problem with rotary table
geoff walker 104/10/2018 17:31:22
398 forum posts
154 photos
20181004_150906.jpgI recently bought a mini rotary table. see photos
Today I was milling a curve in the aperture of engine frame.
My problem is that with the set up I had when I tightened the nuts the table became very stiff and it was really difficult to turn the handle on the table.
As you can see i have brass tee nuts, 4mm thread, which accept 4mm studding. the bar which goes across the frame is 1/4" m.s.
The more I tightened the nuts the stiffer the table. It feels like the tightening is distorting the table and thus creating unwanted friction between the table and base. That to me is illogical but I'm stumped for any other answer.
John Rudd04/10/2018 17:35:43
1368 forum posts
66 photos
If you place a clock gauge on the rotab and with the base on the mill as a reference, watch the clock as you tighten the clamps....if the pointer moves....
SillyOldDuffer04/10/2018 17:50:09
5633 forum posts
1157 photos
I can't account for that, but two thoughts:
  • check that the studding can't turn beyond the base of the brass T-nuts and press on the base of the table as you tighten up.
  • A nastier possibility is that the table has been damaged cutting the curve. Quite a few reports of bigger tables than yours coming to a sticky end when being used that way on steel - the gears inside aren't all that tough. If all else fails, you might have to look inside.
Hope it's something trivial!
JasonB04/10/2018 18:31:11
17856 forum posts
1954 photos
Where do you have the packing pieces that are lifting the work off the table? you are less likely to distort the table if they are directly below the points where your 1/4" clamping plate is placed. I would usually put something over the whole area that won't hurt the cutter such as 6mm MDF or a bit of rigid PVC sheet.
Edited By JasonB on 04/10/2018 18:33:26
IanT04/10/2018 21:31:41
1508 forum posts
142 photos
Sounds a lot like the same problem that can occur when you tighten the T-nuts too much on a cross-slide Geoff (like a Myford for instance). The answer there (and perhaps to your rotary problem) is to make a sub-table. I have them for my lathes and mills - partly so I can attach things that don't normally fit the holes/slots - but also so I can really tighten work down to them (and sometimes to move work (& table) between machines without disturbing the work setting (by referencing the table).
I haven't made any for my rotaries yet - but if I had this problem with one - I think it would the first thing I'd try. They don't have to be anything fancy and are very useful once made.
IanT
geoff walker 105/10/2018 07:35:20
398 forum posts
154 photos
Hi All
Big thank you for all your replies, all of which are really helpful.
A little experiment last night revealed that clamping pressure on the outside of the rim causes the table to lock, when it's nearer the centre there is no problem. I set up a dial gauge as John suggested and you see the finger move as the table flexes, not much but enough to tighten it up. It's very frustrating, I'll have a good look at it this weekend.
Really like the idea of a sub table, I have one for my lathe cross slide, they are a good idea. It might help to even the load across the table
I'll report back on this one. Thanks to all again
Geoff
geoff walker 108/10/2018 09:22:07
398 forum posts
154 photos
Hi All,
I have to say I was really disappointed with this little table of mine.
I didn't expect to have the problem I had. Having said that it was "cheap as chips" so I suppose you get what you pay for!!
Anyway I took Ian T's advice and made a small sub table. This is secured firmly by 4 screws nearer to the centre of the table. The underside of the sub table is relieved 3/4" in from the perimeter so no pressure is applied to the outer rim of the table.
No binding or flexing problems now and it should be ok for the work I have planned.
Geoff
The Oily Rag08/10/2018 09:30:48
48 forum posts
I now have a similar one to this, bought for the downsizing exercise. I will have to look into this problem as the bits I have used it for so far have been OK. Never thought of this before as I had a pretty chunky one with the larger machine, a Chinese cheapie I hasten to add yet it took all the abuse I could throw at it. Hand on heart that was a fair bit, hangs head in shame.
regards
Ian
Michael Gilligan08/10/2018 09:46:53
15481 forum posts
668 photos
Glad to see that you've made it useable, Geoff
I do remain intrigued as to the original 'failure mode' though ...
If you ever dismantle it, perhaps you could take a few photos to show the design, and the finish of any bearing surfaces.
Thanks
Edited By Michael Gilligan on 08/10/2018 09:48:33
geoff walker 108/10/2018 13:27:19
398 forum posts
154 photos
Hi Ian, Michael,
It's not really a failure as such Michael. The unit is generally well designed the action is very smooth with very little backlash. The problem as I see it is the outer rim of the table has very thin section whereas the inner part of the table has a boss underneath which stiffens it up. If you look at the set up in the earlier photo you can see that the engine frame is bearing down hard on the outer rim. This combined with the upward thrust of the tee nut is causing the rim to flex, not much, but enough to create friction between the table and the base. It's a design fault, if the outer rim was a little thicker I don't think there would be problem.
Geoff
Michael Gilligan08/10/2018 13:38:08
15481 forum posts
668 photos
Posted by geoff walker 1 on 08/10/2018 13:27:19:
Hi Ian, Michael,
I was reluctant to use the term, Geoff ... but couldn't think of a better one.
< For the defence > Whilst nothing broke, the device failed to perform as required.
IanT08/10/2018 15:40:33
1508 forum posts
142 photos
That's a tidy job Geoff - and if it's now working to your satisfaction - I wouldn't worry further about it.
IanT
Pete Rimmer08/10/2018 17:46:31
685 forum posts
49 photos
Posted by Michael Gilligan on 08/10/2018 09:46:53:
Thanks
If bolting a part to the table makes it flex, then either the table or the part isn't flat. I'd be bluing the table up to see if it was pringle-shaped first off.
IanT08/10/2018 18:18:53
1508 forum posts
142 photos
A good point Pete - but even if the table is perfectly flat - the work usually isn't - and that's before you start applying clamps, straps & packing to attach that part to the table (or cross-slide etc) being used. Quite apart from the other benefits of using sub-tables - a lot of machinery designed for hobby use just isn't that "heavy-duty" in nature - sub-tables can help rectify this deficiency and reduce the possibility of causing damage (like to the T-slots for instance).
IanT
