First Thoughts on Anodising
Neil Wyatt06/09/2018 23:56:46
17083 forum posts
690 photos
76 articles
It would feel fraudulent to write a 'how to anodise' posting following just a few day's experience!
But I have learned a few lessons, so rather than an incomplete or inexpert how-to, here are a few tips that might help others:
You are going to use a lot of nasty chemicals especially caustic soda and sulphuric acid. Stock up on latex/nitrile gloves, get goggles, old jeans (ideally ones that already have acid holes in). Make plenty of space and get things arranged in a logical manner.
Fairly dilute caustic soda cleans aluminium and strips failed anodising well, but it goes off rapidly with use. I found myself using fresh each time rather than mixing up a really strong solution.
Cleaning with dilute washing up liquid before and after the caustic bath is essential to remove any grease layer that will inhibit cleaning or anodising. If you touch the work after cleaning - clean it again or you WILL find a fingerprint in you anodising.
My sulphuric tank was at about 12-13%, this seems to work well and is below the 15% threshold where you need a licence to hold it.
I used a sealable 6-litre box for the acid that came with a plastic grid in the bottom, this helped make sure that the bottom of things anodised, but I found it helped to move objects around a few times during the process.
I sat this box in a large washing up bowl with an inch of sodium carbonate (washing soda) solution in the bottom to catch and neutralise any drips.
I had a second bath full of dilute washing soda to neutralise things as soon as they came out of the acid. I could then get them to a sink for rinsing before going into the dye.
Rinse between all solution changes.
The commercial dies I tried were excellent! They work best at about 50C so warm them up!
I tried scarlet Windsor and Newton ink for red, it was very poor.
Red Quink worked a bit better, but only made a weak pink.
Blue washable ink worked really well.
Sealing solution seems to work well, but they still recommend a steam/hot water sealing as a second step.
The final result may look uneven with brighter and duller patches. I found (after some experimentation) that gentle rubbing with a damp 'magic sponge' rapidly and easily gave an consistent satin finish without scratching.
Make sure your power supply is up to the job and keep an ammeter in circuit. If the amps get to high, fit a low-value power resistor in series (I used 0.5R for my largest piece to keep the current to 4A) Extend the anodising time for larger pieces, especially if you have to limit the current.
Finally, think safety at every stage.
XD 35107/09/2018 00:48:37
1392 forum posts
118 photos
I think Ramon Wilson may have beaten you to it !
All good info there Neil ! I haven't had the need to anodise anything yet but that will probably change once i finish the hit 'n' miss engine i'm currently building , then a ME beam engine , a mastiff etc ,etc.
Eventually i want build a murrays engine but really bling it up , the frames made from polished then jeweled alloy so maybe some of the other fittings could be anodised .
Hopefully there will be more replies here so it becomes a nice long thread with plenty of info in it for us to reference later on if needed .
XD 35107/09/2018 01:22:58
1392 forum posts
118 photos
Btw congrats on the 14k posts that you will pass in the next 24 hrs !
Neil Wyatt07/09/2018 09:52:57
17083 forum posts
690 photos
76 articles
Posted by XD 351 on 07/09/2018 01:22:58:
I can't miss the chance to thank you for that (and ring the bell!)
JohnF07/09/2018 10:08:05
919 forum posts
114 photos
Never done anodising but I do a fair bit of hot caustic blacking of steel components and where any corrosive chemicals are being used I would advise the use of a full face visor rather than goggles plus I always have a large bucket of clean fresh water close by with a suitable cloth in case of splashes or other accidents—touch wood not needed up to now but !!!
Vic07/09/2018 10:44:43
2402 forum posts
12 photos
Posted by JohnF on 07/09/2018 10:08:05:
Very wise John. Axminster tools sell inexpensive full face visors. smiley
Bazyle07/09/2018 12:33:06
4903 forum posts
195 photos
By 'commercial dyes' do you mean special anodising ones? If so where do you get them and are they available in less than a ton quantities which is often the problem with pro stuff. Do any of 'our' suppliers have them in sensible packs?
Vic07/09/2018 13:07:00
2402 forum posts
12 photos
Posted by Bazyle on 07/09/2018 12:33:06:
Getting proper Anodising dyes in small quantities hasn’t been a problem for many years. Just do a google, this was the first hit I got.
Ian S C07/09/2018 13:07:46
7468 forum posts
230 photos
I have not done any anodising (yet), but from what I'v read a good dye is the Dylon dyes normally used for fabric, it comes is little aluminium containers about 1 1/2" dia X 1/2" high. Lots of colours.
Ian S C
Neil Wyatt07/09/2018 14:15:31
17083 forum posts
690 photos
76 articles
I got my supplies of specialist chemicals from Gateros Plating.
www.gaterosplating.co.uk/anodising-main
Around four pages of datasheet with each one.
Neil Wyatt07/09/2018 14:25:49
17083 forum posts
690 photos
76 articles
Another thought... I made a point of getting 6082 for all the parts of my telescope as it is supposed to be good for anodising, strong and using one consistent material shoudl give more consistent colour.
I've just put the last component in the bath, but as it's quite small I strung a series of other small bits and pieces from around the workshop on the titanium wire. Only one of these was already anodised - a bit of door handle remodelled as a holder for a dial indicator, of unknown composition. It didn't appear to strip well in caustic soda well it will be interesting to see how it takes. Next an odd bit of bar, probably 6082, filed and machined into a quick change holder for the same indicator. Then the nut and washer from my lathe drawbar, made many, many years ago. Obviously not 6082 as it went black in the stripping bath! Obviously this allow is one of the ones where you are supposed to use a desmutting bath (nitric acid - more nasties!) so I just scrubbed them but they didn't come very clean, especially the knurl and the bore I coudln't get to with a kitchen scratchie*!
These last two seem to have gone very bright and clean in the sulphuric, so perhaps they will anodise OK.
I'll report back in an hour or two!
*AKA 'washing-up-diddy'
Andrew Tinsley07/09/2018 15:06:12
959 forum posts
I have done anodising for years and it is pretty fool proof. If you want to give it a try, buy one of the kits that several companies sell. A friend used Ebay for his kit and he got excellent results first time.
Please note the Safety warnings that come with the kit and also in the above replies.
Dyes can be problematical, I have used Dylon initially but not all colours work. The Reds do and the Kingfisher Blue as well. Some of the greens don't work and it is said (not by me!) that the pores left by the anodising process are very small (true) and some of the large molecule dyes won't go into the pores (which I doubt).
You are probably better off buying the correct dyes for the anodising process. If you are going to use the anodised product on say a finned jacket for an IC engine. I believe there are dyes which don't degrade at higher temperatures. The Dylon reds last a long time but eventually go a sort of pink shade in IC application.
Andrew.
Muzzer07/09/2018 15:42:53
2904 forum posts
448 photos
Quite an interesting article from Misumi on anodising. Always been fascinated by the "sort of hexagonal" structure of the oxide cells that are formed. These are electrically insulating of course and can actually form a fairly effective insulation layer.
In a previous company, we found various instances where the primary insulator (typically Mylar film) on some mains equipment had been punctured by swarf or other particles but the anodisation layer had been able to withstand the test and / or operating voltage. Not something you should rely on and not something that would be approved but almost certainly prevented quite a few field failures.
Must try the process myself some time....
Murray
john fletcher 107/09/2018 18:08:10
566 forum posts
I have a copy of an anodising article by Ramon Wilson in Model Engineer, I think it would be September 2012 as it was advertising the October Model Engineering exhibition of 2012.Also I have another copy of anodising, again from ME, this article is by Gerald Smith, not sure of the date,both detailed and very informative.John
Will Bells07/09/2018 20:19:53
152 forum posts
7 photos
Hi Neil ..... does Gateros sell sulphuric at 15% (it's not stated on their website so far as I can see) ? I've anodised for many years, so still have a supply of diluted, but it wont last for ever and I wasn't smart enough to stock up.
Cheers Will
Neil Wyatt07/09/2018 20:30:48
17083 forum posts
690 photos
76 articles
Posted by Will Bells on 07/09/2018 20:19:53:
Cheers Will
I think they have assumed people will just buy battery acid from a motor factor, of course it's getting more complicated now.
£39 for a permit, it lasts three years but you need the faff of getting a countersignatory and two documents from a list where most people get electronic documents now...
Neil Wyatt07/09/2018 20:31:44
17083 forum posts
690 photos
76 articles
Posted by Neil Wyatt on 07/09/2018 20:30:48:
Cheers Will
Definitely a market for someone like Gateros to sell it diluted to 15%.
Mark Rand16/09/2018 22:05:37
849 forum posts
I'm in the process of starting to make a couple of 5 step poly-V pulleys for the milling machine out of aluminium. I suspect that hard anodising might help them to last better* . If I visit messrs Gateros plating's site and buy one of their kits, then mix the acid up a bit weaker and keep the temperature low and run the voltage up higher, can I do a DIY hard anodize? Current and voltage supply and control are not a problem, knowledge is...
*The original A section, 4 step, pulleys lasted less than 60 years. Albeit, a previous owner's apparent changing of the speeds with a crowbar when he lost the handle to loosen the belts hasn't helped. sad
Clive Hartland17/09/2018 08:48:48
2502 forum posts
40 photos
I have never seen an anodised pulley? I think that it might be a bit OTT for a pulley. Further thoughts, that an iron pulley will have greater momentum than an Alu. one. Anodising is after all a protection method for weathering or handling or cosmetic?
Neil Wyatt17/09/2018 09:29:19
17083 forum posts
690 photos
76 articles
I think hard anodising may require a bit more sophistication for success. That said I'm sure it possible.
But also ordinary anodising will be fine for a pulley.
I'm thinking of anodising the pulley I made for my mill, but just as bling, not to make it work better
