Today's mystery object
duncan webster19/09/2018 13:55:25
2525 forum posts
49 photos
img_3366 (small).jpgBeck of London were into making microscopes, and this looks like some kjid of surveying device, but you can't see through it, there is a plastic? disc in one end as seen in photo. There is a rack and pinion to move the top member back and to, and levelling screws underneath. Anyone got any ideas?img_3365 (small).jpg
David Jupp19/09/2018 14:17:10
722 forum posts
17 photos
That plastic disc has a modern symbol found on power buttons. I'm not sure when the symbol came into widespread use, but my feeling is that the device pre-dates that piece of plastic.
Mike E.19/09/2018 14:18:24
197 forum posts
6 photos
Necessity being the mother of invention, it looks like an attempt at a home made builders level.
Journeyman19/09/2018 14:28:32
776 forum posts
131 photos
Looks like a 'Dumpy Level' but not sure if all the optics are there. Possibly by J.R. Beck, London, Ltd. (later Griffin & George) !
duncan webster19/09/2018 14:33:48
2525 forum posts
49 photos
David
Why didn't I spot that! I've had a bit of a dismantle and found there is a laser pointer down the middle, obviously replacing whatever was there before, and the level on top is diffenent as well, but I'd still like to know what it was before it was modified, the rack and pinion thing would seem to be of little use in any long range instrument, but then the bottom bit with the 360 degree protractordoen't look like it was originally part of the top bit, the paint is completely different. Perhaps it's the ultimate bitza, a microscope body mounted on an old theodolite base?
Clive Hartland19/09/2018 15:23:28
2550 forum posts
40 photos
It is more than likely a Drain Laser, there are very few drain lasers in the survey field and all that I have seen are, 'Bitza's in fact my drain laser is made from a modified projection laser. It reaches out about a half mile.
Michael Gilligan19/09/2018 15:33:39
15418 forum posts
665 photos
Posted by duncan webster on 19/09/2018 14:33:48:
yes
Neil Wyatt19/09/2018 16:10:39
17686 forum posts
697 photos
77 articles
Posted by David Jupp on 19/09/2018 14:17:10:
That was my first thought as well!
It's clearly a 21st century facsimile and not ancient at all
Michael Gilligan19/09/2018 16:37:48
15418 forum posts
665 photos
I haven't found a picture of the London Model 15
... It's probably the incredibly scarce one devil
But others in the London range are included here: **LINK**
https://archive.org/stream/beckmicroscopes00beckuoft#page/n0/search/london
Jon Lawes19/09/2018 16:46:01
370 forum posts
Best treat with care then! As LASER operators say, don't ever look into the beam with your remaining good eye.
Robert Atkinson 219/09/2018 17:53:09
600 forum posts
16 photos
It's a collection of bits, a tribrach, microscope tube with rack, bubble level and laser pointer. The collar holding the laser in is machined so not a complete bodge. I can see puutong a laser on a tribrach to level it but the microscope horizontal "translation" does not make much sense.
Robert.
