Pressure angle of gears in Boxford lathe apron
Alan Charleston05/10/2018 06:00:36
83 forum posts
20 photos
Hi,
Can anyone tell me what the pressure angle of the gears in a Boxford AUD lathe apron is? I suspect it is 14.5degrees rather than 20 degrees but I want to be sure before I splash out on some cutters.
Alan
not done it yet05/10/2018 08:10:45
4492 forum posts
16 photos
You should be able to see the difference in tooth shape at the root. Comparison pics are to be found on the net or in gear cutting tomes. 20 degree pressure angle teeth are wider at the root. I expect (guessing) it will be 14.5 degrees - at least for earlier models.
JohnF05/10/2018 10:10:04
962 forum posts
140 photos
Why not just contact Boxford I’m sure they will advise, I have always found them very helpful
