Forum sponsored by Allendale Nov 29
Part built Allchin 1.5 inch
derek blake11/02/2019 13:25:46
315 forum posts
91 photos
Many thanks Jason, but only Loctite if I go for bronze and brass nuts? not stainless studding and stainless nuts.
JasonB11/02/2019 13:28:42
14864 forum posts
1492 photos
Loctite for any of the metals if you prefer not to silver solder
derek blake11/02/2019 13:32:08
315 forum posts
91 photos
Thanks Jason
derek blake11/02/2019 13:55:40
315 forum posts
91 photos
sorry Jason, just one last question can I use stainless studding with brass nuts?
JasonB11/02/2019 13:56:34
14864 forum posts
1492 photos
Yes
derek blake12/03/2019 20:18:52
315 forum posts
91 photos
Evening All
lots of little bits done on the Allchin, project still ticking along and news that my boiler should be useable and will be finished in due course so that’s good news.
once this arrives the engine can take shape and I can update the pictures.
one job tonight was to thread some bronze bar 5BA and make the cylinder fixing studs.
Jeff Dayman12/03/2019 23:44:14
1402 forum posts
37 photos
Hope the extra half dozen you made for me are in the post already.....wink
Just joking. They look great Derek. Good news on your boiler.
derek blake13/03/2019 08:36:06
315 forum posts
91 photos
Anytime Jeff! wink
derek blake15/03/2019 19:31:11
315 forum posts
91 photos
Evening all
abit more work on the cylinder done after receiving it back from Ken who very kindly did some tasks I just couldn’t do on my lathe.and I still have no milling machine.
ive finished drilling and tapping the cylinder cover holes front and back, more fixing holes on valve chest cover and attempted first fit of slide valve.
im pleased so far, let’s see if it all works in the end...
Edited By derek blake on 15/03/2019 19:35:49
derek blake15/03/2019 19:31:36
315 forum posts
91 photos
derek blake15/03/2019 19:32:22
315 forum posts
91 photos
derek blake18/03/2019 12:06:48
315 forum posts
91 photos
Hi All
I'm in need of a cheat, I'm making the steam glands this week.
ive made the one for the piston but have the regulator and slide valve ones to make, I turned two yesterday and they were great until I tried to transfer the stud holes into them and I was misaligned.
is there a easy way of transferring the stud position from the cylinder into the rear of the gland ready for drilling instead of trying to measure?
I was thinking of maybe turning some studs with points and gently pressing the gland onto that this transferring a small dent as a marker.
the glands wont go right up to the cylinder so I cant use ink etc.
I just wondered if there was a really simple way that I'm missing.
Many thanks,
Del
JasonB18/03/2019 12:18:36
14864 forum posts
1492 photos
Pointed studs will work, infact you can even buy them. When you turn the point also file a couple of flats either side so you have something to wind the stud out with.
derek blake18/03/2019 12:20:38
315 forum posts
91 photos
Thanks Jason, I think that’s the best bet.
i will make some tonight, especially as they can be used again.
Del
Paul Kemp18/03/2019 15:51:22
208 forum posts
9 photos
Derek,
Lokking good, nice to see you are progressing. Usually with glands or flanges I drill off the gland / flange tapping size for the studs, put it in position and drill through and tap, means the holes are all in the right place and the studs stand up like soldiers rather than drunken sailors! In your case though pointed or transfer studs are a good way to do it. Any way that you come up with that works is a good way to do something!
Paul.
derek blake18/03/2019 19:43:10
315 forum posts
91 photos
thanks Paul, because they were blind holes I used the first one to mark the second but I’m going make some studs with points as mentioned by Jason for the other glands.
derek blake18/03/2019 19:45:23
315 forum posts
91 photos
Ausee.com.au
TRANSWAVE Converters
