Problems with a breadmaker
Gary Wooding23/09/2018 13:01:08
753 forum posts
194 photos
My wife has been using a Panasonic bread-maker for many years. She always uses the same recipe, brand of flour, and yeast, but the results vary. Mostly the bread rises OK, but has a distinct slope, with one end taller than the other. Once in a while she gets a pretty near perfect loaf, and occasionally it hardly rises at all.
We've been unable to figure out why the variation and, in particular, why it sometimes hardly rises at all.
She uses the same brand dried yeast and stores the opened packets in the fridge.
Any ideas?
Bazyle23/09/2018 13:04:56
5393 forum posts
206 photos
If it has more than one heater element perhaps one has an intermittent contact so doe not heat up one end, and sometimes more than one fails, or the switch is dodgy.
Bob Stevenson23/09/2018 13:14:14
426 forum posts
7 photos
We also use a Panasonic breadmaker with mostly consistent results, however, it was not always so.....
I don't think it's a good idea to keep the yeast satchets in the fridge as temp is everything when making bread...we buy the yeast in small regular batches and make sure we only use fresh yeast. we also use the same tepid water temp every time and make sure that the Allinson strong white bread flour is also fresh...ie we don't buy too much at one time. We have also noted that kitchen temp is critical too and make sure it's the same each time we use the machine.
a friend of ours makes really excellent and tasty bread with her Panasonic maker but has developed her own recipe using equal amounts of white and brown/wholemeal flours
The Oily Rag23/09/2018 13:25:41
48 forum posts
Useful thread for me. I am being pressurised to buy a breadmaker for our kitchen as I am constantly complaining it has been alleged about supermarket bread. Top of our list was the Panasonic machine.
regards
Ian
Baz23/09/2018 13:33:30
451 forum posts
The long suffering ( her indoors) has had a Panasonic bread maker for at least 15 years. Started off with yeast sachets but got variable results, ever since using packet all in one mixes results have been very consistent, machine has one heating element in base and bread rises equally end to end.
Gary Wooding23/09/2018 13:40:50
753 forum posts
194 photos
I don't think the machine has more than one heater.
Somebody advised her to store the yeast in the fridge in an attempt to solve the problems I've mentioned, but it had no effect.
She uses only Carr's flour purchased in 1.5Kg bags, and weighs 10oz of wholemeal and 4oz of strong white per loaf, which she makes every two days. She typically has one opened bag with one unopened in reserve, and always checks that the water is at approx the same tepid temperature every time. There is no heating in the kitchen but there is a doorway (without a door) to a heated room.So the kitchen temperature does vary, but, because it's an old Victorian house it takes a while to respond to the external temperature.
Cornish Jack23/09/2018 14:28:43
1162 forum posts
163 photos
SWMBO also has a Panasonic (12 years plus) and has mostly good results but occasional, inexplicable oddities - lopsided or heavy texture. Uses Canadian Strong flour and sachet yeast and measures quantities very carefully. No clues, so far, as to the cause of the anomalies.
rgds
Bill
Stuart Bridger23/09/2018 14:50:49
464 forum posts
26 photos
I have a breadmaker, but never use it to bake. It makes the dough, which I then cook I the oven. Vastly superior results
Vic23/09/2018 14:58:37
2567 forum posts
18 photos
We’ve had the same problem a few times with our Panasonic Gary and we’ve put it down to stale yeast. We use ours a couple of times a week and get great results from it once we realise the powdered yeast has gone off. My wife uses Sainsbury’s whole meal bread packs that you just add water and butter to but I normally add a little extra yeast to make it rise a little more. “Sloping” loaves are definitely down to not enough rise. Our Panasonic must be over 20 years old now?
Vic23/09/2018 15:02:51
2567 forum posts
18 photos
Posted by The Oily Rag on 23/09/2018 13:25:41:
regards
Ian
You don’t want to know what goes in some supermarket bread or where it comes from ... wink
Neil Wyatt23/09/2018 15:18:48
18139 forum posts
713 photos
77 articles
Posted by Vic on 23/09/2018 15:02:51:
I heard a story in my college days that you definitely won't hear repeated on this forum...
N.
Wout Moerman23/09/2018 15:28:41
47 forum posts
We aRe on our third Panasonic. We bake daily, sometimes twice. Number one was used until the anti stick coating was gone in many places. That seems to be the weakest part, also in the replacements. But they are really good machines. I guess we get about 1000 breads out of a machine, so that about 10 cent per bread.
We vary a lot in recipes and sometimes they breads are even, sometimes not. But it always tastes vastly superior to supermarket bread!
KWIL23/09/2018 15:36:04
3293 forum posts
63 photos
Batch to batch, flour will and does vary (Source - Friendly Master Baker)
Adam Mara23/09/2018 16:30:31
112 forum posts
Thought it was me getting inconsistent results with my Panasonic bread maker using recipes, pleased to hear I am not alone. I get far better results from the ready to bake packs, Wrights Mixed Grain is favourite, and has a fairly long shelf life, but always read the instructions, this is what happened when I missed 'use half a pack' on a Ciabatta mix!ciabatta.jpg
Mick B123/09/2018 17:10:36
1660 forum posts
88 photos
Posted by Stuart Bridger on 23/09/2018 14:50:49:
+1. I turn it off before the bake starts, then knock the dough flat and roll it up to bloomer shape, let it rise again and bake in the oven.
Mind you, since the sourdough loaves at Lidl, Morries and Sainsbury's have recently become so good, I haven't made any for a while...
Grizzly bear23/09/2018 18:27:51
250 forum posts
8 photos
We have a Panasonic SD 2500 about 4 years old, had a cheapo previously, no comparison.
+ 1 for fresh yeast, it soon goes off.
Good results with various makes of flour, usual mix is 300g strong white and 200g of wheat meal or country mix,
not sure of the name, but its coarse. Add honey & olive oil + 260ml of water.
Regards, bear..
Edited By Grizzly bear on 23/09/2018 18:32:20
Ady123/09/2018 18:56:37
3811 forum posts
519 photos
I always thought it was in the kneading of the dough but there's also a bit of alchemy in breadmaking
Like with the making of alloys and steels
My own preference is Hovis White and their consistent results really do astound me
Other mass produced breads just taste like total rubbish to me, even the more expensive stuff
So IMO there's deffo a sprinkling of breadmakers magic in a good loaf
EDIT
With beer I believe the wort is a critical part of the process for consistent results
Edited By Ady1 on 23/09/2018 18:58:11
Meunier23/09/2018 20:23:11
343 forum posts
5 photos
Posted by Ady1 on 23/09/2018 18:56:37:
Have thought often about inconsistent results with our Panasonic machine and believe the consistency you mention is probably due to using large - enormous by home standards - quantities in their mixes where a small variation in quantity has a minimal effect and controlled water/environmental temperatures make the difference. Our kitchen scales quantities and water temperature estimates give a proportionately greater difference than with large mixes.
DaveD
Edited By Meunier on 23/09/2018 20:24:19
Georgineer23/09/2018 21:13:40
388 forum posts
17 photos
I've been baking our own bread since the village bakery where we then lived closed down. I've worn out two Kenwood machines and am well on the way to wearing out my second Panasonic.
After a lot of experimenting we've settled on 1/3 Waitrose green flour and 2/3 Waitrose orange flour - I've no idea what's in them, I just go by the colour of the packet ! I recently experimented with Waitrose grey flour, which I know is rye. It rises but can't keep the bubbles (not enough gluten) so it sits down again. I was going to add PVA glue but was over-ruled, so I've given up the experiment.
I've found that a draught can affect the loaf - our breadmaker sits next to a window and I have to be sure to close up before baking on a cold or breezy day.
I use Allinsons tinned yeast - Easy Bake I think it's called. A tin lasts me about a month, and the yeast gets noticeably less active toward the end of the tin, which I counteract by gradually increasing the dose.
For water I use filtered tap water which I keep in a jug at room temperature. I don't think the temperature matters, but sometimes our tap water smells of chlorine and that may well upset the megobs.
George
Mark Rand23/09/2018 21:58:57
918 forum posts
6 photos
I'm surprised that nobody seems to be keeping a working yeast culture. Why is this?
EngineDIY
