Mild steel strip 30mm x 1mm
Speedy Builder5 | 14/09/2018 07:26:07 |
2642 forum posts 217 photos | I am looking for a supplier of mild steel band (Black or bright) about 30mm wide by 1mm thick and 60 meters in length total. This is for lattice work on a gate which will be about 3.5meters wide. |
JasonB | 14/09/2018 07:40:10 |
![]() Moderator 23022 forum posts 2763 photos 1 articles | Can you not use flat stock, 1/16 x 1 1/4 is probably what the old size was and that's available. Get it in 3 or 6m lengths. |
Ron Laden | 14/09/2018 08:46:52 |
![]() 2312 forum posts 452 photos | I tried using steel banding once for something similar but it was a devil of a job trying to get it something like flat. In the end I gave up and used some large spacing steel mesh mounted at 45 degrees. |
larry phelan 1 | 14/09/2018 09:06:35 |
1190 forum posts 15 photos | Dont think that stuff would be too easy to work with. I would be inclined to go for 1"x1/8" flat,or 30x1.5 mm,if you can get it. |
Gordon W | 14/09/2018 10:00:04 |
2011 forum posts | Seems very thin section to me, is there a special reason for using it? I would go for something like 25x3 or 20x5. Easily bought, cut with angle grinder. Anything smaller may need tensioning to keep flat, corrosion will become a problem. |
Circlip | 14/09/2018 11:24:26 |
1522 forum posts | And if you go for the MUCH heavier sections advised you won't need to attend the local fitness centre to be able to move the gates, but you may acquire a free hernia.
Regards Ian Edited By Circlip on 14/09/2018 11:28:00 |
Ian S C | 14/09/2018 11:39:58 |
![]() 7468 forum posts 230 photos | Perhaps you want 20 mm/ 30 mm X 3 mm galvanised strip, I think it some times rains in your part of the world, and plain steel 1 mm thick might soon rust away even if you paint it. Are you going to rivet it at each crossing? Ian S C |
Robert Atkinson 2 | 14/09/2018 13:09:31 |
![]() 1238 forum posts 20 photos | I agree flat stock would be best (no sharp edges) but there is another approach. Get someone to cut the strips from sheet and then cut the ends yourself with a chop saw. You can get a stand to hold an angle grinder for use a chop saw. Robert. |
Speedy Builder5 | 14/09/2018 13:11:04 |
2642 forum posts 217 photos | 30 x 1 is what seems to be used over here. Rust is not a problem and some of these gates are more than 50 years old. From the photo (30 x 1) you see that the steel is left in its natural state for a couple of years to get the rusty patina, then if you can be bothered, treat with RUSTOIL which is a mix of varnish and Jenolite probably with a bit of linseed oil for good measure. One coat is sufficient for 20 odd years as a bit more patina wouldn't matter. |
Journeyman | 14/09/2018 13:51:08 |
![]() 1174 forum posts 236 photos | You can buy punched lattice sheet *** HERE *** saves fabrication! John |
Gordon W | 15/09/2018 10:05:27 |
2011 forum posts | It has just dawned on me that the strips are probably wrought iron, not mild steel. Lack of corrosion and age, also riveted construction. Good luck finding any, only place I've found in UK is re-rolled stuff, and not cheap. Just a guess. |
Speedy Builder5 | 15/09/2018 12:26:32 |
2642 forum posts 217 photos | I have found a French barrel hoop maker and making further enquires. |
Ian S C | 15/09/2018 13:49:59 |
![]() 7468 forum posts 230 photos | The barrel hoops are probably wrought iron, or similar very low carbon material, and wont rust much after the firs colouring/weathering. Wrought iron is no use for ordinary welding, OK forge welds, rivets would be the way to go, just like the barrel hoops. Ian S C |
