Convex buffer face
Ron Laden20/09/2018 09:29:35
2255 forum posts
446 photos
I am about to turn a set of alu buffers for the 0-4-0 loco.
The buffer face is convex, can you tell me a way of producing that on my mini-lathe.
Ron
Edited By Ron Laden on 20/09/2018 09:36:26
Bazyle20/09/2018 09:38:32
6178 forum posts
222 photos
Ron,
Draw the curve you want much bigger on graph paper with a scale of about 10 thou per square and make up a table of distances from the edge for each square in from the front face. ie a series of steps.
Then just smooth off with a file (insert lots of safety advice for half wits here).
Crude maybe but much quicker than faffing about with any kind of template tracing or curve generating systems unless you want to do something like that as a challenge/interesting project in itself.
btw I'm impressed with your rapid progress and ingenuity so far.
Hopper20/09/2018 09:47:49
5505 forum posts
137 photos
Or just turn a flat surface and then put the curve on with a file. A 10" single-cut millsaw file, fitted with a handle for safety of course, would work well. You'll need a good stiff wire brush "file card" to keep the teeth cleaned out. Rubbing chalk on the file first helps stop metal getting stuck between the teeth.
Run the job at moderate to fast speed and keep the file moving at all times, using long strokes as if filing a normal job held in a vice.
Ron Laden20/09/2018 09:48:11
2255 forum posts
446 photos
Thanks Bazyle, that sounds good.
Cheers
Ron
Ron Laden20/09/2018 09:49:27
2255 forum posts
446 photos
Thanks Hopper, that sounds a good approach too.
Ron
Andrew Johnston20/09/2018 10:04:35
6404 forum posts
682 photos
Posted by Bazyle on 20/09/2018 09:38:32:
Been there, done that; 18.75" radius on an 8.25" diameter part:
In the absence of the above setup I'd be with Hopper and use files and wet 'n' dry until the curve looked about right.
Ron Laden20/09/2018 10:07:07
2255 forum posts
446 photos
Thanks Andrew
Ron
JasonB20/09/2018 11:25:31
21999 forum posts
2539 photos
You can save a bit of filing time by making a tangental cut or two and then just blend the flats into a curve with the file
Neil Wyatt20/09/2018 11:44:37
18894 forum posts
734 photos
80 articles
I did it the way Jason suggests, and for Norden they are oversize at 1 1/2" diameter in 3 1/2" gauge!
JasonB20/09/2018 12:01:43
21999 forum posts
2539 photos
Posted by Neil Wyatt on 20/09/2018 11:44:37:
That's a snow plough not a Buffersmile p
duncan webster20/09/2018 12:04:24
3706 forum posts
69 photos
Industrial locos ofetn had collosal buffers to cope with sharper curves
Ron Laden20/09/2018 13:12:18
2255 forum posts
446 photos
Thanks guys,
Looking at the pics of 08,s they dont seem to have particularly large buffers, I thought they would have been larger.
Of course the 0-4-0 is not scale just pinching features from the 08 and I am guesstimating the buffer diameter to be around 15 inches so going with 1.25 inch.
Ron
Edited By Ron Laden on 20/09/2018 13:14:21
Ian S C20/09/2018 13:13:14
7468 forum posts
230 photos
I'd go the file way, but I'v got a long angle lathe file (well 3 actually), these don't tend to clog up, and they must be ok on the lathe 'cause it's stamped on the file beside the makers name on at least one of them.
Ian S C
KWIL20/09/2018 14:38:49
3477 forum posts
66 photos
See MEW 45, DAG Brown showed a setup (on a S7) for turning large radius curves such as Buffer Heads. Works a treat.
Brian G20/09/2018 18:25:21
805 forum posts
35 photos
Not just colossal buffers on industrial locos, but frequently a 5-link chain carried on the footplate for when the three-link won't reach. A long-wheelbase (11'8"  ) 0-6-0 like an 08 wouldn't be able to round the curves that needed these, but industrial locomotives (and a few BR locos like the 02) with a wheelbase around half of an 08 that could have massive buffers to avoid buffer-locking on extremely tight curves. Rochester Castle shown here operates on curves of 2 chains or less in Chatham Dockyard.
Rochester Castle in Chatham Dockyard
Edit: Spaces added to kill accidental winking smiley.
Edited By Brian G on 20/09/2018 18:29:05
Mick B120/09/2018 21:46:16
2084 forum posts
121 photos
I've never actually done this, but an experienced turner showed me a method using a pointy rod the length of the required radius located in deep dot-punches below spindle centreline on headstock and crossslide chuckside face.
You use the saddle handwheel to keep the radius rod in contact both ends, whilst traversing a tool across the workface. The saddle moves away from the chuck to generate the radius. You arrange the tool so that it reaches centre when the radius rod's parallel to the bedways.
It's fiddly, but it's simple, accurate and I've seen it work.
Edited By Mick B1 on 20/09/2018 21:49:23
Nick Hughes20/09/2018 22:21:59
256 forum posts
143 photos
I've posted this in another thread, but might still help, with some interesting methods:- **LINK**
Neil Wyatt20/09/2018 22:23:34
18894 forum posts
734 photos
80 articles
> Convex buffer face
No relation to Boaty McBoatface?
John Baguley21/09/2018 00:35:56
493 forum posts
51 photos
Posted by Mick B1 on 20/09/2018 21:46:16:
That's how I do mine:
The method was described by Tim Coles in ME Issue 4277.
Mick B121/09/2018 08:48:19
2084 forum posts
121 photos
You can of course use a similar method for concave radii, with the radius rod held between the tail side of the crossslide and a locked tailstock.
The turner I was talking about was using it to make the mushrooms on the end of full-size locomotive superheater tubes and, I think, a mating concave component too.
walker midge
rapid Direct
JD Metals
