want.
I have no connected except as a satisfied customer.
Steve
John Paton 110/10/2018 14:59:08
232 forum posts
6 photos
What bore do you need? I can have a look in my box of slitting saws as I no longer use the very small ones (used to when I had a Myford), some are really small diameter and from memory I think most were about 1/4" bore.
pgk pgk10/10/2018 15:51:26
1638 forum posts
287 photos
CTC do a range of small slitting saws cheap enough for a punt. The arbor they provided was rubbish but that's easily knocked up.
Edited By pgk pgk on 10/10/2018 15:51:42
ronan walsh10/10/2018 21:17:17
539 forum posts
32 photos
Arbour size is not really important, as i can make up a simple one, its for a one off job.
speelwerk10/10/2018 22:01:01
350 forum posts
Arntz **LINK**have a good metric range of small slitting saws, it is a German based compagny but curiously only the Dutch and the US agents have the small ones. The direct link does not work, you find it by; Circular Saw Blades - Metal Circular Saw Blades and then at the end of the page you go to DIN 1837-1838. The 2 mm thickness will probably make a slit around 0.02 mm wider. If you clamp two of 1 mm together it will be less accurate and very close to your desire and if you want it a little wider you can clamp a shim from 0.02 mm or more in between. Niko.
Edited By speelwerk on 10/10/2018 22:02:32
John Paton 112/10/2018 00:20:25
232 forum posts
6 photos
Ronan
I have just been through my tin of small slitting saws.
I don't have an 982" one but have a pair of thinner ones that gang up to 087 if that is near enough for you.
The blades are 1.75 diameter with 5/8 bore. Both ares HSS one by Buck and Hickman, the other Wolferal.
Would these do the job?
ronan walsh14/10/2018 20:43:46
539 forum posts
32 photos
Posted by John Paton 1 on 12/10/2018 00:20:25:
Ronan
Thanks for taking the time and trouble to do that John, but the OD needs to be 1.25", the thickness is not so critical, around the 2-3 mm mark, but the diameter is. Thanks again.
JasonB14/10/2018 20:51:06
17281 forum posts
1859 photos
Ronan, what are you using the saws for?
Would it be possible to make a simple cutter from a slice of silver steel or piece of gauge plate with say 8 teeth that could easily be mounted on an arbor or what about grinding down a cheap 1 1/4" dia woodruff cutter to the required width?
Edited By JasonB on 14/10/2018 20:52:21
not done it yet14/10/2018 21:16:39
4155 forum posts
15 photos
Some on the big river. Probably not what you want or of decent quality, this set contains one cutter of 32mm diameter, but is cheap and blades could possibly be ganged together for extra width? Only posted it because we have no idea of the material to be cut...
Neil Wyatt14/10/2018 21:28:27
17330 forum posts
690 photos
77 articles
There's this one I made from 1 1/4" silver steel. Ended up about 29.9mm diameter, 2.65mm thick.
I wanted to cut holding down slots in the sides of a cast iron toolmaker's vice. Did a great job and since I've used it for a few other things. Looks crap, but works fine, just needs to eb run gently as it's carbon steel.
You could copy it as Jason suggests, or if you are really stuck and it's near enough on diameter I could post it.
ronan walsh14/10/2018 21:31:10
539 forum posts
32 photos
Posted by JasonB on 14/10/2018 20:51:06:
It is to mill a semi-circular slot into a block of steel about 8mm square. There is a piece that fits through the slot and when the 8mm piece lifts up and down, the cross piece, which is mounted on a pin, is used on the opposite end to lift something else, like a miniature see-saw. This is for a job for a college students project, i am not fully aware of what it does, and i would rather buy a cheap slitting saw than waste more time making yet another piece. Thanks all.
speelwerk15/10/2018 00:33:19
350 forum posts
Is it not possible to make the cross piece fit the slot, that way the diameter of the saw is not critical. Niko.
Edited By speelwerk on 15/10/2018 00:33:48
ronan walsh20/10/2018 21:18:15
539 forum posts
32 photos
As an addendum to this thread, i found what i wanted on the site below. The tap and die company in Wood Green London. Has anyone dealt with this company ? Ok to deal with ?
http://www.tapdie.com/html/slitting_saws-_slitting_saws_inch-_slitting_saws_metric.html
not done it yet20/10/2018 22:58:57
4155 forum posts
15 photos
The minimum order might make it a bit expensive? But, if needs must....
Mike Poole20/10/2018 23:46:16
2434 forum posts
53 photos
I made a personal visit and was made very welcome, pleased with my purchases as well. I have also purchased online and it all went smoothly.
